Old 04-02-2019, 11:49 AM   #589
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by NOHOME View Post
Dealer keeps calling. I keep putting it off.
Curious what has better odds of failing the recall or the fix?
My same concerns I voiced earlier, almost verbatim. It almost seems there is a greater chance of the dealership fucking up your motor due to shoddy work than there is of the spring actually breaking. Or, close enough. Either way, not a compelling track record to get me into the shop to have this done.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 04-03-2019, 07:31 AM   #590
booher
Drives: raven frs
Holy cow, there are so many more bad "jobs"now! Its been a while since I checked back sorry. The mechanic performed the repair, and I recieved the car 2 days later. It has been maybe 3 weeks now, maybe 500 miles, and so far, all seems well. Dealership is named anderson Toyota in lake havasu az, if anyone cares. Also, full bolt on, with tune and all, and they worked with it, and put it all back on for me.
booher is offline   Reply With Quote
Old 04-03-2019, 07:41 PM   #591
Invisionthis
Drives: 2013 Silver FR-S
Little update regarding mine, I okay'd the new (Used) engine, for $5000, dealership then called me back the next day, and said the used engine was on backorder and they couldn't get it for 3 weeks ( I wonder why?? ), and then she told me that they could drop the engine rebuild from $7500 down to $5300, which I then okay'd. Last tuesday, I went into the shop on monday to check on it as they told me early next week, and my engine was still in once piece, which makes me think they didn't even take it apart when the GM "Came" in the first place. Went back yesterday, and everything was taken apart, and the rep told me I'd have it by thursday! So fingers crossed, still looking into the legal side of things.
Invisionthis is offline   Reply With Quote
Old 04-03-2019, 08:55 PM   #592
Effy
Drives: 2012 ds4 86
I just got my car back from the dealership last night drove it home and the idle bounces around from 500rpm then jumps back to 1k then sits around 700rpm till it loses the revs again and bounces back to 1000rpm should i be worried? is this abit of a sign of things to come or just a crappy tune?
Effy is offline   Reply With Quote
Old 04-03-2019, 09:41 PM   #593
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Well, I went in for the odd sound off throttle at 3000rpm. They did a bunch of listening and found a crack on my aftermarket header that I'd asked them to swap out during the original work but they hadn't done. Anyway, the car is great now, with no weird noises. Purrs like a kitten. Also no oil leaks anymore thanks to their work. So I'm happy. One Toyota of Oakland. The best service adviser ever is there, Chase. Super happy to work and stick with him.
Old 04-03-2019, 09:43 PM   #594
Welcome to the group, there, Effy -
Your car (ECU) may just be relearning stuff after it was cut off from power.
I'd give it some time and miles to settle down.
Old 04-03-2019, 09:53 PM   #595
Effy
Drives: 2012 ds4 86
Thanks so much puts my mind at ease alittle bit after all of these problems with the recall, hoping to go FI after im sure my car is settled after the valve spring replacement
Old 04-04-2019, 07:21 AM   #596
WNDSRFR
Drives: FR-S,GTI
I've gone over 1500 miles since the recall and my car is still doing this. At first I thought maybe I was being hyper sensitive to every sound the car makes. But it is still doing it for sure. Sometimes the idle dips so low I think the car is going to stall.
Old 04-04-2019, 07:34 AM   #597
No CEL?
Old 04-04-2019, 07:39 AM   #598
oaroyale
Drives: Black BRZ
My car has been doing this for 7 years. He's like a drunk, just as he's about to fall over, he shakes himself off and keeps on stumbling.
oaroyale is offline   Reply With Quote
Old 04-04-2019, 08:02 AM   #599
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Mine was doing this before I took it in for the recall. I think it's just the stock tune.
BigTuna is offline   Reply With Quote
Old 04-04-2019, 11:04 AM   #600
maslin
Benz Tech
Drives: 2017 BRZ Premium
New document posted to the list. I believe it's this one, although they are listed by suffix and the suffix does not seem to indicate anything chronologically. 7099 dated 3/27, 7136 dated 2/13
Nothing too damning, just another highlight on overuse of sealant. I don't know who these dealer letters go to specifically, most likely a different group than the technical instructions. The document says "To: All Toyota Dealer Principals, General Managers, Service Managers, and Parts Managers"
https://static.nhtsa.gov/odi/rcl/201...8V772-7099.pdf
maslin is offline   Reply With Quote
Old 04-04-2019, 12:54 PM   #601
tobin
tobin's Avatar
Drives: '13 BRZ
My car falls under this recall. With the track record of these engine failures after the J02 recall, I feel that it is safer to drive my car without doing the recall. Either way, the opportunity for catastrophic engine failure exists; potentially life-threatening if it were to happen in a bad location. I believe the potential for engine failure is diminished by avoiding the JO2 recall altogether.
SUBARU, how about giving us crate engines?
tobin is offline   Reply With Quote
Old 04-04-2019, 01:24 PM   #602
The odds of failure diminish as they update the instructions and the techs get more practice. Probably safe to have it done soon.
Sure, they are going to hand out 25,000 crate engines. Makes perfect business sense.
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
