Old 04-03-2019, 02:39 AM   #1
saikat.saha
Drives: Toyota Gt86 2012 orange
Boost Gauge reading low
Hi guys,
I am running 10psi on Greddy T518z according to my tumer report. But in boost Gauge it’s showing 5psi. 2 or 3 days ago it was okay. Suddenly it starts to showing 5psi constantly from 3k to 7k rpm. any suggestions?? Is it my map sensor is damaged or something else ( ** my tuning is going on still ) .
Thanks
Saikat
saikat.saha is offline   Reply With Quote
Old 04-03-2019, 05:52 AM   #2
steve99
Drives: FT86
Log manifold pressure direct with ecutek or oft.
See what that says
Should be 1 bar or 14 psi with ignition kn engine off
Should be 0.3 bar or about 4 psi engine idling
Note reading is absolute ir reliative to atmospheric presdure
Old 04-03-2019, 08:48 AM   #3
saikat.saha
Manifold pressure shows 1.7 bar with full throttle by ecutek datalog.
When ignition on and engine off it shows 1 bar.
When idle it shows.7 bar as turbo has factory spring .
I am using a ebc also
Thanks
Saikat
Old 04-03-2019, 07:48 PM   #4
steve99
Drives: FT86
Thanks
Saikat
If manifold presdure is ligging as 1.7 bar ful! Throttle thats 0.7 bar boost or about 10 psi.
So looks like boost guage faulty or if its got its own pressure sensor its faulty
Old 04-05-2019, 03:38 AM   #5
saikat.saha
Thanks .
You are right. It was a one way check valve problem in the boost gauge line. Thats why boost was leaking . Not it’s soleved .
Fuel Gauge - Incorrect Level Reading soulreapersteve Issues | Warranty | Recalls / TSB 0 08-31-2016 12:28 AM
Perrin Boost gauge reading inaccurate? oliverc Forced Induction 0 10-21-2015 12:26 AM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 02:27 PM
Fuel gauge not reading properly FR-S Hot Lava Issues | Warranty | Recalls / TSB 27 10-29-2014 11:33 AM
Boost gauge not reading correctly Pneub Forced Induction 11 10-30-2013 01:39 PM
