Old 02-24-2019, 10:46 PM   #1
8inchAzN
Drives: Car
Subaru vs Toyota air filter
I was wondering if there is a difference between an MY17 Subaru vs Toyota air filters. After doing some research, it seems the manuals do not have a large aftermarket support for the air filters. Can I just call up my local Subaru/ Toyota and go for the cheaper option or is there a consensus that one is better than the other?
8inchAzN is offline   Reply With Quote
Old 02-24-2019, 11:22 PM   #2
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
They are the same.
There is no change from 2013 model to current model respective to air filter size/dimensions. So you have TONS to pick from.
Edit - oops, I'm wrong. MT 2017+ are different.
Old 02-24-2019, 11:31 PM   #3
86MLR
86MLR's Avatar
Originally Posted by Bonburner View Post
They are the same.
Incorrect mate
2017+ manual have different airbox.
2017+ auto still uses pre 17
K&N and Blitz do aftermarket
Paper elements have more surface area than cotton
OEM 17+ paper element doesn't see a restriction as it has near on twice the surface area as the old design
Lots of different p/n's will fit, but most are cotton
I recommend OEM paper.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following 2 Users Say Thank You to 86MLR For This Useful Post:
Bonburner (02-25-2019), Busybee (05-26-2020)
Old 02-24-2019, 11:51 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
86MLR: also might be incorrect USDM vs EUDM, as later lacks many of intake/exhaust/tune updates vs former, if i remember correctly
Old 02-25-2019, 01:14 AM   #5
86MLR
86MLR's Avatar
Ack on EU getting the old kit, but isn't Markham in Canadia?
I thought that AUD, JDM, USD, and, ummm, Canadia all had the same upgrades.
I am happy to be proved wrong, a lesson learnt and all that...
OP: Where are you, hold your hand up high so I can see you....
The Following User Says Thank You to 86MLR For This Useful Post:
8inchAzN (02-25-2019)
Old 02-25-2019, 08:54 AM   #6
8inchAzN
Drives: Car
Correct, I am in Canadia.
Seems like Toyota and Subaru both use the same filters.
Old 02-25-2019, 09:47 AM   #7
8inchAzN
Drives: Car
Incorrect mate
So I just called Toyota and Subaru, they want 23$ vs 48$ respectively. However, the guy told me that the 2017 air filters are the same part for the MT and the AT. Skeptical, I called another dealer and they told me the same thing. Now I am curious lol.
Old 02-25-2019, 10:02 AM   #8
They are wrong if a MT but correct if an AT
The MT 17s use a much higher flow filter and intake. There is really no benefits to an aftermarket one so they never really got into it.
The AT 17s use the same as the 13+ so there are benefits to changing it and there are loads of options.
Just get whichever is cheaper.
Old 02-25-2019, 10:11 AM   #9
8inchAzN
Drives: Car
When I asked regarding 2017MT vs a 2017 AT air filter, both Toyota Dealerships told me they were the same part when they searched it on their computer.
The price difference was between Toyota and Subaru
Old 02-25-2019, 10:17 AM   #10
They are wrong. The picture I attached is the change to the 2017 MT ONLY. The AT filter remains the same as it was before and will not fit the 17+ MT. They are very different in size and shape.
Old 02-25-2019, 10:29 AM   #11
86TOYO2k17
Drives: 2017 toyota 86
Did you just say air filter or specify intake filter? Your first post makes it sound like you are referring to the cabin air filter. Which is the same for all vehicles.
The intake filter should be different.
Old 02-25-2019, 10:35 AM   #12
8inchAzN
Drives: Car
Sorry, I mean the engine filter. I specified Engine filter when I called them.
Old 02-25-2019, 10:42 AM   #13
The Toyota part number for the MT intake filter is SU00306405
The AT part number is SU00300319
Subaru MT part number is 16546AA170
AT is 16546JB000
8inchAzN (02-25-2019), Busybee (05-26-2020)
Old 02-25-2019, 11:36 AM   #14
igorotak
Don't intend to derail the thread but seeing that my17 and newer air intakes are better than previous years, is it plug n play if to swap a my17 or newer in my16? Or does it need a tune?
igorotak is offline   Reply With Quote
Oil Filter For Toyota 86.. Need Help Twin-Dragons Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 06-14-2018 06:01 PM
TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development hirollaz Engine, Exhaust, Bolt-Ons 0 03-15-2017 02:46 AM
Which OEM oil filter? Subaru or Toyota? ndsleep612 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-30-2016 10:14 AM
Toyota Denso Oil filter fumanchu1 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-14-2015 06:30 AM
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
