Old 05-18-2019, 01:09 PM   #57
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
+1 for SX2.
Cheap, relatively sticky, and communicative. I can't keep up with guys on the standard 200TW fare (skill is a factor there too, of course), but I'm within a second or two.
People around here tell me that the SX2 is good in wet conditions. That hasn't been my experience. I always feel like I'm driving on ice and can't trust the car at all. Curious to know what others think?
mistople is offline   Reply With Quote
Old 05-18-2019, 01:21 PM   #58
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by showrun View Post
Ok, I'm ordering some SX2. What's the best size for a completely stock FRS (with good brake pads)?
225/45 on 17x8 wheel?
Or something wider? On a 17x9?
225/45
Old 05-18-2019, 03:59 PM   #59
showrun
Drives: 2015 FRS
Originally Posted by Horrid_Funk View Post
My 2 cents: I've been running SX2s track and street in California for over a year now.
225/45?
If so, on what wheel (make/model/size/offset)?
Originally Posted by mistople View Post
+1 for SX2.
Same questions :-)
Originally Posted by Pat View Post
225/45
On what wheel (make/model/size/offset)?
showrun is offline   Reply With Quote
Old 05-18-2019, 10:13 PM   #60
Pat
Pat's Avatar
Drives: 2023 BRZ
Kosei K4R 17x8 et 36
Old 05-20-2019, 02:05 PM   #61
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
225/45?
Same questions :-)
225/45R17 on the stock performance package 17x7.5 wheel. +48 offset.
Horrid_Funk is offline   Reply With Quote
Old 05-20-2019, 04:30 PM   #62
Horrid_Funk
+1 for SX2.
They're definitely not great in wet, but I wouldn't call it driving on ice. The only other tire I've run on the car are the stock Primacy's. The SX2 is a little more slippery but not a lot. I'd definitely prefer to use something better in the rain but I don't drive in the rain a lot so it's fine for me.
Old 05-20-2019, 04:37 PM   #63
mistople
mistople's Avatar
Right. My 215 Primacys were more predictable than my 245 SX2s. Curious to see what other high performance tires are like in the wet.
Someday I'd love to try a Hoosier H20.
Old 05-20-2019, 06:39 PM   #64
CSG Mike
CSG Mike's Avatar
It depends on how wet, and if you can get heat into the compound, and if you're fighting heat vs hydroplaning.
For the most part, most "EHP" type tires all feel like the SX2 in the wet; if you're trying to corner, it's gonna be a battle.
MPSS/MPS4S do significantly better when the surface is fully saturated and you are not getting heat in the tires at all.
Old 06-28-2019, 12:46 AM   #65
showrun
Drives: 2015 FRS
Closing the loop, after massive hours of obsessive reading, I decided on the following:
225/45Z GT Radial Champiro SX2. Save the RS-4 as an incremental upgrade for next time.
6UL 17x8 +40mm
SPC Performance 81305 Camber Bolt in lower hole, stock lower bolt in upper hole.
-2 camber all around, 0 toe.
Today was my 1st day on track at Portland. One dry session, and different levels of wet the rest of the day.
On the dry, the car was fantastic. Night and day compared to the stock Primacy. Yes I know I am stating the obvious, but it was really awesome. In one session, I just wasn't able to find the limit of the tires, whereas with the Primacy, after 4 track days, I felt the tires were holding me back.
On the wet, I made the mistake of not letting enough air out. At 37psi, the rear has zero grip. I spun twice including going almost straight. Down to 32psi and it wasn't too bad. I still spun one more time, but that was while trying to find the limit.
Thanks everyone.
Old 08-13-2019, 06:26 PM   #66
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
Originally Posted by 14stu View Post
Hankook RS4, I've got 13 trackdays on my current set and should get 2-3 more. They are slightly slower than RE71r's but faster than 615k+ (I've run all 3). The RE71r's can be ruined in a single trackday but you usually get about 6 days on them and the 615k+ last 8-10 days.
The RS4 works fine in the wet and is very progressive in the dry. They are great trackday tires.
That's the consensus I have read and why I went with RS4s. Great tire. Good, grip, feel, and wear for not a lot of money.
bmxr is offline   Reply With Quote
Old 08-13-2019, 08:57 PM   #67
showrun
Drives: 2015 FRS
I'm happy I went with the SX2. Enough grip to have fun with some amount of confidence, but not enough to hide my lack of skills. Fantastic tire for someone looking to improve.
The RS4s are in my future, but I'm not in a hurry.
Old 08-16-2019, 08:24 AM   #68
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Originally Posted by rice_classic View Post
Don't overthink it. Buy, mount, balance, track day!
Part of the fun of all this is learning. I remember one race season, I tried 4 different brake compounds and 4 different tire compounds. It was super fun because I learned a ton and really got to settle into what optimized the car (and the driver).
You're buying street tires - not uber expensive race rubber so who cares. Buy a set of RE71rs, R888rs or whatever and go run them and take notes. Then buy something different and rinse/repeat. Learning about the character traits of equipment is part of driver education. And besides - you're not competing so none of this really matters, the only thing that matters is fun...
(and safety)
I agree with nearly everything in this post (especially the safety comment which I initially missed), except I wouldn't go to RE-71R's right away. I would suggest one of the tires with better life to start out (but don't get too fussy, as stated this is HPDE, not competition).
Also, for those with some confusion about what bolt goes where, etc:
complete with part numbers!
CrowsFeast is offline   Reply With Quote
Old 08-19-2019, 08:49 AM   #69
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Not sure if this has been posted before, but here's the new 2019 Tirerack 200TW test results:
https://www.tirerack.com/tires/tests...y.jsp?ttid=242
TLDR:
It definitely looks like the new A052's are the quickest tire out there in the dry by a measurable margin.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 08-19-2019, 09:49 AM   #70
Icecreamtruk
Drives: Track preped NA FRS
The cat is out of the bag!
Icecreamtruk is offline   Reply With Quote
2019 Toyota 86 TRD Edition stevesnj Scion FR-S / Toyota 86 GT86 General Forum 265 12-04-2019 03:38 PM
Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited Busybee Scion FR-S / Toyota 86 GT86 General Forum 64 02-24-2019 12:05 PM
2019 Special Edition BRZ, any ideas??? Stephen W. BRZ First-Gen (2012+) — General Topics 126 08-06-2018 04:39 PM
2019 Toyota 86 TRD Edition interna CANADA 8 07-08-2018 09:02 PM
FS: (4) 17x7.5 Sport Edition SE-16 w/BFGoodrich g-Force Tires Doug&Julie Wheels and Tires 4 05-26-2014 06:37 PM
