Old 02-25-2019, 12:51 PM   #15
Originally Posted by igorotak View Post
Don't intend to derail the thread but seeing that my17 and newer air intakes are better than previous years, is it plug n play if to swap a my17 or newer in my16? Or does it need a tune?
It would take some work to swap it over for virtually no gains. Just grab a high flow aftermarket filter for your 16 and call it a day.
igorotak (02-25-2019)
Old 02-25-2019, 12:52 PM   #16
Tristor
Tristor's Avatar
I'm not certain, but I'd imagine it likely needs a tune. The MY17+ MT has a different (red) intake manifold in addition to the different airbox and filter design. The airbox being different leads me to believe that the MAF sensor position may be different. I've never directly compared, but my guess is a tune would be required for you to see any benefit, otherwise any differences would be learned out by the ECU.
Also, I think just throwing a Blitz or K&N filter into your normal MY16 airbox would be a better choice anyway.
Tristor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tristor For This Useful Post:
igorotak (02-25-2019), new2subaru (03-01-2019)
Old 02-25-2019, 01:04 PM   #17
igorotak
I learned something new today! Thanks!
igorotak is offline   Reply With Quote
Old 02-25-2019, 01:11 PM   #18
Don't think the maf would be in a substantially different position and I doubt a tune would be needed but that is beside the point. The total changes in engine, intake, mainfold and exhaust with the tune that goes with them was a whopping 5HP so just changing the intake will gain nothing even with a tune. Could gain as much leaving everything as it is and just doing a tune.
Tristor (02-25-2019)
Old 02-25-2019, 02:21 PM   #19
ayau
Drives: Some rust bucket
You may or may not need a new tune, unless someone has done some logging and confirm.
You can log AF short and long term fuel trims and see how much the ECU is compensating to hit its target AFR.
Old 02-25-2019, 06:41 PM   #20
8inchAzN
Drives: Car
The Toyota part number for the MT intake filter is SU00306405
The AT part number is SU00300319
Subaru MT part number is 16546AA170
AT is 16546JB000
Markville toyota looked at me like I was an idiot for asking for SU00306405. They basically said all 86's use 17801yzz03 - that's the only part number they have on file - which a google search shows it being a corolla filter. I guess I'll just suck it up and go Subaru tomorrow.
8inchAzN is offline   Reply With Quote
Old 02-25-2019, 07:06 PM   #21
Very odd. The number is right so I have no idea why their system won't pull it up.
8inchAzN (02-25-2019)
Old 02-25-2019, 07:48 PM   #22
86MLR
86MLR's Avatar
Cross Reference Numbers
AC Delco A2036C
DuraMAX DA10586
Eco Gard XA10586
Fram CA9482
Purolator A25463
Purolator PA25463
Ryco A1489
Service Pro MA10586
Subaru 16546AA170
Wesfil WA1144
From here > https://www.ebay.com.au/itm/K-N-33-5...MAAOSwb-RbpOYf
Disclaimer: unsure on what the filter material is made from, from Googling P/N's it seems like most are cotton, if it is cotton you will be going backwards.
Pic of paper >
Old 02-25-2019, 10:16 PM   #23
8inchAzN
Drives: Car
The dude also said all FR-S/86's use this filter...so... oh well. Thanks for the help though.
The Following User Says Thank You to 8inchAzN For This Useful Post:
Tcoat (02-26-2019)
Old 02-26-2019, 02:18 AM   #24
86MLR
86MLR's Avatar
Eco Gard XA10586, Ryco A1489 and Wesfil WA1144 all seem to be typical paper element for 17+ OEM manual.
My local parts store has the Ryco's, I've never been a fan of oiled filters, plus for the cost of a K&N I can get 5 paper elements, no cleaning, no oil, just open and replace twice a year.
Opinions may vary
The Following User Says Thank You to 86MLR For This Useful Post:
Tcoat (02-26-2019)
Old 02-26-2019, 09:12 AM   #25
8inchAzN
Drives: Car
Opinions may vary
I'm on the same boat as you, I went to check out Partsource yesterday as well. They only stocked FRAM brand and the Fram one also uses the same filter between all 86/frs/brz model year and tranny options. I guess noone wants to stock something for a M/T car with only 2 MY's.
Old 02-26-2019, 09:20 AM   #26
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I doubt that they have picked up the differences and updated the catalogs.
Off the top of my head I can't recall another vehicle doing something so similar in regards to changing an air filter for a different transmission option.
The Following User Says Thank You to Summerwolf For This Useful Post:
Tcoat (02-26-2019)
Old 02-26-2019, 09:54 AM   #27
Opinions may vary
How about the oil bath filter I had on my 58 Chev? Only took almost a litre.
Old 02-26-2019, 04:10 PM   #28
8inchAzN
Drives: Car
AT is 16546JB000
Called Heffner Toyota today and asked specifically for that part number. They had to special order it in...there's 3 in all of Ontario.
Tcoat (02-26-2019)
Oil Filter For Toyota 86.. Need Help Twin-Dragons Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 06-14-2018 07:01 PM
TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development hirollaz Engine, Exhaust, Bolt-Ons 0 03-15-2017 03:46 AM
Which OEM oil filter? Subaru or Toyota? ndsleep612 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-30-2016 11:14 AM
Toyota Denso Oil filter fumanchu1 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-14-2015 07:30 AM
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 10:28 PM
