Old 01-20-2015, 11:34 AM   #1
sw20kosh
Drives: 2013 Black FR-S
Tip in backfires/"pops"
Hey guys! Would love to brainstorm a lil on a new issue that popped up when my tuner ported my tune over to a new ecutek update/Racerom version.
If I ever so gently tip into the throttle while cruising I'll get rapid fire backfires or pops in my header and exhaust. Logs show no knock or misfire counts.
It will happen on certain downshifts too.
Any idea what this could be?
I have 0 cats and no exhaust leaks. It goes away if I flash back to previous rom version.
Old 01-20-2015, 01:16 PM   #2
mad_sb
Drives: 2013 Asphalt FR-S
lean miss-fire is my guess, despite not having a miss-fire count in the ecu. Either that or a column got transposed somewhere. Do you have a wideband?
Old 01-20-2015, 02:26 PM   #3
sw20kosh
Yes I do. I can post a log
Old 01-20-2015, 04:18 PM   #4
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Yeah You need to find out if it is too lean or too rich when this happens. Also log ignition timing to see what it is doing. Which ROM cal id did he switch from and to? Have you brought this up with your tuner yet? It maybe just one of those small details that got transposed when moving his tuned changes to a new ROM cal id.
Toyota John is offline   Reply With Quote
Old 01-22-2015, 05:40 PM   #5
sw20kosh
@mad_sb
Here is accelerator position vs. Wideband (custom map O) vs. AFR
Here is accelerator position vs. Timing
Thanks for any insights!
Old 01-22-2015, 06:18 PM   #6
mad_sb
OK, If i am reading the graphs correctly, and i may not be..
[edit after staring at the graphs some more]
Yeah that is lean misfire, look like the fuel just shuts off as you tip in. I once tried to set the main fuel map leaner than 14.7 in the cruise area, it would do just the opposite, when you saved the file it would go full rich in that cell as leaner than 14.7 is not supported in the rom. and it would go into heavy missfire when you hit that cell.... I did not log it as i had full access to the map (brzedit at the time) and saw it the instant i opened the map file again.
I have seen my own tune go sideways as a result of porting it to a different stock rom (a00c to a01c). All sorts of weird behaviors, so I went back to and have stuck with a00c. My bet is it is 100% an issue with a setting in the tune or an incompatibility in the new base tune file.
Timing looks ok, fuel is just not there on tip in. I would send those logs to your tuner and ask them to double check all the settings. So many possibilities it may be easier for them to just start over and try again.
Old 01-24-2015, 10:56 AM   #7
Toyota John
Calle Atun
The fuel AFR looks normal to me. If there wasn't enough accelerator enrichment you would see a lean spike in both AFR right after throttle tip in and then it would level out. Log requested AFR and what are you fuel trims doing?
Old 01-24-2015, 04:15 PM   #8
mad_sb
@sw20kosh
Help me understand what I am looking at on the first log graph you posted.
Lets look at the tipin event right after 2.0 mark on the x Axis:
To me it looks like you tipped in from zero accelerator angle to about 4.5%
At the peak on the tip-in event it looks like the factory front 02 is reading 20:1 or dead lean? Or is the scale not the same for afr as it is for accelerator pedal angle? Also looks like the wideband is further down the pipe and offset from the factory sensor but it is also reading dead lean at the peak of the tip-in?
DIY Rom tuning for exhaust pops and backfires W/ romraider andrew5826 Software Tuning 703 11-14-2022 04:44 AM
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
