Old 04-13-2019, 02:22 PM   #15
Originally Posted by extrashaky View Post
If he has a hammer, he can make a gasket.
"But what can I do if it's not cut already and I don't have my purse handy to hit it with?!!?!"
Old school. Dad taught me that trick when I was maybe 10. Works great. Don't even need a hammer. Can just pick up a stone.
Old 04-13-2019, 02:28 PM   #16
extrashaky
Drives: 2014 BRZ Limited
I'm on numerous AMC and Jeep Facebook groups, and it's always funny to me when people get all bent out of shape and panic because the pre-cut gaskets they buy don't line up properly to their 30 or 40 year old parts. It's such a simple thing just to keep some gasket paper on hand and go for the hammer. It's too simple for people to believe it until they see it.
Since this thread was pretty basic to begin with and was thoroughly answered in the first response, let's change the subject. Here's how you use a hammer at the other end of the gasket's life:
[ame]https://www.youtube.com/watch?v=2VC8ldesvrY[/ame]
Old 04-13-2019, 02:43 PM   #17
I have always had gasket paper at the ready. It's up there with the proverbial duct tape and baling wire. These are excellent hacks to share.
Old 04-13-2019, 03:01 PM   #18
extrashaky
Maybe this should now be an old school hacks thread. Here's how to use a candle to unstick bolts:
[ame]https://www.youtube.com/watch?v=7qqMXXGgFQg[/ame]
Old 04-13-2019, 03:45 PM   #19
hmmmm - I haven't tried the wax trick, but I'm thinking that the heat is the trick part -
Old 04-13-2019, 04:18 PM   #20
"Five minutes of waxing and it comes right out."
Old 04-13-2019, 04:23 PM   #21
I've never had luck with propane or MAPP, only acetylene, so I'm inclined to buy in on the wax bit.
Old 04-13-2019, 04:42 PM   #22
Maybe you needed a bigger blow torch and a BFH -
Old 04-13-2019, 08:17 PM   #23
Wax Guy didn't.
Old 04-13-2019, 09:25 PM   #24
Since much of my early life was spent driving really old or odball cars i learned how to make gaskets at am early age. Have probably made hundreds. I used a piece of soft pine 2 X 4 between the hammer and the part though. Gave a nicer edge.
Old 04-15-2019, 02:11 PM   #25
Chamaco
Drives: Silver FR-S
Originally Posted by jsimon7777 View Post
Ace.
Word!
Chamaco is offline   Reply With Quote
Old 04-19-2019, 05:16 AM   #26
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by BigTuna View Post
There are 3 gaskets on a header. 2 that go to the heads, and one that connects to the overpipe. If they didn't replace any, then you may want to do all 3.
Using any special tool to tighten that one hard to get bolt on the head?
Carlitoz3 is offline   Reply With Quote
Old 04-19-2019, 07:50 AM   #27
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
The stock ones are pretty easy with a socket extension. aftermarket ones can be trickier sometimes.
BigTuna is offline   Reply With Quote
Driver side valve cover gasket leak solidONE Issues | Warranty | Recalls / TSB 59 02-22-2021 12:52 AM
Head Gasket Oil Leak - this is what one might look like exE36M3 Issues | Warranty | Recalls / TSB 36 02-14-2021 01:27 AM
Finally fixed the oil leak - Warning for those still using OEM drain plug/gasket. lupindub Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 02-25-2016 07:47 PM
Overpipe gasket exhaust leak THEWAKLER Engine, Exhaust, Transmission 19 11-29-2015 01:38 AM
Head Gasket leak? Carlsson Issues | Warranty | Recalls / TSB 8 10-23-2015 12:49 AM
