Old 02-18-2019, 09:16 PM   #883
ermax
ermax's Avatar
There were more than twice as many FRS's built than BRZs. it would be expected that there would be more failures after the work. There have been 3 catastrophic failures reported here so a BRZ is statically due any time now.
Wow I didn’t realize there was such a big discrepancy on sales in the first year. That explains a lot then.
Old 02-18-2019, 09:27 PM   #884
ermax
ermax's Avatar
Originally Posted by slizoth View Post
The mechanics are identical, unless Toyota has different standards for Technicians than Subuaru I think it's more likely there are just more FRS vehicles out there than BRZ.
Well Subaru has a few cars with the FA20 where as Toyota just has one. So you would expect a Subaru tech to be a little more knowledgeable on the engine. Although I doubt even at Subaru they spend much time rebuilding FA20s. But I agree the failures are probably bias on this forum due to the number of FRS’ sold.
Old 02-18-2019, 09:32 PM   #885
ermax
ermax's Avatar
I’m just hoping these people with bearing failures get taken care of. I rebuilt my engine about 7500 miles ago and it’s running fine but I bet if I get the recall done and it goes badly they will point their finger at me for doing my own rebuild. Or they could pull the old, “we don’t have oil change records for your car” scam.
Old 02-18-2019, 09:44 PM   #886
Originally Posted by alan.chalkley View Post
Has anyone done a base dyno before the valve spring recall work and then afterwards , to check if the new springs provide less power?
Just my ocd brain working , instead of sleeping!
You needed that!
Old 02-19-2019, 08:12 AM   #887
BRZnut
Drives: BRZ DGM Limited
Originally Posted by ermax View Post
There are 3 or 4 threads going where people have reported bearings going. If I recall there are a total of 5 reported. I could be wrong, id have to dig through the 4000 recall threads to be sure. But yeah I realize people aren’t reporting the good rebuilds I am simply saying we only saw one guy on the forum over many years report broken spring yet here we have 3 (going with your number to be conservative) report post recall bearing issues in just a few weeks. My point is statistically it seems they’ve created a bigger risk to the customers while shifting the liability to the dealers. But without real numbers you can’t be sure.
Ya, we need a sticky thread where those that have failures after the recall work can post what happened so that we can keep a running tab! Can someone do that?
The Following User Says Thank You to BRZnut For This Useful Post:
ka-t_240 (02-19-2019)
Old 02-19-2019, 09:13 AM   #888
Yes that is an excellent point as well!
Also, with Subaru they have more cars in total involved in the recall so it is very possible the BRZ work isn't being done as quickly and we wouldn't see the other model failures on here.
In the end though I would think at this point if there was a high failure rate on the repairs, there would have been a stop work order put out until it was determined the cause.
It's also possible we've heard from everyone that had a failure, but that seems unlikely.
Tcoat (02-19-2019)
Old 02-19-2019, 09:21 AM   #889
Why? What would it prove? To track failures without knowing the number of successes is dirty data. It is worse than meaningless since it does not consider all the possibilities. Even if we could track the failures vs the successes on here it would still be meaningless since we are just too small a sample size to compile any form of accurate statistics.
It is indisputable that there have been some problems but to emphasize those issues while ignoring the successes is nothing but fear mongering and irresponsible.
Everybody needs to just take a step back, take a big breath and relax. Going on a quest to find issues only will result in finding only the issues and not the reality of the situation.
Dadhawk (02-19-2019), Gunman (02-19-2019)
Old 02-19-2019, 09:35 AM   #890
Yep! As much as so many on here would like to think they know more about doing business than Toyota and Subaru the companies know what they are doing. The recall is already costing them $450 MILLION and they are not going to force that cost up by having to replace engines in every 10 cars or so.
Like all car forums there will always be a bunch running around screaming that the sky is falling because a drop of rain fell close to them.
Old 02-19-2019, 10:20 AM   #891
ermax
ermax's Avatar
Rumor is some dealers have put their own stop order in the repair.
The Following 2 Users Say Thank You to ermax For This Useful Post:
Dadhawk (02-19-2019), Tcoat (02-19-2019)
Old 02-19-2019, 10:43 AM   #892
It would be the prudent thing to do if the dealer is aware of the failures and still have several cars to do.
Old 02-19-2019, 11:25 AM   #893
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
less than 2 weeks and less than 200 miles after the recall, my engine has seized and refuses to rotate. Car has been sent to the local dealer today to figure out what happened
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
The Following User Says Thank You to 200hp/tonne For This Useful Post:
Old 02-19-2019, 11:39 AM   #894
ermax
ermax's Avatar
I see you have some mods. It will be interesting to see if the dealer tries to blame the mods.
Good luck!
The Following User Says Thank You to ermax For This Useful Post:
Old 02-19-2019, 11:42 AM   #895
Seems like we need a "condolences" button rather than a "thanks" at times.
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
ermax (02-19-2019), maslin (02-19-2019), mswbrz (02-20-2019), Sapphireho (02-19-2019)
Old 02-19-2019, 12:12 PM   #896
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Reeses "Sorry, not sorry!" too for completeness?
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
