Old 05-25-2019, 12:54 AM   #15
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
Originally Posted by norcalpb View Post
I left the factory barcode stickers on the tread and let the road take them off.
Would this cause a problem?
I highly doubt this is the issue. I think the real problem is these tires aren't up to your level of autocrossing haha. (Or they need longer to warm the carcass before going full throttle...) If you only track these tires, I would consider Yokohama Advan AD08Rs or Michelin Pilot Sport Cup 2s. If you daily and track the same tire, a couple tires that won't kill you in the rain would be Michelin Pilot Sport 4 or Bridgestone RE003s. But just my opinion.
theadmiral976 is offline   Reply With Quote
Old 05-25-2019, 12:57 AM   #16
norcalpb
norcalpb's Avatar
Dude I hope you are trolling with that statement.
I’m really not. You can see part of the sticker in the pic.
Old 05-25-2019, 01:17 AM   #17
norcalpb
norcalpb's Avatar
Originally Posted by theadmiral976 View Post
https://www.e90post.com/forums/showt...1259542&page=6
See the pictures in this thread. Seems like others have noticed these specific tires have a tendency to overheat "more than expected" for any given tire pressure. I do think, from looking at your pics and others that this is the seam between the two halves (it has to be curved to clear the sipes). I would definitely consider talking with the shop that sold them to you; however, it also looks like you have scrubbed them pretty well in just these first 100 miles so they might not have a good solution for you.
The pictures only show splitting along the width of the tread, and not along the circumference like my situation.
My last set of these tires lasted 24k including 4 track days/2 auto Xs and were most likely heat cycled numerous times. Never had a problem with cracking.
I have a track day next Saturday so FML on this one. I will buy another set if need be.
I have another set of wheels/tires for DD but I personally don't mind the noise these tires make if I decide to take them to work. The Auto-X was unlimited laps so I was able to get the tires to a good temp but barely made them squeal.
Old 05-25-2019, 01:22 AM   #18
Notice how the groove is exactly the same distance from each section of tread?
Mold seam made obvious by running tires over pressure and heating up during autox. It will just wear away with no ill effects.
norcalpb (05-25-2019)
Old 05-25-2019, 01:24 AM   #19
What possible damage can a sticker on the tread do? Think it through.
strat61caster (05-26-2019), wparsons (07-04-2019)
Old 05-25-2019, 01:28 AM   #20
norcalpb
norcalpb's Avatar
My problem is thinking it through to the point over thinking lol.
I suppose a tire faces worse things than just a sticker.
The Following User Says Thank You to norcalpb For This Useful Post:
Tcoat (05-25-2019)
Old 05-25-2019, 01:31 AM   #21
Yep. If a sticker can cause perfectly even lines following a specific repeated pattern then we are screwed.
Old 05-25-2019, 03:58 AM   #22
DM7
Drives: '13 FR-S Argento
That line is a thin strip of rubber compound that is different from the rest of the tread cap compound. That thin strip is used to ground the vehicle, giving static electricity a path to ground for dissipation. Differing compounds will heat up at different rates causing them to separate.
DM7 is offline   Reply With Quote
Old 05-25-2019, 07:51 AM   #23
ZionsWrath
Thanks
ZionsWrath's Avatar
36 psi is too high. It's probably too high when hot as well. They probably reach over 45 psi when heated up.
You also need more camber, look at your shoulders. Unless you are in a class that prohibits it. Then you might want to flip the tires when they half tread.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 05-26-2019, 12:03 AM   #24
Hi ya DM7,
Are you being serious?
Old 05-26-2019, 03:33 AM   #25
theadmiral976
Hi ya DM7,
I sure as hell hope they aren't lol
Old 05-26-2019, 03:37 AM   #26
theadmiral976
That first picture has a small amount of circumferential splitting near the top of the image. Certainly not as bad as your tires, but something to think about.
I agree with Tcoat - likely a combination of too much pressure, ambient temp, track temp, and aggressive cornering. Plus, just because a previous set of tires held up "better" doesn't mean a new set of the same make/model/type will. I would imagine your new set of Federals have a different lot number. Come to think of it, I might check the barcode on the tires out of curiosity to see when the new set was manufactured...
Old 05-26-2019, 02:19 PM   #27
DM7
Hi ya DM7,
Decades ago many tires did not have grounding strips. Cars would build up static charge as they drove along and shock the occupants when they stood on the ground exiting and entering. Some people installed anti static straps to prevent static charge from building up while driving.
I owned a set of Motomaster AW (my fellow Canadians know this budget tire brand) tires five years ago that did not have grounding strips built into them. I would get a zap each time I closed the door as I was leaving the car after a long drive.
The Following User Says Thank You to DM7 For This Useful Post:
humfrz (05-26-2019)
Old 05-26-2019, 02:37 PM   #28
Well, I'll be damned, @DM7 learnt ol humfrz something today -
Weld splitting on strut tower norcalpb Issues | Warranty | Recalls / TSB 14 04-13-2024 05:38 PM
Splitting Large Threads? Stang70Fastback Site Announcements / Questions / Issues 4 01-09-2017 02:47 PM
Lane splitting? Packofcrows Off-Topic Lounge [WARNING: NO POLITICS] 79 08-15-2016 07:31 PM
We're splitting hairs at this point (FRS v. BRZ) s5pitfire Scion FR-S / Toyota 86 GT86 General Forum 42 07-26-2013 04:20 PM
