Old 04-19-2019, 09:55 PM   #1
soundman98
ProCrastinationConsultant
soundman98's Avatar
plus 1 wheels, tire sizing question
looking to change my wheels for a future BBK upgrade. i'm also going to be lowering 1" in the future, but wheels and brakes are my first focus.
i've settled on the 18x8.5 +44 Rota KB-F wheels.
from what i'm reading the max tire width to prevent rubbing is 225mm, right? according to willitfit.com, 225's will be stretched on an 8.5" wheel, i generally prefer a flat or slight bulge in the sidewall, so i'd prefer to run a 235-245.
is it better to stretch 225's or is it easy enough to fabricobble everything that 235-245's would fit without rubbing issues?
Old 04-19-2019, 10:09 PM   #2
soundman98
soundman98's Avatar
i was looking at that. that still won't tell me if the fronts will rub the wheel wells while turning.
Old 04-20-2019, 01:59 AM   #3
Grey86
Grey86's Avatar
Drives: Tornato grey 86
Are you running coilovers ?
With stock suspension it loos like you will just clear (2mm from spring) with the 8.5 44 offset and 225.
The only difference by running a 234/245 is the speed difference. 225 will be the closest to stock speed.
IMO i would run a 8.5 with 42 or less offset OR a 8 with a 40 offset. Just knowing im not going to run into any issues with stock suspension.
hope this helps.
Grey86 is offline   Reply With Quote
The Following User Says Thank You to Grey86 For This Useful Post:
soundman98 (04-20-2019)
Old 04-20-2019, 12:19 PM   #4
Vital
Drives: 2015 BRZ
It will depend on how you plan on lowering, springs or coils? This thread should help you out. It seems some of these guys were able to fit 235-245 on stock suspension though. If you go coils you should have any issues, but if you go springs you may need 3-5mm spacer with the bigger sizer tires.
http://www.ft86club.com/forums/showt...?t=8636&page=6
The Following User Says Thank You to Vital For This Useful Post:
Old 04-20-2019, 08:12 PM   #5
soundman98
soundman98's Avatar
that thread helps a lot!
by coils, you mean coilovers? i am planning on fortune auto's 510 series coilovers. springs just feel like a whole lot of work for minimal benefit.
Old 04-21-2019, 01:12 AM   #6
Tristor
Tristor's Avatar
I'm running 225/40R18 tires on 18x8.5 +44 ET wheels right now, it works perfectly fine without any rubbing on stock suspension. If you lower the car 1" (which is where I'm at right now) on coilovers, you will need spacers front and rear to get a flush fit. I have -3.2F/-2.2R and I need 18mm spacers for both, but am running 15mm right now and it's close enough to flush for me. To run the spacers you will need extended studs, so have fun in the rear
If you know you'll be lowering straight out, you should figure out your likely camber settings and get wheels with the correct offset to get within 5mm of being flush that way you can change camber somewhat and run normal spacers on extended studs, if you go too nuts to get your wheels to be flush you'll end up needing bolt on spacers.
Also, do yourself a favor and don't buy Rotas.
If you run a reasonable offset its completely unnecessary to be on 18s to fit a BBK.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
soundman98 (04-21-2019)
Old 04-21-2019, 05:29 PM   #7
soundman98
soundman98's Avatar
to clarify, the main issue with going wider than 225 is tire-to-spring clearance, right? there's enough wheel well clearance elsewhere that even massive 245/255's would fit fine regarding only the wheel well, right?
ideally, i wanted to be running an 18x8, but i'm being picky about wheel selection, and none of them come smaller than 8.5. my 2nd choice is the titan 7t-s5, which really only comes in 18x9.5, which creates even more problems.
are rota's too soft? i've read a little about it, but i'm willing to heed the warning. thanks.
the reason i'm looking at 18's is because the baer bbk that i'm looking to run specifies that 18's must be ran for clearance. flush really isn't a concern, as long as i'm close. the main concern is clearing the calipers.
http://baer.com/14-Front-Pro-Brake-System-4011000.html
Tire Sizing Questions (Total noob looking for winter tires) AzureShadow Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-11-2015 12:24 PM
Tire size question on 18 x 9.5 all around wheels. 8six_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-24-2015 10:09 PM
RTR tire sizing SVThis Tracking / Autocross / HPDE / Drifting 10 02-19-2013 08:10 PM
Wheel Guys Chime In! Need advice on tire sizing Pure Automotive Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-17-2013 01:21 AM
Plus 0 tire sizing Brzer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-30-2012 08:15 PM
