Old 05-13-2019, 11:41 PM   #20791
RayRay88
Drives: 2017 86 860 Special Edition
Originally Posted by new2subaru View Post
"Really? Is this on 215s and stock wheels? I’m in ontario too and unless there’s snow on the ground, summer tires feel super planted. MPSS in 225 on a 8” wide wheel were planted but still playful and I could kick the back end out at will, but now Firehawks in 255 on a 9” wheel result in immortal grip basically no matter the weather"
Firehawks 225/50 R16. They def don't feel planted...there's a major difference when it warms up more. I'm very careful when driving in the wet, especially when cool.
Most likely due to your taller sidewall, regardless of summer compound.
RayRay88 is offline   Reply With Quote
Old 05-14-2019, 07:50 AM   #20792
new2subaru
Weight Weenie
Drives: 15 FR-S
Possibly, higher sidewall tires seem more compliant to me though.
I have my Juke on summer tires right now too and it's slipping in the cold. They're low profile. Maybe I'm just nitpicking...
Old 05-14-2019, 08:37 AM   #20793
StraightOuttaCanadaEh
Wes
how wide is the wheel?
Instagram: @gt86ws
Old 05-14-2019, 08:53 AM   #20794
new2subaru
Weight Weenie
Drives: 15 FR-S
7" wide. I know, it's an old school look
Old 05-14-2019, 10:27 PM   #20795
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
New livery
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
The Following 4 Users Say Thank You to Raven86Project For This Useful Post:
jflogerzi (05-17-2019), Leonardo (05-14-2019), MJones_RB (05-15-2019), new2subaru (05-14-2019)
Old 05-17-2019, 10:35 PM   #20796
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Took out my spare tire. Replaced it with a 18x8 Konig Oversteer & 215/40/18.
I LIKE TIRES!
Old 05-18-2019, 07:31 PM   #20797
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I finally did a post winter interior detail.
I hit the clutch pedal assembly hinge points with some silicone grease after being annoyed by a squeaky noise.
It may be a placebo effect but the pedal travel is definitely smoother and the squeak is gone. More notably the car now shifts smoother and I noticed less vibration in the driveline and shifter. I must be going crazy.
The Following User Says Thank You to RToyo86 For This Useful Post:
humfrz (05-19-2019)
Old 05-19-2019, 11:04 AM   #20798
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
WHAT DID YOU DO TO YOUR FRS TODAY?
Mounted &wired waterproof puller fans behind oil cooler and JRSC cooler...
Fans: https://www.coolerguys.com/products/...fan-cg12025h12
canyons is offline   Reply With Quote
Old 05-19-2019, 05:23 PM   #20799
OK, I suggest you post up some pictures in the DIY section of where you applied the grease. Lord knows we have a ton of people with clutch/TOB/transmission problems that could benefit from your discovery.
Good observation - good science!
Old 05-20-2019, 12:37 AM   #20800
suzyj
Drives: 2018 86 GTS
I took it in (actually I’m waiting while they do the work) for it’s 15,000km service, so now it’s old.
Yesterday I gave it a wash and was amazed at the number of stone chips I’ve accumulated in the four odd months I’ve had it. My daily commute is via some massive roadworks north of Perth, passing road trains and semis, so I guess that’s par for the course.
I’m toying with buying a spare bonnet and bumper, so I can then swap it out every year or so and repaint.
suzyj is offline   Reply With Quote
Old 05-20-2019, 02:39 AM   #20801
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Finalized a Greddy Oil pan install
Perrin oil cooler
and Perrin Intake (since the cooler lines get in the way of any intake)
bought a new oil pan from subaru, and used honda bond on it, thinking back I should have bought a Killer B pickup while I was down there.
talk about nerve wracking. Drove it to work and its doing just fine.
Ill check the level when i get home tomorrow morning
Clutch Dog is offline   Reply With Quote
Old 05-20-2019, 06:34 AM   #20802
Ashikabi
Ashikabi's Avatar
Clear bra
Old 05-20-2019, 06:58 AM   #20803
86MLR
86MLR's Avatar
Said I wouldn't but did
The Following User Says Thank You to 86MLR For This Useful Post:
DarkPira7e (05-27-2019)
Old 05-20-2019, 10:14 AM   #20804
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yesterday, I Painted my calipers. Found a loose nut, fixed it. unhooked my amp ground wire, scuffed the bolt location, hooked back up. Detailed the engine bay. Decided to get a different alignment , soon...
Its monday!
I LIKE TIRES!
MJones_RB (05-20-2019)
