#883 | |
Wow I didn’t realize there was such a big discrepancy on sales in the first year. That explains a lot then. |
#884 | |
Well Subaru has a few cars with the FA20 where as Toyota just has one. So you would expect a Subaru tech to be a little more knowledgeable on the engine. Although I doubt even at Subaru they spend much time rebuilding FA20s. But I agree the failures are probably bias on this forum due to the number of FRS’ sold. |
#885 |
I’m just hoping these people with bearing failures get taken care of. I rebuilt my engine about 7500 miles ago and it’s running fine but I bet if I get the recall done and it goes badly they will point their finger at me for doing my own rebuild. Or they could pull the old, “we don’t have oil change records for your car” scam.
#886 |
#887 | |
Drives: BRZ DGM Limited
| The Following User Says Thank You to BRZnut For This Useful Post: | ka-t_240 (02-19-2019) |
#888 |
Also, with Subaru they have more cars in total involved in the recall so it is very possible the BRZ work isn't being done as quickly and we wouldn't see the other model failures on here.
In the end though I would think at this point if there was a high failure rate on the repairs, there would have been a stop work order put out until it was determined the cause. It's also possible we've heard from everyone that had a failure, but that seems unlikely.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (02-19-2019) |
#889 | |
It is indisputable that there have been some problems but to emphasize those issues while ignoring the successes is nothing but fear mongering and irresponsible. Everybody needs to just take a step back, take a big breath and relax. Going on a quest to find issues only will result in finding only the issues and not the reality of the situation.
#890 | |
Like all car forums there will always be a bunch running around screaming that the sky is falling because a drop of rain fell close to them.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (02-19-2019) |
#891 | |
#892 |
It would be the prudent thing to do if the dealer is aware of the failures and still have several cars to do.
#893 |
Drives: Raven Fr-S
less than 2 weeks and less than 200 miles after the recall, my engine has seized and refuses to rotate. Car has been sent to the local dealer today to figure out what happened
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
| The Following User Says Thank You to 200hp/tonne For This Useful Post: | Dadhawk (02-19-2019) |
#894 | |
Good luck! |
| The Following User Says Thank You to ermax For This Useful Post: | Dadhawk (02-19-2019) |
#895 |
Seems like we need a "condolences" button rather than a "thanks" at times.
| The Following 4 Users Say Thank You to Dadhawk For This Useful Post: |
#896 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Reeses "Sorry, not sorry!" too for completeness?
"I gotta rock." -- Charley Brown |
| Broken Valve Spring | sybrite | Engine, Exhaust, Transmission | 45 | 11-02-2018 04:20 AM |
| Valve spring swap | rcmf5525 | Engine, Exhaust, Transmission | 6 | 05-19-2018 03:12 PM |
| Jrsc replacement diverter valve issue | Brzxton | Forced Induction | 6 | 12-08-2017 09:39 AM |
| GSC FA20 Valve Spring Kits | MAPerformance | Engine, Exhaust, Transmission | 41 | 07-20-2015 10:22 AM |
| Skunk2 Dual Valve Spring and Titanium Retainers | limitedblkwrx | Engine, Exhaust, Transmission | 0 | 01-04-2015 11:12 PM |
