#57 |
Weight Weenie
Drives: 15 FR-S
@Speedy Nick
Can you give us the wheel and tire specs in the pic? They look perfect! (Can't quote you for some reason) |
#58 | |
Drives: Stock
I use 245/40r17 or 255/40r17 depending on the track. At Fuji, 265/35r18 seems to be faster. http://www.enkei.co.jp/wheels/racing...t03rr/size.php |
#59 | |
Weight Weenie
Drives: 15 FR-S
Thanks Nick! |
#60 |
Drives: Stock
here is the pic with 15 laps @ Fuji Speedway. Pace was mid 2m02sec, ambient temperature 20℃, track surface temperature 35 - 40℃. Held on till the first timed lap, and then went a sec slower thereafter...
| The Following User Says Thank You to Speedy Nick For This Useful Post: | CSG Mike (05-17-2019) |
#61 | |
Only users lose drugs.
Drives: All the time
Any idea what your tire temps were? Might be the angle, but that center rib looks pretty wasted...the rest looks good - great, actually. That's the left front, correct?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#62 |
Drives: '13 FRS - STX
That's just how they wear, looks totally normal for that tire and a few light laps or autox days.
#63 | |
And the aggressive wear on the center rib looks like an area that needs some design improvement...
#64 | |
I'll edit in a picture of my old set here: Edit:
#65 |
Drives: '15 STX
The center rib wears like that for a few reasons. Steering input and car balance over the front end, mainly. Since most 86's are more on the side of entry push/exit rotation, and drivers usually ask a lot of the front end, it wears like that on the front of this car. You'll notice the rears don't get a huge chamfer/taper like that.
All in all I'd say that's normal. |
| The Following User Says Thank You to tony_r For This Useful Post: | strat61caster (05-18-2019) |
#66 |
Drives: Stock
72~78℃. These wear like this, and so does other tires with straight center ribs. The funny bit is that I've reached the slip sign already there...
#67 | |
Drives: Stock
#68 |
Drives: Stock
This tire should be shaved first for any track use. I hereby also post my rear after same stints. Less than 20 laps, same situation. This tire have thick gauge with low density compound. It heats up quickly but will suffer under very high loads. I did not shave this one because I was expecting rain... and it didn't!
| The Following User Says Thank You to Speedy Nick For This Useful Post: | venturaII (05-19-2019) |
| We've got some new competition it seems... | tbwoodlee | Other Vehicles & General Automotive Discussions | 11 | 06-12-2013 09:53 AM |
| possible competition | jmaryt | FR-S / BRZ vs.... | 98 | 10-01-2012 09:31 PM |
| Looks like there's some new competition... | SOB | FR-S / BRZ vs.... | 19 | 01-11-2012 11:25 AM |
| Kia K9, competition for FR-S? | 1660 | Other Vehicles & General Automotive Discussions | 15 | 07-07-2011 10:12 PM |
| Possible Competition | brandon | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 02-21-2011 03:59 PM |
