Old 04-17-2019, 04:02 PM   #29
srscion
srscion's Avatar
Drives: 2016 FRS
Is it a secret?
There is a lot to thinking about, not just tob engagement and pilot bearing contact but also starter contact.
srscion is offline   Reply With Quote
Old 04-17-2019, 04:37 PM   #30
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Right, so did you machine a spacer for behind the flywheel to push it forward the same thickness as the adapter and just use longer flywheel bolts?
I feel like you are being vague for a reason. Any reason not to spell it out? Judgement? Trying to create a product to sell and don't want to give away your secretes? Kinda confusing.
Old 04-17-2019, 05:13 PM   #31
srscion
srscion's Avatar
Drives: 2016 FRS
This particular engine that I used does not have a bell housing like the fa20 does so the adapter plate doubles as a bell housing. and offsets things so the starter makes proper contact. The clutch assembly is recessed in the fa20 but in the 2az its protruded.
Old 04-17-2019, 05:14 PM   #32
srscion
srscion's Avatar
Drives: 2016 FRS
I reused all the oem hardware to bolt things up
Old 04-17-2019, 07:54 PM   #33
Irace86.2.0
I see. So the adapter was conveniently a necessary spacer.
Old 04-18-2019, 10:06 AM   #34
srscion
srscion's Avatar
Drives: 2016 FRS
Yes
Old 04-18-2019, 11:35 AM   #35
frsty_86
frsty_86's Avatar
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
Excited to see how your hood will tie everything together.
frsty_86 is offline   Reply With Quote
Old 04-18-2019, 11:43 AM   #36
srscion
srscion's Avatar
Drives: 2016 FRS
Here is a teaser of what it will end up looking like
The Following 4 Users Say Thank You to srscion For This Useful Post:
alphasaur (05-29-2019), frsty_86 (04-19-2019), Irace86.2.0 (04-18-2019), Shark_Bait88 (04-18-2019)
Old 04-18-2019, 03:25 PM   #37
Irace86.2.0
Someone has some photoshop skills. The engine bay pic was well done too. Nice execution on the hood.
Old 04-18-2019, 03:34 PM   #38
srscion
srscion's Avatar
Drives: 2016 FRS
Thank you
Old 04-18-2019, 05:16 PM   #39
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
would you consider redoing the swap with the engine/transmission moved closer to the firewall to avoid the protrusion? maybe use a different transmission?
glorydays is offline   Reply With Quote
Old 04-18-2019, 07:00 PM   #40
Irace86.2.0
I don’t think a different transmission is necessary unless the torque limit on the transmission was challenged. The transmission can get moved back, but then it is necessary to make custom transmission mounts, custom driveshaft, custom shifter linkage and obviously redo the engine mounts, while possibly needing to do a custom oil pan to clear the front sway bar and/or steering rack. At that point might as well upgrade transmissions, but then he would need a new adapter/bell housing, new clutch, possibly a hydraulic TOB, maybe a custom flywheel, etc. It seems like his goal was a budget build, which negates a lot of this.
Old 04-20-2019, 10:30 PM   #41
srscion
srscion's Avatar
Drives: 2016 FRS
No, the modification to the body would be costly, new mounting points would have to get fabricated for a different transmission, a different drive shaft would be needed, the sub-frame would have to get cut. I don't want to ever go down that road.
Old 04-20-2019, 10:32 PM   #42
srscion
srscion's Avatar
Drives: 2016 FRS
You're right, I wanted to keep the cost down as much as possible and minimize back end troubleshooting for when things don't work. Luckily I did not have many issues.
Toyota Aristo Engine Harness Conversion to USDM Supra TT to Swap into FRS ThePurist Engine Swaps 0 11-23-2017 08:13 PM
Toyota left a nice surprise if you're doing a Toyota motor swap.. Manji Engine Swaps 15 01-07-2015 01:48 AM
Engine swap JDM EJ25 STI engine FRSToyota86 Engine Swaps 25 11-20-2013 01:56 AM
Engine Swap hybrid35 Southern California 0 01-07-2013 01:04 PM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
