Old 03-12-2019, 09:58 AM   #15
ka-t_240
Originally Posted by Gopherboy6956 View Post
After doing some looking - I think i'll go Braille AGM - still much lighter than stock, but no potential Lithium issues and I don't have to get a different trickle charger for winter.
Plus, around $200 still isn't bad.
https://www.braillebattery.com/index...atteries/b2618
Just make sure you disconnect over the winter if not leaving on a charger. It will help keep it happy. My battery is smaller, but still leave it on a charger most of the time.
ka-t_240 is offline   Reply With Quote
Old 03-12-2019, 11:44 AM   #16
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
For sure - even my basically dead ass one is on a trickle right now
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 03-12-2019, 01:31 PM   #17
bee-jay
bee-jay's Avatar
Drives: 2014 BRZ LTD WR Blue Pearl
Went to hang the charger on last night for a top off charge, only to find battery is completely dead. Not even a dome light. So....
It was a choice between the Optima and Deka AGM. I've had good luck with the Optima in my Tundra. Got 7 years out of the first one.
Decided on the Deka intimidator AGM since we buy boat loads of batteries from Deka here at work and I can get a decent price.
Hope it works out ok and holds up as well as the Optima.
The batteries in these cars sure go dead fast when sitting.
bee-jay is offline   Reply With Quote
Old 03-12-2019, 02:19 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Optima moved their production facilities a while ago and started using recycled lead in their batteries almost 10 years ago. I got only a couple years out if the last two yellow tops on my truck, dead cell every time. I would pass on them. I been a big fan of Odessey and Northstar the last few years.
Sent from my Moto E (4) Plus using Tapatalk
Old 03-12-2019, 08:42 PM   #19
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I know you already picked up a battery, but Odyssey batteries get my vote... made mistake getting Shorai before it and ended up being a dead $300+ paperweight from daily driving within a few months. Voltage is critical on the lithium batteries and you can't let them get below 13.7 volts if you value your battery... so you have to watch your voltage like a hawk and have them constantly on a charger. If you start your car a few times within a short time/travel distance and no charging in-between would not recommend using for a daily driver. Would only use for coming and going to work and not running ANY short errands while at work. Charging while at work would be highly recommended if need to use the car for errands during the workday.
The Nissan dealership 'killed' the less than 1 year old Odyssey battery in my Frontier which they had for 3 months waiting on a replacement part for failed brake system because apparently they don't disconnect the battery and used it without recharging, first and last time I ever take a vehicle to them. They drained it down to ~3 volts then had the nerve to say I needed a new battery for $130. Told them I didn't want their junk OEM battery. OEM battery is why I bought the Odyssey when I got the truck in the first place - crazy ammount of corrosion on the main cable, connections, and battery bracket from it offgassing.
Contacted Battery Mart, where I purchase batteries from, and asked them to do the Odyssey recovery procedure, which they agreed to though saying no garantee since it was way outside the warranty drain specification, and that return shipping would be on me if it was a dead battery. So I shipped off the battery to them and they performed the recovery procedure, brought the battery back to life, and stress tested it with very healthy results.
Battery functions as new with no noticeable change in its performance. I'm sure some life was taken off it due to the Nissan dealerships negligence, but as long as I get useful service out of it for ~ 5 years it will be well worth it. I bought the when it was on sale and with an additional %15 off... so it was ~$80 less than normal price...normally ~$280, got it for just under $200. Odyssey batteries will last a good 7+ years of extreme use though, and are rated at up to 10 years useful life... and have a 5 year warranty.
I use the PC680MJ in my FR-S... metal jacket because higher heat rating and about 1/2 the weight of stock battery.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 2 Users Say Thank You to Vracer111 For This Useful Post:
NoHaveMSG (03-12-2019), why? (03-13-2019)
Old 03-12-2019, 09:06 PM   #20
conehead
Drives: RS 2.0
Another vote for Odessey. Optima sold out and is junk now. Braille are super light, but my friends that use them on track cars get less than a year out of them and treat them like disposables.
conehead is offline   Reply With Quote
Old 03-13-2019, 07:30 AM   #21
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Any of these super lightweight batteries need to be on chargers as much as possible. And frankly if you sit them at work you should detach them so the don't drain. I'm surprised there isn't a prevalence of solar powered chargers for them, that you they can always be charging when the car is off.
why? is offline   Reply With Quote
Old 03-13-2019, 11:24 AM   #22
new2subaru
Weight Weenie
Drives: 15 FR-S
Good point. I wonder if anyone has gone this route. I may try it.
Old 03-13-2019, 01:32 PM   #23
conehead
Drives: RS 2.0
you can buy a little solar panel and charge controller at harbor freight for cheap.
Old 03-13-2019, 04:10 PM   #24
mrg666
pessimistic skeptic
mrg666's Avatar
I just bought a Braille AGM - not lithium. So going with the traditional tech that's just 1/3 lighter.
I just went through the winter (a colder winter than previous years) in upstate NY with a Braille B3121 battery. There were no issues. It didn't need charging or anything different than stock battery. I will see how many years it will last. If it lasts more than 3 years, I am getting another.
Old 03-13-2019, 04:14 PM   #25
JD001
JD001's Avatar
Drives: Subaru BRZ
Hey All - Quick question -
My OEM battery finally bit the dust (from my 2013) and it's time for a new one.
I track my car occasionally and am not opposed to getting a smaller / lighter one. I do store my car in the winter on a trickle charger, so very cold starts are not an issue.
IF I do go with an aftermarket, smaller/lighter batter - I want it to be almost a direct swap if possible.
Any recommendations over another OEM battery?
Thank you!
What's going on here??? There are some very striking yellow bits that must turn blue....
Old 03-13-2019, 04:17 PM   #26
Gopherboy6956
lol what? The battery will be gone and the only part left yellow is the sticker on top of the radiator fill tube
What will really throw you off is the red Cam Sensor Covers, Alternator and water pump pulleys.
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 12:55 PM
FS: KC Machine lightweight battery mount with Shorai battery and charger toeout Engine, Exhaust, Bolt-Ons 4 04-23-2017 12:07 AM
Auto Battery Recommendations? JGalp Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 10-08-2016 08:03 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
