#15 |
Benz Tech
Drives: 2017 BRZ Premium
Unless they did a few smoky donuts in the back lot.
I'll be picking up a Rexing V1 before my car ever goes to the dealer. Hard wired so it can't "accidentally" be unplugged. |
#16 | |
Drives: 2016 Subaru BRZ
So next is the throw-out bearing, but there no clutch noise or squeaking; and would the TOB effect shifting to this degree? |
#17 | |
Senior gif poster
Drives: 2013 Asphalt FRS
In my experience this doesn't sound like the TOB but rather a clutch adjustment issue, however if your going to have someone get at the transmission might be worth it to consider getting a new clutch kit and TOB. OP do you think you can get a video with sound to help us get a better idea of the notchy feel? |
#18 |
Benz Tech
Two components of the throw out bearing. The bearing itself, the top of the circle that spins on the pressure plate. That is what usually wears and gives the rough grinding noise when the clutch is applied.
The whole TOB assembly rides along the quill, the tube that covers the transmission input shaft. No bearing or anything there, just a very loose metal to metal slide. Enough dust and gunk in there and the assembly will bind on the quill. Could also be a bent or breaking clutch fork, the TOB would be unable to press far enough to fully disengage the clutch. Or a seriously worn pivot? There's a lot of options to figure out blind. Sadly, a lot of possible issues are going to be in the bellhousing. Might want to take a quick look around under the hood, inside if you have a borescope/endoscope laying around. |
| The Following 3 Users Say Thank You to maslin For This Useful Post: |
#19 | |
Can you tell when the transmission is spinning in neutral and when it's not? I can clearly tell when mine stops, especially in the morning.
#20 | |
Video of @Ultramaroon I'm not sure about the feeling you're describing (or just something I haven't paid attention to). Could you clarify? |
| The Following User Says Thank You to Mrone For This Useful Post: | DandoX (04-19-2019) |
#21 | |
Senior gif poster
To my ear it really sounds like the clutch isn't fully engaging. If it was the tob you would hear a sound when the car is on and you depress the clutch, like a subtle squeal sounds and it would go away and come back as the temp changes. I hope you get this sorted, worst is you probably need a new clutch kit. Hopefully all it needs is to be re adjusted though. |
#22 |
Some transmissions make more noise than others. People also have different levels of sensitivity to sounds. I'm trying to feel out the best simple way to help you identify when/if your clutch is fully disengaged. It can be tricky.
As I'm sure you know, it takes very little torque to spin the front side of a transmission while it's in neutral. The way a syncro works for engagement, not only must the two mating sides be at rest (not spinning) relative to each other, there must also be no torque, or at least very little. It takes very little torque to lock a transmission out of gear. Even if you manage to force the input side to quit spinning by using the syncro as a brake against the dragging clutch, it still won't engage. If none of this makes sense, or the picture is fuzzy, don't be embarrassed. Let me know. We can go back and clarify more. Otherwise, I'll proceed. There are a few different ways to get a feel for the existence, or absence of clutch drag.
#23 |
I see nothing odd in that video. Sounds/looks normal.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | HKz (04-19-2019) |
#24 |
I looked up a post about clutch adjustment and just got finished doing it. I lowered the clutch pedal to match the brake, but the problem is still there; and the pedal itself feels a bit more squishy than before.
@Ultramaroon I would say the picture is fuzzy. I think I understand what you're describing, but I have not heard or felt anything like that before. Not consciously at least. I also have a loud-ish exhaust that may suppress any subtleties of the transmission. I will take her around the block to see if I can notice it. |
#25 | |
OTOH, if you can get it in gear after lowering the pedal, there was nothing wrong with the clutch in the first place.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | maslin (04-19-2019) |
#26 |
Maybe there is something loose or binding in the shift linkage -
![]() humfrz |
#27 |
*Update*
Took the car to the dealership -- long story but I wont get into it here -- and they were able to replicate the lockout the 1st and 4th gears. Apparently it was the synchros. They replaced the transmission under warranty. The gearbox still feels bumpy though. The closest example would be if you slide a pen horizontally over (or between) keys on a keyboard. Feels like it's hitting something. The mechanic said "that's just how they are." I tested another BRZ gearbox and it did feel similar. But if that's the case then I don't know why mine felt so smooth before I took it to the dealership [side note: I found out they changed the transmission oil during their "warranty inspection"]. I suppose it's just something I have to get used to now. At least the lockout problems are gone. I appreciate everyone's input and trying to help me solve the problem. You guys are awesome! TL;DR: Snychros bad. Got new transmission; no more lockout. Bumpy gearbox is "normal", so I'll stop whining. |
| The Following 4 Users Say Thank You to Mrone For This Useful Post: |
| Tags |
| clutch, gearbox, notchy shift, rough shift, transmission |
| AT Hard Shifting issues Poll | FRSBRZGT86FAN | Issues | Warranty | Recalls / TSB | 268 | 02-27-2023 07:58 AM |
| Issues Shifting Into Gear From Stop | bryan86tx | Issues | Warranty | Recalls / TSB | 12 | 02-27-2019 02:26 AM |
| AT transmission hard shifting issues | calic | Issues | Warranty | Recalls / TSB | 44 | 11-09-2015 06:17 PM |
| Notchy Shifting | Decisis | Engine, Exhaust, Transmission | 20 | 02-07-2014 04:36 AM |
| I may have solved my shifting issues.. | retrosmiths | Engine, Exhaust, Transmission | 13 | 05-21-2013 11:03 AM |
