| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Thread Lurker
Drives: 2015 Edelbrock BRZ
Coil Pack upgrade 2015 BRZ
Been having this issue where the car starts up great and drives perfect but when I get into stop and go traffic, idle to long in a parking lot, or sit at a long red light the car will either rough idle or shut off. Car is able to be turned on right after and driven. I've read up on a lot of different causes but I found one recently that all leads to my coil packs needing replaced. I've done a handful of things to help fix the issue ill list them below as well as my mods list. Car has 55k miles
Things ive done to help issue: Spark plug change Cleaned MAF Cleaned throttle body will be changing oiled soon I'm at 5k miles on this oil Mods List: Edelbrock SC 700cc DW injectors 300c DW fuel pump Grams 72mm TB VP UEL headers Ultimate Racing over pipe Ultimate racing Mid pipe Invidia N1 CatBack Perrin LW pulley set Delicious Tune by William Knose I basically want some input on good coil packs to buy or any other possible reasons my car dies when it gets hot. THANK YOU! |
#2 | |
Also don't the 2015s+ have much better coil packs? I seem to remember my coil packs not only looking different but there wiring harnesses are different compared to the 2014 my friend owns.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | NoHaveMSG (04-14-2019) |
#3 |
Drives: Crapcan
15' and up has the updated coil packs. Doesn't rule out a bad coil but they typically throw a code.
| Coil pack options | ROADRACER | Engine, Exhaust, Transmission | 14 | 12-24-2018 03:33 AM |
| Coil ignition pack | D86Ellis | Issues | Warranty | Recalls / TSB | 7 | 09-20-2016 03:01 AM |
| Is $460 too much for 1 oem coil pack & spark plugs from mechanic? | spatcha88 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 24 | 03-21-2015 01:08 PM |
| ignition coil pack #2 and #3, dealer won't cover | vestal52 | Issues | Warranty | Recalls / TSB | 28 | 10-17-2014 12:24 AM |
| Coil pack part numbers? | feldy | Engine, Exhaust, Transmission | 6 | 03-11-2014 12:31 PM |
