Old 03-27-2019, 06:59 AM   #1
5150
5150's Avatar
Drives: 2017 86
Car is running too cool, safe or not safe?
I currently have Mishimoto thermostat which opens up at 76 Celsius. I noticed that whenever I drive early in the morning or at night in the freeway which is much cooler than during the day, the check engine light would pop out (P0128) coolant temperature is below thermostat threshold. My coolant temperature was hovering around 70 to 72 Celsius when the check engine light appeared after 7+ miles of driving in the freeway. When I driving normally in town, my coolant temperature would hover around 76 and my check engine light would never appear when I drive around the city. When ever I enter the freeway, it takes about 1 to 2 minutes for my coolant temperature to drop to 70-72 Celsius. My current cooling mods are mishimoto radiator, their slim fan shroud and jdl oil cooler kit in preparation that I am going to turbo charge the car in a couple months. I flushed out my coolant and checked the thermostat whether it was stuck open but nothing was wrong with it. I am wondering if it is best to just leave the thermostat on or switch back to oem thermostat. What do you guys think?
5150 is offline   Reply With Quote
Old 03-27-2019, 07:25 AM   #2
JIM THEO
Drives: BRZ 2018
So your car rarely works at CL state 2 and only at full throttle goes to 4.
This is one reason I choose Sard 82C thermostat that is only 6C below OEM plus that it's exactly same type/brand with the original thermostat, sorry but I don't trust Mishimoto.
Otherwise I think you won't have problems except increased fuel consumption while you can add some advance here and there, or at least this is my experience with my lower thermostat.
JIM THEO is offline   Reply With Quote
The Following 2 Users Say Thank You to JIM THEO For This Useful Post:
5150 (03-28-2019), Tristor (03-29-2019)
Old 03-27-2019, 08:13 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
In my opinion, second only to the hoses, your thermostat is the most important thing in the cooling system. It would be the last thing I changed. For whatever reason, non oem thermostats seem to cause issues on any brand/make of car. I definitely understand wanting to help temps before they're an issue, but leave the thermostat as a last resort
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
5150 (03-28-2019), Icecreamtruk (03-27-2019), Tcoat (03-27-2019), Tristor (03-29-2019)
Old 03-27-2019, 10:22 AM   #4
JIM THEO
Drives: BRZ 2018
In my case the thermostat I bought is same brand (https://www.ntcl.co.jp/en/), same series, same quality with the OEM and is used in other Subaru models so I don't think it will cause any troubles!
The Following User Says Thank You to JIM THEO For This Useful Post:
5150 (03-28-2019)
Old 03-27-2019, 10:23 AM   #5
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I had to replace my stock one I used stock again. I don’t think there’s a need to alter the temp
TommyW is offline   Reply With Quote
Old 03-27-2019, 10:40 AM   #6
Could just go old school like we had to do when the fan was driven by a belt and didn't have all the fancy dancy sensors and auto on/off!
86MLR (03-27-2019)
Old 03-27-2019, 10:52 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
But if there still IS fancy set of sensors & auto on/off stuff .. wouldn't it result in same temps, but simply longer or more frequent fan switch on cycles, due cooling off being slower due blocked rad area?
Old 03-27-2019, 05:25 PM   #8
JIM THEO
Drives: BRZ 2018
When you remap the car with the upgraded fan settings (lower start/stop points) actually the phenomenon you describe is much worse rather with the lower thermostat which mates better with the new limits, if you lower the fan limits you should also adopt thermostat limits which means a lower temp thermostat, am I wrong?
Old 03-29-2019, 09:24 AM   #9
chipmunk
Drives: _
https://mobile.twitter.com/caterhamf...45724907036673
chipmunk is offline   Reply With Quote
Old 03-29-2019, 11:25 AM   #10
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Go back to stock
Dr. BRZ is offline   Reply With Quote
Old 03-30-2019, 10:04 PM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
That as well as if the ac compressor comes on due to defrost or you decide to flip the a/c on you've blocked airflow to the condenser as well because the fan cycle times are adaptive to when the a/c is on.
The modern technique is to edit the fan cycles in romraider or tuning in the software of your choice, it even takes into account vehicle speed. I set mine to turn on slightly earlier and to vent the engine bay at a stop. Temps are still perfect in the winter and used waynos values:
http://www.ft86club.com/forums/showp...4&postcount=34
Although I have had issues in the past with aftermarket thermostats, I believe in your cases if you're tuning your cars you should look into editing your fan curves to get the balance you guys need:
Old 03-31-2019, 12:08 AM   #12
It was a joke. The whole reference to the fancy sensors and auto controls was the actual answer. Why shove things in the rad when you can totally control when the fans come on and off? Guess it was too indirect a reference.
Old 03-31-2019, 02:36 AM   #13
I'm ah feared you went too far back for some of the folks -
Old 03-31-2019, 03:18 AM   #14
JIM THEO
Drives: BRZ 2018
Although I have had issues in the past with aftermarket thermostats in the past, I believe in your cases if you're tuning your cars you should look into editing your fan curves to get the balance you guys need:
Exactly what I say but if you lower the fan tables where they start to work by 5C degrees it is better to change also thermostat open point by the same amount by changing it:
OEM thermostat opens at 88C, fully open at ~95C
OEM fan tables: 95C on - 91.5C off
In my case
NTC thermostat opens at 82C, fully open at ~89
NTC fan tables: 90C on - 87.5C off
In my case the lower thermostat helped me by reducing flkc as coolant lowers intake temperatures.
At least it kept me safe! Mailman1117 Scion FR-S / Toyota 86 GT86 General Forum 22 08-13-2016 07:59 PM
Be Safe ButeraFRS CANADA 37 10-12-2015 09:02 AM
SAFE?:running nokya yellow bulbs in factory foglight housing jbsali Cosmetic Modification (Interior/Exterior/Lighting) 12 07-13-2014 11:42 AM
Is this safe? Anomie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-25-2014 10:58 AM
Are these safe? mrlewistan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 03-22-2013 04:22 PM
