Old 02-02-2019, 06:06 PM   #1
PapaJ
Drives: 2014 Scion FRS
Tuning Options??
Hello everyone, Please pardon my noobness but I was preparing and researching a build I was going to to do in the coming months. I plan on adding several engine components ,SBD500x Turbo Kit, HKS Forged Internals, as well as a BUNCH of supporting mods for the turbo, and upgrades.
Where I seem to be lacking is TUNING, with awesome things like OFT out there and ECUTek, I am unsure what to go with. Or should I just source someone locally to do my tuning and not worry about doing myself. Any advice would be greatly appreciated.
PapaJ is offline   Reply With Quote
Old 02-02-2019, 06:18 PM   #2
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Ecutek, James @ HRI Tuning. The best.
Trueweltall is offline   Reply With Quote
The Following 3 Users Say Thank You to Trueweltall For This Useful Post:
kch (02-19-2019), Thedishdoc (02-04-2019), Trust86 (02-02-2019)
Old 02-02-2019, 06:21 PM   #3
Boomerang
86
Boomerang's Avatar
If you want to be safe then get ECUTek and a local tuner. More expensive overall but may be cheaper in the long run as you have less chance of blowing your motor with OFT and remote tune(very few tuners, if any do OFT)
Old 02-02-2019, 06:43 PM   #4
86TOYO2k17
Drives: 2017 toyota 86
Usually for FI ecutek is the way to go. But OFT does have tunes for the SBD turbo kit. Either one should be fine.
Old 02-02-2019, 08:29 PM   #5
Trust86
Drives: 2016 Halo FRS
Trust86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Trust86 For This Useful Post:
Thedishdoc (02-04-2019), Trueweltall (02-03-2019)
Old 02-02-2019, 11:06 PM   #6
jflogerzi
jflogerzi's Avatar
For any turbo build you want ecutek as it has built in safety features for overboosting etc... Plus now with the new Bluetooth module you can log using your phone.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 02-03-2019, 08:22 PM   #7
PapaJ
I've noticed that the 500x kit has an option for them to send the tune, which is what I was debating on doing. Is that something I would install myself?
I greatly appreciate all of the feedback from everyone.
Old 02-03-2019, 09:23 PM   #8
steve99
Drives: FT86
http://www.ft86club.com/forums/showthread.php?t=106068
Old 02-03-2019, 09:25 PM   #9
steve99
Drives: FT86
To flash\install a tune you will nedd fhe tune plus a device to access and flash the ecu see above link
Old 02-18-2019, 10:16 PM   #10
e30kawi
Drives: CWP limited
Where does delicious tuning fall in amongst the others in that link?
e30kawi is offline   Reply With Quote
Old 02-19-2019, 04:41 AM   #11
steve99
Drives: FT86
The info in link i posted relates to tune systems ie tuni g devices not tuners.
Feel vrre to pick tuner of your choice for any of the tune systems
Deliceous have a good reputation afaik they only tune with ecutek on brz\86 platform
e30kawi (02-19-2019)
Old 02-19-2019, 11:30 AM   #12
e30kawi
Drives: CWP limited
Would you not be able to take the tool to a tuner and have them make a custom map? Sorry for my ignorance, this is a new process for me and will have to find a way for a tuner to tune my car once I install a JRSC. Want to make sure I get the right stuff as they aren't exactly cheap if I buy the wrong thing.
Old 02-19-2019, 11:57 AM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
While most tuning solutions are similar now, there are variances that a tuner may not be familiar enough with. Some require specific licensing that a tuner will not want to acquire to create a custom map. Sometimes it's a matter of comfort, a good tuner will know their boundaries and speak up if they're not sure. For what it's worth, I'd find a tuner and tuning solution BEFORE you get the supercharger installed.
Old 02-19-2019, 04:47 PM   #14
steve99
Drives: FT86
If you going direct to tu er they will use theor runing device . You only need to buy the device\tool if your remote tuning or self tuning
Finally Ready to explore tuning options - Need Help iNcontroL Software Tuning 9 09-21-2016 01:52 PM
Tuning options in Chicago?! ual60515 Software Tuning 9 07-24-2015 06:51 PM
Tuning options for rallying Stumpygt86 Software Tuning 6 03-01-2015 08:25 PM
Tuning options near or in Cincinnati raven1231 Great Lakes 11 09-28-2014 09:10 PM
What are the DIY tuning options? 86dreams Engine, Exhaust, Transmission 25 09-16-2012 10:59 PM
