Old 10-16-2018, 08:02 PM   #57
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Another item missed in the article is the fuel type.
The Dynasty cars are SCCA T4 and won the Runoffs (because of Oscars penalty) and they didn't do it on 92 octane E10 pump gas. The article mentions 93 but competitive teams rarely share their secrets.
T4 rules state that one must run only the fuel type in the factory service manual.
The factory service manual says "unleaded" with '93 or higher' in parenthesis. So as long as it's unleaded that allows unleaded 100+ octane.
The other thing in the article that stood out is they say they have a Mustang Dyno - but then say usually cars with stock header and aftermarket exhaust see 185-190whp with a tune which seems like a high number on a Mustang Dyno? So to be at >200whp on a Mustang dyno with only a drop-in filter, gutted stock header and aftermarket exhaust is pretty damn crazy, especially if it really is on 93 octane.
I'm thinking I should call Circuit motorsports and buy that tune.
SCCA T4 - FRS
Old 03-05-2019, 11:24 PM   #58
86MLR
86MLR's Avatar
Thread bump for more data
2017 86 ADM
Snorkel mod
OEM air filter
Mishimoto intake pipe (no resonators)
OEM header (punched out cat)
2.5" Ultrex overpipe ($90, LOL)
2.5" X Force mid pipe (cat punched out)
2.5" X Force resonated cat back (X Force is cheap, LOL)
Ecutek Racerom
98 RON
Before tune is with all bolt ons, cut offs and knock outs
Just on 198hp
Difference between pre and post tune is night and day
Tuner says he can lose the dip, BUT, for the cost, he and I don't think it's worth the outlay.
The Following 2 Users Say Thank You to 86MLR For This Useful Post:
Prodigalson (06-30-2019), RToyo86 (03-16-2022)
Old 03-05-2019, 11:38 PM   #59
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by ApexEight View Post
What's that guy's deal lol. Better change your final drive bro, he says you need to
Originally Posted by Lantanafrs2 View Post
Sheesh I'd rather swap a header than rear end gears
Originally Posted by nikitopo View Post
If your rpm's are so low and you are in the correct gear, then you need to change your final drive ratio to a shorter one. Maybe a 4.55 will match good on such track. It always depends the track. It is not optimal to solve your issue by eliminating the torque dip. No matter how good is the curve in the mid rpm's, you won't get the maximum acceleration. You'll need to have the revs on the higher end area for the best acceleration.
Usually anytime I see 'nikitopo' chime in a thread it's usually baseless and not worth reading into....
Old 06-20-2019, 08:30 PM   #60
DarkSideFRS
Drives: 2013 pearl white FR-S
thread bump
how bad is the resonance in the cabin with the gutted cat?
DarkSideFRS is offline   Reply With Quote
The Following User Says Thank You to DarkSideFRS For This Useful Post:
mrntd (06-22-2020)
Old 04-15-2020, 01:34 PM   #61
MRBRZ1
MRBRZ1's Avatar
Drives: Subaru brz
Originally Posted by Joe-G View Post
There's a whole separate discussion regarding gutting the factory front pipe and header... but I never came across an actual dyno showing the gains on an NA setup. So for those interested, here's some reference in case you guys want to do the same.
Baseline is from another local car, which has been used as a baseline for a bunch of the locals. I think its pretty close to what these cars make stock at our altitude.
Based on my logs, the car runs a little rich and the MAF sensor still needs to be re-scaled due to the GS intake. MAF scaling is untouched from the Stg 2 OFT 93 EL map. LTFTs are around 8%, and under WOT/High RPM I think AFRs are low 11s. Was at Castrol Raceway this weekend and the car was backfiring non-stop during each session.
Modifications:
- OFT OTS Stage 2 93 EL tune
- Gutted factory header
- Gutted factory front pipe
- Custom muffler delete
- Grimmspeed Intake
- NST lightweight pulleys (Crank, water pump, alternator)
thanks for sharing this information.
Should i digging the cat of header only or cat and frontpipe must?
For now i'm with miltek catback and inbox filter oft stage 1.
I checked and found that there is no more difference between uel and el header map for stage 2 in ver 4.03.
What is acceptable knock value and what should be the afr in case i will switch to stage 2 with modified header?
MRBRZ1 is offline   Reply With Quote
Best Catback/Front Pipe/Over Pipe/Header Combo for the BRZ? O.Z. BRZ Engine, Exhaust, Transmission 22 04-17-2019 09:44 AM
Ceramic coating header only vs header/over pipe/front pipe pixel67 Forced Induction 8 08-18-2015 02:39 PM
FS: OEM FRS/BRZ Header w/ Gutted Cat malubawla Engine, Exhaust, Bolt-Ons 10 06-06-2014 11:29 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
