#29 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
One event. It can turn over multiple times in said occurance.
#30 |
#31 | |
The buzzing under the hood is the servo motor in the throttle body. Normal.
#32 |
Famous Potatoes
Drives: '15 ultramarine
| The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
#33 | |
OP, have you gone in for the valve spring recall? It might be that.
#34 |
Drives: 2013 Scion FRS
#35 |
#36 |
#37 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
![]() Every aftermarket battery maker does this. |
#38 |
Yep they are pro rated but it is better than nothing.
#39 |
Just got a new battery. Same issue, car won't start
Sent from my SM-G955U using Tapatalk |
#40 |
Famous Potatoes
#41 | |
https://www.aa1car.com/library/battery_runs_down.htm humfrz |
#42 |
If new battery didn't start the car then the charging system is not suspect (yet).
Check new battery. Is it charged? Brand new ones can be bad more often than most things you buy. Check cable ends to ensure clean and tight. It doesn't take much. Nobody thought to ask before but had you changed anything on the car just before it started having issues?
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 10:40 PM |
| Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 06:47 PM |
| Voice Commands with new turn by turn in IOS6? | jadewbj | Electronics | Audio | NAV | Infotainment | 0 | 09-21-2012 10:11 AM |
