Old 04-28-2019, 07:19 AM   #57
new2subaru
Weight Weenie
Drives: 15 FR-S
@Speedy Nick
Can you give us the wheel and tire specs in the pic? They look perfect!
(Can't quote you for some reason)
Old 04-28-2019, 10:34 AM   #58
Speedy Nick
Drives: Stock
Originally Posted by new2subaru View Post
@Speedy Nick
NT03rr 17*9J 40mm
I use 245/40r17 or 255/40r17 depending on the track. At Fuji, 265/35r18 seems to be faster.
http://www.enkei.co.jp/wheels/racing...t03rr/size.php
Speedy Nick is offline   Reply With Quote
Old 04-28-2019, 11:52 AM   #59
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by Speedy Nick View Post
NT03rr 17*9J 40mm
Thanks Nick!
Old 05-17-2019, 12:15 AM   #60
Speedy Nick
Drives: Stock
7 laps from a set of RE71R? I wish...
here is the pic with 15 laps @ Fuji Speedway. Pace was mid 2m02sec, ambient temperature 20℃, track surface temperature 35 - 40℃. Held on till the first timed lap, and then went a sec slower thereafter...
The Following User Says Thank You to Speedy Nick For This Useful Post:
CSG Mike (05-17-2019)
Old 05-17-2019, 09:48 AM   #61
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Any idea what your tire temps were? Might be the angle, but that center rib looks pretty wasted...the rest looks good - great, actually. That's the left front, correct?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 05-17-2019, 10:29 AM   #62
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
That's just how they wear, looks totally normal for that tire and a few light laps or autox days.
ineedyourdiddly
Old 05-17-2019, 10:49 AM   #63
venturaII
venturaII's Avatar
I'm not suggesting they were overheated - they don't look it. I'm just curious what the actual tire temps were at the tread.
And the aggressive wear on the center rib looks like an area that needs some design improvement...
Old 05-17-2019, 12:04 PM   #64
strat61caster
Tire's been out for 4 years now, BFG Rival S 1.5 is the only thing that comes close (better for some scenarios, drivers), center rib wear is well known, not sure why you'd change it other than 'it doesn't look nice'
I'll edit in a picture of my old set here:
Edit:
ineedyourdiddly
Old 05-17-2019, 02:43 PM   #65
tony_r
tony_r's Avatar
Drives: '15 STX
The center rib wears like that for a few reasons. Steering input and car balance over the front end, mainly. Since most 86's are more on the side of entry push/exit rotation, and drivers usually ask a lot of the front end, it wears like that on the front of this car. You'll notice the rears don't get a huge chamfer/taper like that.
All in all I'd say that's normal.
tony_r is offline   Reply With Quote
The Following User Says Thank You to tony_r For This Useful Post:
strat61caster (05-18-2019)
Old 05-17-2019, 07:50 PM   #66
Speedy Nick
Drives: Stock
72~78℃. These wear like this, and so does other tires with straight center ribs. The funny bit is that I've reached the slip sign already there...
Old 05-17-2019, 07:58 PM   #67
Speedy Nick
Drives: Stock
Edit:
and here is my Kumho V700 K61 compound after 30min of practice and 20min of qualifying... great tire. I can still do about 8 hours of tests after the race with no issue. Initial grip peak do come in the first few laps, but the drop is not significant thereafter. You really can drive them down to the cord. K91 compound lasts for ages... hence the importer switched to K61 lol. I use both depending on the temperature.
Old 05-17-2019, 08:42 PM   #68
Speedy Nick
Drives: Stock
This tire should be shaved first for any track use. I hereby also post my rear after same stints. Less than 20 laps, same situation. This tire have thick gauge with low density compound. It heats up quickly but will suffer under very high loads. I did not shave this one because I was expecting rain... and it didn't!
venturaII (05-19-2019)
We've got some new competition it seems... tbwoodlee Other Vehicles & General Automotive Discussions 11 06-12-2013 09:53 AM
possible competition jmaryt FR-S / BRZ vs.... 98 10-01-2012 09:31 PM
Looks like there's some new competition... SOB FR-S / BRZ vs.... 19 01-11-2012 11:25 AM
Kia K9, competition for FR-S? 1660 Other Vehicles & General Automotive Discussions 15 07-07-2011 10:12 PM
Possible Competition brandon Scion FR-S / Toyota 86 GT86 General Forum 14 02-21-2011 03:59 PM
