Old 05-22-2019, 12:45 PM   #1
Scjacob827
Drives: 13' BRZ
Pandem v3 Wheel Fitment
I've looked through almost everything I can find at this point and have found very little info regarding wheel fitment for the v3 kit. Looking for a meaty/functional setup.
Any insight would be much appreciated.
Scjacob827 is offline   Reply With Quote
Old 05-24-2019, 06:06 PM   #2
kch
Senior Misanthrope
kch's Avatar
Fronts are 65mm wider than stock
Rears are 90mm wider.
Most people stick to 9.5 up front. With stock fenders, people like 9.5 +40ish, so you'll want 18x9.5 -25 in the fronts.
Rears, I see a lot of people running 18x11. If that were possible to fit on stock fenders, they would be flush at roughly +70. This means you'll want something like 18x11 -20.
This is all ballpark info that I found from a little googling. You should further verify. A lot of people who widebody their cars are fairly secretive about their wheel specs because show car. idk.
Edit: this is all focused on aesthetics. A staggered setup like I described won't handle particularly well.`
Old 05-24-2019, 06:13 PM   #3
Scjacob827
Drives: 13' BRZ
Thanks for the insight! Yeah I've been trying to just luck out and find someone else with a v3 kit that was selling their wheels but haven't had much luck. On top of that 5x100 wheels in general are hard to come across with aggressive specs. Trying to avoid custom ordering wheels but its looking like ill be heading that route shortly :/
Old 05-24-2019, 06:18 PM   #4
kch
Senior Misanthrope
kch's Avatar
Yep, the v3 pretty much requires custom wheels.
Old 06-03-2019, 01:09 PM   #5
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
Im running v1 kit.
I'm unsure of the size differences between v1 and v3.
But 18x9.5+22
and 18x10.5+12
25mm CONVERSION spacer front/rear
255/35/18
285/40/18
Tires are 2 large and throwing CEL/DTC's It's a never ending battle to get the fitment perfect ...
Celigts is offline   Reply With Quote
Pandem Body Kit BRZ Onz Cosmetic Modification (Interior/Exterior/Lighting) 9 08-16-2018 10:38 AM
Rocket bunny v3 pandem kit wheel fitment topic? 69Marshall69 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-06-2018 08:12 AM
PP wheel fitment Hix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-13-2017 10:19 PM
Help with wheel fitment jplake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-31-2016 08:08 AM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 06:33 PM
