Old 07-28-2013, 11:10 PM   #29
utekineir
blowhard
Drives: frs, project forester
Originally Posted by FR-S Matt View Post
Your true enthusiast though that wants every ounce of horsepower will go EL though.
This,
that and this car needs all the help it can get, seems counter productive imo to do anything that robs power.
i.e. chunky wheels, etc.
utekineir is offline   Reply With Quote
Old 07-30-2013, 02:00 AM   #30
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Some people like the smooth sound over the burble.
uspspro is offline   Reply With Quote
Old 08-03-2013, 07:07 PM   #31
yamsta
daGangsta
yamsta's Avatar
Drives: 2013 FR-S 6MT
If anyone is looking for an EL Header with high flow cat, I'm selling my P&L one here: http://www.ft86club.com/forums/showthread.php?p=1116300
yamsta is offline   Reply With Quote
Old 09-10-2018, 05:00 PM   #32
Seiryuu
Drives: ZC6
So 5 years later... Is there an EL header that sorta functions more like an UEL header for the torque dip? It doesn't have to be equally as good as UEL, just better than other EL headers even if it means not gaining as much top end.
Seiryuu is offline   Reply With Quote
Old 09-10-2018, 05:44 PM   #33
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I can't pull up images easily since I'm at work, but look at HKS and ACE iirc
Old 09-10-2018, 05:46 PM   #34
churchx
churchx's Avatar
Drives: 2014 GT86
Ace's.
Old 09-10-2018, 07:03 PM   #35
freerunner
freerunner's Avatar
Drives: GT86
JDL
freerunner is offline   Reply With Quote
Old 09-10-2018, 08:46 PM   #36
CSG Mike
CSG Mike's Avatar
It's been out for a while now, but not only does it eradicate the torque dip, it makes it a torque peak, and also has the highest output of any header on the market for this car.
https://www.counterspacegarage.com/csg-86ace-dt
Package includes header, overpipe, all the hardware you need, and tune.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
justinco (09-11-2018), Spawn_Of_Creation (09-11-2018), wparsons (09-11-2018)
Old 09-11-2018, 01:06 PM   #37
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
How about better than a UEL in almost every way, especially in the "dip" area?
[ame]http://www.youtube.com/watch?v=ggQspB1P7a4[/ame]
justinco is offline   Reply With Quote
The Following 3 Users Say Thank You to justinco For This Useful Post:
CSG Mike (09-11-2018), smg1138 (02-18-2019), wparsons (09-11-2018)
Old 09-11-2018, 10:01 PM   #38
PulsarBeeerz
Drives: JRSC BRZ SOLD
JDLs prototype EL header has more area under the curve than their own UEL. They have a dyno of it on their IG.
PulsarBeeerz is offline   Reply With Quote
The Following 4 Users Say Thank You to PulsarBeeerz For This Useful Post:
CSG Mike (09-12-2018), tehShirt (09-12-2018), Turdinator (09-14-2018), wparsons (09-11-2018)
Old 02-17-2019, 04:44 PM   #39
Wil
Wil's Avatar
Drives: Drives like a crab.
Kind of necroing this but, I am still looking for a catted EL header that really does correct the torque dip. Budget is 1k$.
I was looking at the FT86 Speed Factory which appears to be barely UEL and sounds kind of EL on top. JDL and P&L as well but could not find some relevant and independant testing. It will be tuned with OFT.
I'm using the car as a daily driver and will track it from time to time on tracks with long phase of acceleration (Spa to be precise)
Wil is offline   Reply With Quote
Old 02-17-2019, 04:59 PM   #40
Hawk77FT
Drives: GTS 86
Get ACE CS400 or A350 and front pipe with a high flow cat in it (100 cel). Problem solved!
Hawk77FT is offline   Reply With Quote
Old 02-17-2019, 07:50 PM   #41
Lantanafrs2
Drives: 2013 frs red
This is the last thread that needed reviving.
Lantanafrs2 is offline   Reply With Quote
Old 02-17-2019, 08:44 PM   #42
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Catted is not your answer for what you are looking for. Must be catless
Dr. BRZ is offline   Reply With Quote
DIY: ReWire AT Shifter to Reverse & Correct the +/- pattern (on selector stick) ymboc DIY (Do-It-Yourself) Guides 11 04-02-2022 05:07 PM
Correct barb size for catch can? Hanakuso Engine, Exhaust, Transmission 15 01-23-2014 06:32 PM
Do these look correct for our car? 9005 Replacement BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 1 06-24-2013 11:15 AM
correct idle rpm after warmup StormTrooper Issues | Warranty | Recalls / TSB 11 04-27-2013 07:00 PM
Fitting 9.5" wheels in back.. is my math correct? eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 05-23-2012 02:19 PM
