Old 04-14-2019, 10:44 AM   #1
the_ging
Drives: 2017 860
Best header for JRSC?
Trying to source all my parts for the grand install and was wondering if people have any experience with different headers? Function > Form
- 2018 Toyota Prius I
- 2017 Subaru WRX Sti
- 2017 GT86 860
- 1995 Honda Civic Si w/ B18C Turbo 300 whp
the_ging is offline   Reply With Quote
Old 04-14-2019, 10:54 AM   #2
HachiRokuX
Drives: 2017 Toyota 86
It’s probably the Ace A350.
HachiRokuX is offline   Reply With Quote
Old 04-14-2019, 11:19 AM   #3
86TOYO2k17
Drives: 2017 toyota 86
Ace is the best.
Many people will say get a tomei or invidia or maybe even a jdl because of cost and bang for buck.
But the ace is the all around best in performance.
Old 04-14-2019, 12:57 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Ace definitely seems like the make for highest HP. Best could mean a few different things for headers though. JDL makes great headers, I'd be sure to get some headers that come with ceramic coating to insulate heat in the headers for efficient evacuation. You also need to decide if you want UEL or EL. I'd stick with EL for pure function.
DarkPira7e is online now   Reply With Quote
Old 04-14-2019, 06:58 PM   #5
Joveen
Joveen's Avatar
Drives: Bone stock
JDL UEL performs like a EL header according to most people.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 04-14-2019, 08:23 PM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
My thoughts are that there are limits to NA power, which dictate the size of the exhaust. Typically, if you go too big then all you get is top end and too small and all you get is low end. A properly sized diameter and runner length 4-2-1 header seems to allow for the best NA gains, but does that mean it'll have the best gains for forced induction? Not necessarily, especially if there is significant increase in power.
Many people say for turbos that no exhaust, or the bigger the better, is the way to go because there is no sense in limiting the exhaust flow, as the turbo is flow dependent. A supercharger is not dependent on the exhaust to generate boost, so this idea of bigger is better just doesn't hold water with superchargers, as long as the exhaust is not the bottleneck to engine output.
With a roots supercharger like my Harrop SC, the power delivery is linear, meaning it build boosts linearly with rpm. The JRSC, like other superchargers, build boost exponentially (X^2) with boost, which is why they have late power gains, but really big gains when that power finally comes on.
So it begs the question, what would be the best header? Well, if the goal is to not limit the flow then the header should be large to support top end power, which is where the JRSC has most of its flow. If the goal is to try and flatten the torque curve a little then the header could be designed for low end power, but then it may be restrictive to those high rpm gains, which is kind of what the JRSC is all about.
Old 04-15-2019, 02:03 AM   #7
tomm.brz
Drives: brz 2017 hksv2
more than highest HP, i would say ACE is best for torque gains under tge curve, and good gains on top end. if i m not wrong jackson racing is a centrifugal sc, so you really want to gain more under the curve
also don't go UEL for forced induction, i have it and i'm down more than 20hp on higher rpm compared to a friend with identical setup as mine (hks v2) with a EL catless header
The Following User Says Thank You to tomm.brz For This Useful Post:
DarkPira7e (04-15-2019)
Old 04-15-2019, 09:22 AM   #8
DarkPira7e
DarkPira7e's Avatar
I agree 100% with what you've said, I'm going EL as well for my FI setup. They may be trying to have their car embrace the boxer rumble more and be willing to sacrifice overall performance for it, which is as long as they know what they want. At least a header can be changed out relatively easy.
Old 04-15-2019, 09:23 AM   #9
Joveen
Joveen's Avatar
Drives: Bone stock
Performance is not being sacrificed.
Old 04-15-2019, 10:33 AM   #10
tomm.brz
Cosworth says that just a more free catback net more than 10whp on FI cars, do you think UEL can go the same as EL on higher rpm with a centrifugal supercharger?
i understand JDL makes UEL with quite big primaries but they sure can't go the same as EL, since uel are more inefficient per nature.. talking about pump gas of course, not E85
Old 04-15-2019, 12:31 PM   #11
HaXx
Drives: jrsc_brz
How much power at 3k and at redline is a header realistically going to yield? Get the s/c on, that's the important thing. I would only go changing heads, over/front pipe for noise and flames. I'm on jrsc and catback. Stock head. Already pushing luck with neighbors lol. I have a fetish for subie rumble for uel all the way.
HaXx is offline   Reply With Quote
Old 04-15-2019, 01:14 PM   #12
Ace is king.
Old 04-15-2019, 01:14 PM   #13
A good header is additive or multiplicative with a supercharger!
HaXx (04-15-2019), tomm.brz (04-15-2019)
Old 04-15-2019, 01:48 PM   #14
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
I'll be running my A350 with the JRSC!
mistople is offline   Reply With Quote
The Following User Says Thank You to mistople For This Useful Post:
HaXx (04-15-2019)
JRSC vs HKS v3 SC Bekker Forced Induction 16 04-01-2020 05:25 PM
JRSC C38 with an RS Pulley majixmatrix Forced Induction 62 03-10-2020 08:42 AM
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2017 11:39 PM
FS (NY): JRSC C30 + Bilstein B16 + P&L EL Header/op/fp dp1 NY / NJ / CT / PA 6 04-30-2016 07:27 PM
JRSC oil use xsnapshot Forced Induction 3 03-27-2016 10:22 PM
