#15 | |
| The Following 2 Users Say Thank You to gravitylover For This Useful Post: | Ultramaroon (05-13-2019), wparsons (05-13-2019) |
#16 | |
You'd feel the vibration if it was the tire(s) out of balance. I'll bet the alignment is slightly wonky and making the car wander.
| The Following User Says Thank You to wparsons For This Useful Post: | gravitylover (05-13-2019) |
#17 |
Guest
Posts: n/a
So actually, I had the same kind of experience in my brand new 2018 a couple months ago. It felt like I had to make too many steering corrections at highway speed (while just going straight)-- not an alignment thing, more like the car was upset by every little crack/groove in the pavement. I definitely couldn't really cruise one-handed on the steering wheel at above 70mph, which was kind of annoying. I was actually having some buyer's remorse during the first 1500 miles because I drive so much freeway out here in CA.
The problem was completely solved when I switched to 18x9.5 wheels with wider and stickier tires. The car is wayyyy more planted now and is easily stable beyond 90+ mph. I can drive one-handed easily and I hardly have to make any steering corrections at all. This is all on stock suspension by the way-- I assume once my coilovers go on it will be even more planted. Hopefully that helps a bit! |
#18 |
Drives: 2015 Subaru BRZ
Check your bushings. I kind of felt what you are talking about. Have about 90k miles and stock suspension setup. My front sway bar bushings were dried and nasty looking. Changed to some newer poly bushing and it seems to have helped with high speed stability.
#19 |
The Dictater
Drives: '13 Red Scion FRS
You could try dropping tire pressures 2-3 psi. I can always tell when my pressures are too high if my car feels floaty on the highway.
| The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (05-16-2019) |
#20 | |
Here's the alignment printout https://imgur.com/jn52cMx I did ask when I was at that shop again yesterday if they could go a bit more aggressive and the won't. If the car is within spec it's good, they won't do anything but.
I guess it's possible that because these tires are a stiffer sidewall than the previous ones that I don't need the psi to be as high. I'll try that. |
| The Following 3 Users Say Thank You to gravitylover For This Useful Post: |
#21 | |
The Dictater
You can also do the chalk test, ideally when warm as well. |
#22 | |
Drives: '13 FRS - STX
imho on each wheel: 0.00° to +0.03° toe in the front +0.03° to +0.08° toe in the rear Maybe you can ask for like +0.01°Front and +0.05°Rear for each wheel? That's what I would try if I had to fix your car. The more toe-in you have the more stable the car will be at the sacrifice of responsiveness. It seems silly to argue over such little numbers but I guarantee you'll feel it, even at lower speeds, it's not some mushy economy car that can get away with never getting aligned and it feels 'fine' it's whole life. Edit: seems like a lazy shop to me, bringing in the right rear (toe-ing it in) would help even out the camber and could actually get all the numbers green, but the machine probably tells them camber isn't adjustable and they can't do anything about it even though camber and toe adjustments are interlinked on this car due to the multi-link setup. |
| The Following 3 Users Say Thank You to strat61caster For This Useful Post: |
#23 |
Thanks man. I'm going to follow up on this next week, have a couple of big trips to do before that though, 500 miles tomorrow and 600 on Monday. I guess I'll just keep it down to the more reasonable speeds that I usually cruise at
That was a special circumstance and I got lucky with a great lead that was hauling ass so I took advantage of it, usually I just let them roll by.
#24 | |
Drives: 2005 Toyota Camry
When I got my car new I got it upwards of 90MPH on the way back from Colorado. 3 months later, I got it up to about 110 on a flat/empty/clear stretch of I-15 in Utah (about 10 miles visibility with no other cars on the road, quite odd). Neither of those times did I feel any vibration or instability of any kind. Wider/stickier tires would make your car track more with the grooves in the pavement, not less. |
| The Following 3 Users Say Thank You to mav1178 For This Useful Post: |
#25 |
Drives: 2013 FR-S Series 10
I dont think 0.02 degrees toe out is gonna affect your stability. I've had 10 times that amount with no instability. I've felt vibration at triple digit speeds but not instability. I'd have them check your suspension for any worn parts/dampers before another alignment. At 115k thats way more likely than -0.02 degrees toe causing it.
| The Following 2 Users Say Thank You to Decep For This Useful Post: | gravitylover (05-18-2019), Spuds (05-17-2019) |
#26 | |
I'm with this guy, I've run way more toe and don't have an issue. I'd wager that 100k+ miles of new England roads have worn out the bushings and it's time to do a refresh. The front control arm rear bushing is probably the culprit. Aftermarket "stock" arms are cheap. You can get them on Amazon or Rock Auto for just over $100. I'm running one on my BRZ and have had no issues. |
#27 | |
Drives: 2016 Subaru BRZ
#28 |
Meanwhile our OP, @gravitylover is out for a test drive after adjusting his tire pressure.
"Ha! Whaddaya know? That did it."
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | gravitylover (05-18-2019), strat61caster (05-18-2019) |
| Front-Pipe Question for FRS | FewTooManyBeers | Engine, Exhaust, Transmission | 12 | 02-15-2019 10:22 PM |
| Front LCA question | caffeinejunky | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 04-30-2014 08:54 PM |
| Question for for someone who has had the front bumper off | 10Tim | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 09-30-2013 05:34 PM |
| Front lip question... | brz_guy | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 05-17-2013 01:51 PM |
| Frs/brz front piece question | lavisxice | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 01-10-2013 06:42 PM |
