Old 04-10-2019, 04:40 PM   #1
Mad-BRZ
Thread Lurker
Drives: 2015 Edelbrock BRZ
Coil Pack upgrade 2015 BRZ
Been having this issue where the car starts up great and drives perfect but when I get into stop and go traffic, idle to long in a parking lot, or sit at a long red light the car will either rough idle or shut off. Car is able to be turned on right after and driven. I've read up on a lot of different causes but I found one recently that all leads to my coil packs needing replaced. I've done a handful of things to help fix the issue ill list them below as well as my mods list. Car has 55k miles
Things ive done to help issue:
Spark plug change
Cleaned MAF
Cleaned throttle body
will be changing oiled soon I'm at 5k miles on this oil
Mods List:
Edelbrock SC
700cc DW injectors
300c DW fuel pump
Grams 72mm TB
VP UEL headers
Ultimate Racing over pipe
Ultimate racing Mid pipe
Invidia N1 CatBack
Perrin LW pulley set
Delicious Tune by William Knose
I basically want some input on good coil packs to buy or any other possible reasons my car dies when it gets hot. THANK YOU!
Mad-BRZ is offline   Reply With Quote
Old 04-13-2019, 11:03 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Spark plug change
Cleaned MAF
Mods List:
Edelbrock SC
700cc DW injectors
300c DW fuel pump
Grams 72mm TB
VP UEL headers
Invidia N1 CatBack
Have you datalogged to try and catch the issues?
Also don't the 2015s+ have much better coil packs? I seem to remember my coil packs not only looking different but there wiring harnesses are different compared to the 2014 my friend owns.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
NoHaveMSG (04-14-2019)
Old 04-14-2019, 12:53 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
15' and up has the updated coil packs. Doesn't rule out a bad coil but they typically throw a code.
Coil pack options ROADRACER Engine, Exhaust, Transmission 14 12-24-2018 03:33 AM
Coil ignition pack D86Ellis Issues | Warranty | Recalls / TSB 7 09-20-2016 03:01 AM
Is $460 too much for 1 oem coil pack & spark plugs from mechanic? spatcha88 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 03-21-2015 01:08 PM
ignition coil pack #2 and #3, dealer won't cover vestal52 Issues | Warranty | Recalls / TSB 28 10-17-2014 12:24 AM
Coil pack part numbers? feldy Engine, Exhaust, Transmission 6 03-11-2014 12:31 PM
