Old 09-30-2015, 02:53 PM   #1
Tal
Tal's Avatar
Drives: Scion FRS 10 Series
E-85 tune, does it require a new fuel pump?
Hey guys, tomorrow i'm going to go get my E-85 tune. The tuner suggested that I get a new fuel pump. Is this a good idea?
10 Series Owner. Love it.
Tal is offline   Reply With Quote
Old 09-30-2015, 03:03 PM   #2
ka-t_240
No need unless your car is boosted and requires larger port injectors.
Many of us have been running E85 on the factory fuel system for a long time!
ka-t_240 is offline   Reply With Quote
Old 09-30-2015, 03:35 PM   #3
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Very vague question without giving some more info on your car and the mods you have
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 09-30-2015, 04:20 PM   #4
kch
Senior Misanthrope
kch's Avatar
As others have said, you're fine to run E85 with the stock fuel pump if you're NA. However, if you've got some sort of FI, then you might need to consider a fuel pump and injectors.
Old 09-30-2015, 04:28 PM   #5
Illuminaughty
Drives: 2013 Subaru BRZ Limited 6MT
Boosted or NA? I don't believe in solving problems that you don't yet know exist, especially when you can introduce new ones along the way. I'm (lightly) boosted running 7PSI on E85 and I can still peg the AFR (lambda) down to 11.0 at WOT. Entirely stock fueling system.
I'd ask your tuner why he thinks you need a new fuel pump. Seems like a rather blind assumption unless you're going for big power right off the bat.
Illuminaughty is offline   Reply With Quote
Old 09-30-2015, 06:23 PM   #6
OkieSnuffBox
Drives: '23 BRZ Limited
No, just like everyone on the FB page told you.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
themajesticone (09-30-2015)
Old 09-30-2015, 07:19 PM   #7
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
nope
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
Old 10-02-2015, 01:48 AM   #8
Zendeta
Drives: FRS
How much of a difference is running an E85/Flex fuel kit. Exactly what soft of gains are we looking at?
Zendeta is offline   Reply With Quote
Old 10-02-2015, 02:39 AM   #9
steve99
have a read of the Basic bolt on mods guide below.
you can get about 20 hp gain on a stock car with E85 and dedicated E85 tune.
Flex fuel kit/tune does give more power its just allows you to switch seamlessly between E85 and petrol or any mix in between.
dedicated E85 or petrol tunes you need to run tank down then fill with other fuel and re-flash ecu were talking naturally aspirated here. Boosted is different story
Old 10-02-2015, 03:03 AM   #10
Fastbrew
Drives: 2014 Pearl White BRZ
So - I am on E85 flex/AVO. I only changed the injectors to FIC880s. No pump. At 10.5PSI boost on E85, I get 350WHP. When I ran 92 at 12PSI boost - I was getting around 283WHP.
Two things you don't need to get this HP - a new fuel pump or a full 3" exhaust. 2.5" up front is fine.
Fastbrew is offline   Reply With Quote
Fuel Pump, tune woode Forced Induction 5 12-31-2013 11:07 AM
Fuel pump sw20kosh Engine, Exhaust, Transmission 1 12-10-2013 10:21 PM
Visconti Tune STG 1 Pump Gas Help Cal3000 Engine, Exhaust, Transmission 7 05-05-2013 08:36 PM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
