Old 01-30-2018, 06:29 PM   #43
CSG Mike
CSG Mike's Avatar
Originally Posted by lutfy View Post
I agree. Have not will not. It is surprising that track tires are sold with wear warranty. But then I guess its a double edged sword for them; they do sell it as 200 wear tire hence the requirement.
Lutfy
Michelins come with a superb warranty, even the MPSS!
That being said, they can tell if the tire has been abused, and will decline coverage subjectively.
CSG Mike is online now   Reply With Quote
Old 01-30-2018, 07:03 PM   #44
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
I’m just here for the free heat cycled tires.
tigermack is offline   Reply With Quote
The Following 2 Users Say Thank You to tigermack For This Useful Post:
justint5387 (01-31-2018), MisterSheep (01-30-2018)
Old 01-30-2018, 07:28 PM   #45
sw20kosh
Drives: 2013 Black FR-S
Then name the penalty something without a negative connotation like "competitive street tire" or "time trial tire".
Some people have been pretty clear how they feel about the 'stones and BFG's. Not just 86ers or people on this forum mind you.
Its named 'super soft street tire' in 86cup. The 'cheater tire' is tongue-in-cheek.
The Following User Says Thank You to sw20kosh For This Useful Post:
strat61caster (01-30-2018)
Old 01-30-2018, 08:52 PM   #46
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Thanks, that's changed since I last looked.
ineedyourdiddly
Old 03-05-2018, 09:25 PM   #47
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
What sort of pressure are you running on the track with RS4? hot pressures. whats the fastest?
Surok is offline   Reply With Quote
Old 03-06-2018, 08:13 PM   #48
n0thing
Drives: Subaru BRZ
Is it still considered slower than re71r?
n0thing is offline   Reply With Quote
Old 03-06-2018, 08:16 PM   #49
FirstWinter
Drives: Car
Yes
FirstWinter is offline   Reply With Quote
Old 03-07-2018, 11:21 AM   #50
Icecreamtruk
Drives: Track preped NA FRS
On a 2900lbs car (race weight, including driver) with moderate aero and 245 wide RS4 the sweet spot was 34psi hot for tracks with lots of low speed turns and 36psi hot for tracks with lots of high speed long turns. 38 psi felt slower grip wise and was slower or equal on the clock (depending on track setup) and 32-30 felt quicker but was way slower (almost a full second slower on some tracks). The tire likes quite a bit of camber (getting even wear at -3.8 up front to give you an idea).
Icecreamtruk is offline   Reply With Quote
The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post:
MisterSheep (05-05-2018), Surok (03-08-2018), Tristor (04-26-2019)
Old 03-08-2018, 07:38 PM   #51
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
interesting, i ran 32 hot yesterday and it felt good. i will increase for the next event.
Old 04-02-2018, 09:16 PM   #52
n0thing
Drives: Subaru BRZ
How do you properly heat cycle/bed in re71r for optimal performance?
Old 04-26-2019, 05:32 AM   #53
Speedy Nick
Drives: Stock
You can't / don't. You put a new set of RE71R just before the qualifying, run them slowly for half a lap, go full speed thereafter, and make sure that you nail your first or second timed lap. I run in a 10-lap race at Fuji. It will go off after about 7 laps so you nurse them home. The tire will be good for another 4x30min test session, and they can lap maybe 1 - 1.5sec slower than the original qualifying lap, till you go down to the cord. You should do consider two timed laps and a cooling lap, as a typical routine.
This tire is not build to do HPDP 20-30mins sessions straight. The tire was initially targeted to become the fastest street tire, hence was very popular in 86 one-make race (club-man class).
Speedy Nick is offline   Reply With Quote
The Following 4 Users Say Thank You to Speedy Nick For This Useful Post:
CSG Mike (04-26-2019), Icecreamtruk (04-26-2019), Tristor (04-26-2019), venturaII (05-17-2019)
Old 04-26-2019, 04:34 PM   #54
CSG Mike
CSG Mike's Avatar
7 laps from a set of RE71R? I wish...
Old 04-27-2019, 09:08 AM   #55
Speedy Nick
Drives: Stock
The GAZOO 86 one-make race now do two races in one day, and they run on a set. Let`s hope that this will push the tire suppliers to do something about this situation... I`ve been told that Z3 is very consistent, and only about 1-1.5 sec slower at Fuji (2min / lap track). The sidewall stiffness is quite different, so you may need different camber though. I need less than 3° front camber with V70a, but need much more with RE71R, and probably even more so with Z3.
... and I only use RE71R as my rain / mixed condition race tire. or, you can just use it on the road... after-all, it does have 200 tread-wear rating!
Old 04-28-2019, 12:05 AM   #56
CSG Mike
CSG Mike's Avatar
But you know how to manage tires better than most!
Speedy Nick (04-28-2019)
We've got some new competition it seems... tbwoodlee Other Vehicles & General Automotive Discussions 11 06-12-2013 10:53 AM
possible competition jmaryt FR-S / BRZ vs.... 98 10-01-2012 10:31 PM
Looks like there's some new competition... SOB FR-S / BRZ vs.... 19 01-11-2012 12:25 PM
Kia K9, competition for FR-S? 1660 Other Vehicles & General Automotive Discussions 15 07-07-2011 11:12 PM
Possible Competition brandon Scion FR-S / Toyota 86 GT86 General Forum 14 02-21-2011 04:59 PM
