Old 04-28-2019, 10:20 PM   #15
erebuswarrior
Drives: 2015 Asphalt BRZ
Originally Posted by FR_STEEZ View Post
I just want to backfire on upshifts when banging gears. my buddies brz does it and he only has base b at -10..... I tuned my car the same way and it doesn't happen for me. I dont understand lol. we have the same exhaust mods as well
Different drivers. You and him maybe managing clutch and accelerator pedal differently. Have him try it in your car. If he does it easy in your car then it's because of how he's using the accelerator when shifting.
erebuswarrior is offline   Reply With Quote
Old 05-20-2019, 10:53 AM   #16
trinidadj
Drives: '16 FRS-MT Ablaze Red
I'm on the V4 e85 stage 2+ with catless headers, catless front pipe and a catback exhaust. If I want to make pops and some small flames, do I just need to make the edits from the original post by erebuswarrior?
trinidadj is offline   Reply With Quote
Old 05-29-2019, 08:52 PM   #17
Hadalet
Hadalet's Avatar
Drives: Argento FR-S
Originally Posted by elBarto View Post
If you want even more control, you can rescale that table to get more rpm's
It's basicly grouping all of the same values in to one table to gain 3 more tables.
(These are settings for a daily driver, just some light added burble)
Can you give a little context? It sounds like what I've been looking for. Just a bump up of the burble that's already there. This is what I see.
Sent from my SM-G892A using Tapatalk
Hadalet is offline   Reply With Quote
Old 05-30-2019, 11:06 AM   #18
elBarto
elBarto's Avatar
Drives: Toyota GT86
DO NOT EDIT those tables. You have an incorrect definition!
Editing these will result in a bricked ECU.
Use this updated definition (Only use for V4 roms, do not use these for older V2 tunes)
Those tables are included, then you will see the same as my screenshot.
OFT V4 A00C
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following User Says Thank You to elBarto For This Useful Post:
Hadalet (07-22-2019)
Old 05-30-2019, 11:23 AM   #19
erebuswarrior
After rescaling the in gear tables, to only have negative timing 2500 RPM and up, I also moved to -15.8, and here's a video of the fire I didn't know I was shooting lol.
Old 07-09-2019, 07:25 PM   #20
phiflyhigh
phiflyhigh's Avatar
Drives: 2017 Subaru BRZ
So I'm testing this tune out on my 17' BRZ and it works fine. My question though is, can you send me an instruction for how to rescale the mapping for higher RPMs? I don't like the constant burbling/popping at lower RPMs
phiflyhigh is offline   Reply With Quote
Old 07-10-2019, 12:54 PM   #21
elBarto
elBarto's Avatar
Drives: Toyota GT86
Rescale that table to get more rpm's
You can edit the top row with the rpm's also, just copy my table and add your own values. My values are for a daily driver with some very light burbles.
Old 07-12-2019, 05:53 PM   #22
phiflyhigh
phiflyhigh's Avatar
Thanks ElBarto! I just adjusted mine similar to what you have yours as I don't want all the bangs all the time.
Old 07-14-2019, 08:54 PM   #23
erebuswarrior
This is my rescaled version on Ecutek.
Old 02-24-2021, 08:32 AM   #24
BRZ_Mobin17
Drives: 2017 Subaru BRZ (silver)
I cant see the rescaled table for higher RPMs. Can anyone repost please? I just want pops and flames from like 3500 - 6500 rpm. I also am boosted with Vortech, but I dont think that will affect this.
BRZ_Mobin17 is offline   Reply With Quote
Old 02-24-2021, 05:30 PM   #25
elBarto
elBarto's Avatar
Drives: Toyota GT86
The more negative you go, the "better" the effect will be, going more positive the effect will be more softer.
My temps are in Celsius (left values of 70 and 80), but doesn't matter for the timings
Old 02-24-2021, 09:20 PM   #26
BRZ_Mobin17
Also a Side question for anyone with the answer. Where the hell do I get the updated Brz template for the OFT?!? Is it a file someone can email me
or do I have to put a request to openflash for it? Thank you in advance.
Old 02-24-2021, 10:45 PM   #27
BRZ_Mobin17
Here's my tables, how does this look?
I'm running vortech and on E85.
Old 02-25-2021, 04:57 PM   #28
elBarto
elBarto's Avatar
Drives: Toyota GT86
You can find the template files Here
Can't help you with the Vortech/E85 question.
Adding aftermarket forced induction is illegal and E85 is non-existing in my country.
bangs, e85, fire, oft, pops
DIY Rom tuning for exhaust pops and backfires W/ romraider andrew5826 Software Tuning 703 11-14-2022 04:44 AM
OFT Backfire/Pops help DaveyBonesJones Southern California 8 08-27-2018 11:53 AM
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
Bride Seat Slider Lever Pops Out pleong Cosmetic Modification (Interior/Exterior/Lighting) 0 12-23-2015 08:17 AM
Tip in backfires/"pops" sw20kosh Software Tuning 7 01-24-2015 04:15 PM
