Old 04-22-2019, 10:12 AM   #15
J1Avs
Drives: 2018 BRZ tS
Originally Posted by showrun View Post
I was thinking I'd wait a little before buying rear LCA and camber plates.
In the meanwhile, the only cheap option is front camber bolts. Do those make sense with the stock rear LCA? Or is camber front and rear something that needs to be adjusted all or nothing?
And is "RSRR" the Federal 595RS-RR?
I've heard Federal's stock of the RSRR's are pretty low to non-existent right now, as they are transitioning to a new tire/compound to replace it -- appears to be out overseas, not but released locally yet.
J1Avs is offline   Reply With Quote
Old 04-22-2019, 10:58 AM   #16
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Leave the stockers on until they need replacing. That is the best way to learn the car. You'll get bigger slip angles so when you put stickier tires on you'll be more comfortable. That's why some of the better racing schools teach with hard tires.
TommyW is offline   Reply With Quote
Old 04-22-2019, 11:00 AM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Is this going to be your only set of tires or will you have a DD set? It rains too much around here to have 200TW tires on year round. If you are only rolling one set of wheels you may want to go with a PS4S or Extreme contact for a while. My RS3's were downright sketchy in the wet.
Old 04-22-2019, 01:16 PM   #18
HaXx
Drives: jrsc_brz
Back to your original questions as to what tires are relevant, the staples in no particular order, and across the full spectrum of grip/wear: sport comp2, re 71r, r888r, pilot sport4s.
HaXx is offline   Reply With Quote
Old 04-22-2019, 03:23 PM   #19
showrun
Drives: 2015 FRS
Man, I don't know... I understand the logic of what you're saying... but I want more SPEED in corners!!!
The car is a dedicated HPDE car. I only drive it at most a couple hours to/from the track. That being said, wet track happens, so good to know.
I've read a lot about the RE 71R. My understanding is that it is very fast, but only for a very short amount of time before overheating. Great for ax, time attack and such, less so for 20-30 minute sessions. And they last 1-2 days. Has your experience been different?
The r888r: this thread talked me out of them: http://www.ft86club.com/forums/showthread.php?t=129352
I need to read up on the others.
showrun is offline   Reply With Quote
Old 04-22-2019, 04:30 PM   #20
MX-5RACER
Drives: 1999 Miata
The R8888r is a decent HPDE tire, I use a very similar tire on my track Miata (Nitto NT-01R). The thing with the R888r compared to the faster Hoosier R7 is the R888r SUCKS, but it sucks for a long time. The R888r is not the fastest tire, but has good wear and decent grip. For ultimate track time, there is not much that can hang with the Hoosier R7. For HDPE, you want something predicatable, with long lasting grip. The R888r or NT-01r are good choices in this respect. I prefer the stiffer case of the NT-01r as they seem to have a better feel than the R888r. They both still allow a large amount of slip angle before letting go completely.
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
Old 04-22-2019, 04:41 PM   #21
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If you really want to stick in the corners, wide slicks and aero with stiff, lowered suspension - top hats+LCA to get the right camber.
Old 04-22-2019, 04:49 PM   #22
showrun
Drives: 2015 FRS
Totally. That's the end game.
For now, I'm looking for the 1st incremental step up from completely stock.
Camber bolts and 200TW tires seem like a first step?
Old 04-22-2019, 04:56 PM   #23
EAGLE5
Dismember
EAGLE5's Avatar
Sure. Cheap first step.
Old 04-22-2019, 05:00 PM   #24
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Don't overthink it. Buy, mount, balance, track day!
Part of the fun of all this is learning. I remember one race season, I tried 4 different brake compounds and 4 different tire compounds. It was super fun because I learned a ton and really got to settle into what optimized the car (and the driver).
You're buying street tires - not uber expensive race rubber so who cares. Buy a set of RE71rs, R888rs or whatever and go run them and take notes. Then buy something different and rinse/repeat. Learning about the character traits of equipment is part of driver education. And besides - you're not competing so none of this really matters, the only thing that matters is fun...
(and safety)
PRO86 | WTCC | STL
Old 04-22-2019, 05:56 PM   #25
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Hankook RS4, I've got 13 trackdays on my current set and should get 2-3 more. They are slightly slower than RE71r's but faster than 615k+ (I've run all 3). The RE71r's can be ruined in a single trackday but you usually get about 6 days on them and the 615k+ last 8-10 days.
The RS4 works fine in the wet and is very progressive in the dry. They are great trackday tires.
14stu is offline   Reply With Quote
Old 04-22-2019, 06:46 PM   #26
TommyW
TommyW's Avatar
Speed in corners comes with driver mod. You'll be miles ahead in the long run if you learn more car control with the stock tires. People are too quick to put sticky tires on. You're a low intermediate driver in a car you haven't tracked. Do yourself a favor and wait on new tires.
Old 04-22-2019, 07:59 PM   #27
CSG Mike
CSG Mike's Avatar
Hello folks,
Bought a bone-stock 2015 FR-S a couple weeks ago as dedicated HPDE car. I drive the car to/from racetracks, and that's it. I'm in the Pacific Northwest, so rain is always a possibility.
I have done JR radiator/oil cooler, Castrol SRF, Carbotech XP10.
I'm a low intermediate driver in terms of skills. I did a lot of HPDEs several years back in a C6 Corvette. I just did my 1st HPDE in the FR-S. The stock tires are limiting. Maybe I'm kidding myself, but I feel even my limited skills could use a better tire.
I've googgled. Watched videos on TireRack. Read GRM.
I've read a bunch of older threads. Things change every year.
I'd like to discuss tire options for 2019. I'm leaning towards keeping the stock wheels, but open to going to a wider 17" wheel if it won't hinder my learning. Cost is not really a factor.
So far I'm looking at:
DUNLOP DIREZZA ZII STAR SPEC (there is some old stock left)
DUNLOP DIREZZA ZIII
HANKOOK VENTUS R-S4
YOKOHAMA ADVAN NEOVA AD08 R
Azenis RT615k+ (added per Vesartis)
Thoughts?
Is your priority going fast, or getting long life, or maximizing learning?
Lower grip tires will force you to find other ways to find speed; the stock tires are fantastic for that.
Don't get stuck in the "corvette driver" mentality!
Old 04-23-2019, 12:55 AM   #28
Sleepless
Drives: 2016 FR-S
Next great step up from stock tires are Michelin MP4S. Great in the rain too.
Sleepless is offline   Reply With Quote
2019 Toyota 86 TRD Edition stevesnj Scion FR-S / Toyota 86 GT86 General Forum 265 12-04-2019 03:38 PM
Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited Busybee Scion FR-S / Toyota 86 GT86 General Forum 64 02-24-2019 12:05 PM
2019 Special Edition BRZ, any ideas??? Stephen W. BRZ First-Gen (2012+) — General Topics 126 08-06-2018 04:39 PM
2019 Toyota 86 TRD Edition interna CANADA 8 07-08-2018 09:02 PM
FS: (4) 17x7.5 Sport Edition SE-16 w/BFGoodrich g-Force Tires Doug&Julie Wheels and Tires 4 05-26-2014 06:37 PM
