questions on '17+ PP Sach shocks
i'm currently running RCE Yellow springs on the non-PP stock shocks, can i install this same springs on a set of Sach shocks that come with PP? also what's so good about this Sach shocks? do they make your car more comfortable and handles better than the non-PP shocks?
#2 |
I didn't like the Sachs shocks at all, the valving was messed up for anything other than dead flat roads.
I found them "crashy" and replaced the OEM coilover after a couple of thousand kilometres. My MCA Street Performance coilovers are better everywhere IRT performance and comfort.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#3 |
Drives: '13 FRS - STX
yes
dunno dunno |
#4 |
Drives: 2018 BRZ Limited
I'm running the an 18 PP with the Sachs dampers and TRD's (Eibach Pro's). Just about the same drop as the Yellows, although the rear springs are progressive. No issues and I think it feels great. However, I haven't experienced any other setups so I don't have much to compare it with. I've never found any quantitative comparison between the stock and Sach's. I'm sure its out there somewhere. I'm curious about the differences also.
#5 | |
Drives: BRZ 2018
I am going to fit the tS springs/shocks and from what I have read they are the same comfort wise with the OEM 17+ BRZ springs/shocks combo, am I wrong? |
#6 |
#7 |
tS Sachs should be better, but I hadn't found any lowering springs that are compatible...
#8 |
Drives: BRZ 2018
#9 | |||
Drives: '23 BRZ
FWIW I'm running the factory PP Sachs dampers with Swift BRZ Sport springs which lowered the car 1.25" and are ~40% stiffer than stock. The car performs very well at the track and I don't get the sense that it is underdamped for these springs. |
| The Following User Says Thank You to ZDan For This Useful Post: | stlgrym3 (04-30-2019) |
#10 |
Ohne Titel
Drives: 2017 BRZ PP ISM
I had a ‘13 with stock suspension and then RCE yellows. Now I have a ‘17 PP. I prefer the ‘17 suspension to either of my prior setups for comfort and handling. I think if you search you’ll find previous comments from RCE that yellows will work fine on PP dampers. Not a very expensive experiment to try.
#11 |
#12 |
Drives: BRZ 2018
#13 |
RCE Yellows work well on PP and non-PP shocks. The non-PP shocks are more comfortable.
- Andrew |
#14 | ||
Personally I don't mind that setup, though I did drive a stock 86 a few weeks ago in Japan on stock suspension and it was definitely "more comfortable." But the difference is fairly negligible. It's not like the Yellows + Sachs combo is jarring compared to stock. Just a bit stiffer, and it obviously feels great while cornering.
Instagram: @spike.grc
| The Following User Says Thank You to spike021 For This Useful Post: | Racecomp Engineering (05-01-2019) |
| OEM shocks going out? | brazy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 02-09-2018 11:07 AM |
| On lowering springs for and stock shocks, time for new shocks... | Basket Case | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 11-16-2015 08:31 AM |
| Wax Sealant Pad Questions / Care Questions | l0aded | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 03-25-2014 11:19 AM |
| What shocks | _F-R-S_ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 10-31-2012 02:18 PM |
