Old 04-19-2019, 01:21 PM   #29
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Originally Posted by tomm.brz View Post
more than highest HP, i would say ACE is best for torque gains under tge curve, and good gains on top end. if i m not wrong jackson racing is a centrifugal sc, so you really want to gain more under the curve
also don't go UEL for forced induction, i have it and i'm down more than 20hp on higher rpm compared to a friend with identical setup as mine (hks v2) with a EL catless header
Exact same setup ? Same tune, same boost, same over/front/catback/intake? Same dyno?
It would be good to know the true hp difference. If it really is 20hp, then the price, while high would be worth it to a good amount of people willing to spend the money. But if it's 5hp or something low like that, then the $700 price difference really is not worth it unless you got a good deal on a used one.
jw because I have a JDL UEL right now and considering JRSC in the near future.
*Edit - sorry i just realized you just said EL vs UEL, not necessarily ACE giving the 20hp difference
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 04-19-2019, 01:26 PM   #30
CSG Mike
CSG Mike's Avatar
The difference becomes more pronounced as you go to the HBP, where flow becomes an issue; the Ace simply allows more timing to be added without knocking, unlocking more power.
AUC gains are extra icing on the cake.
Old 04-19-2019, 01:38 PM   #31
tomm.brz
Drives: brz 2017 hksv2
Yes, as said i have UEL, but they are the worst UEL for power (hks boxer spec) and my friend exact same setup but less boost than me, makes 20hp more than me with skunk2 alpha serie EL header
anyway now i m waiting for Ace 350 to be shipped from Taiwan
Old 04-19-2019, 06:18 PM   #32
gtengr
Drives: 2017 BRZ
I haven't experienced it myself, but the previous owner of my Cosworth w/HBP ran a Tomei UEL and I run the Ace CS400, and he said the same thing after driving it with the Ace. Not necessarily 20 hp, just that it pulled noticeably harder up top.
gtengr is offline   Reply With Quote
Old 04-19-2019, 06:20 PM   #33
tomm.brz
tomei uel are good, so maybe yes, not 20hp... also cosworth kit is positive displacement, you get more of a difference uel vs el with a centrifugal kit up top... extreme difference really up top
Old 04-20-2019, 03:24 PM   #34
J1Avs
Drives: 2018 BRZ tS
I currently run a JDL Catted UEL (with a gutted cat...long story), but will eventually be swapping it out for the PTuning Race Header (an EL). It will be interesting to see the power differences between the two, but I will say, I get a TON of compliments on the tone of my exhaust with it’s current setup (JDL UEL, JDL UQFP (now castless...long story), and Perrin 2.5” CBE) — and its typically preempted with someone saying they HATE the sound of most twins.
J1Avs is offline   Reply With Quote
JRSC vs HKS v3 SC Bekker Forced Induction 16 04-01-2020 05:25 PM
JRSC C38 with an RS Pulley majixmatrix Forced Induction 62 03-10-2020 08:42 AM
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2017 11:39 PM
FS (NY): JRSC C30 + Bilstein B16 + P&L EL Header/op/fp dp1 NY / NJ / CT / PA 6 04-30-2016 07:27 PM
JRSC oil use xsnapshot Forced Induction 3 03-27-2016 10:22 PM
