Old 02-04-2019, 03:46 PM   #29
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Well it can. Once.
One event. It can turn over multiple times in said occurance.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
gkubed (02-05-2019), Tcoat (02-04-2019)
Old 02-04-2019, 03:47 PM   #30
One event. I can turn over multiple times in said occurance.
Old 02-04-2019, 03:49 PM   #31
Originally Posted by RZNT4R View Post
Holy crap people, 11.8V isn't slightly low, it's beyond discharged.
A 12V battery is full between 12.6 and 12.8, and below 12.2 is considered completely discharged. Below 12.4 it shouldn't even be load tested.
I'm late to the party. ^^^this^^^
The buzzing under the hood is the servo motor in the throttle body. Normal.
Old 02-04-2019, 04:49 PM   #32
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Well of course it's the battery, but we have to go thru 3 pages of over-diagnosis. Might be the valve springs?
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
finch1750 (02-04-2019), Tcoat (02-04-2019), Ultramaroon (02-04-2019)
Old 02-04-2019, 06:46 PM   #33
Ok, yeah.
OP, have you gone in for the valve spring recall? It might be that.
Old 02-04-2019, 07:07 PM   #34
bsco
Drives: 2013 Scion FRS
Ok, yeah.
I haven't gone in for that
Sent from my SM-G955U using Tapatalk
bsco is offline   Reply With Quote
Old 02-04-2019, 07:11 PM   #35
We were JK.
Old 02-04-2019, 07:12 PM   #36
bsco
We were JK.
I know haha
Old 02-05-2019, 05:50 AM   #37
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I find it hilarious that they offer a 7 year warranty on a replacement battery but the one that comes with the car is only covered by the general new car warranty.
This is how battery warranties work, straight from toyota's website. It's not a 7 year warranty, it's 2 years then you have to pay the difference between the "depreciated" battery and a new one
Every aftermarket battery maker does this.
Old 02-05-2019, 06:45 AM   #38
Yep they are pro rated but it is better than nothing.
Old 02-07-2019, 06:43 PM   #39
bsco
Just got a new battery. Same issue, car won't start
Old 02-07-2019, 06:45 PM   #40
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Wholly cow. What is it doing now? Did you have the other battery and your charging system checked?
Old 02-07-2019, 07:20 PM   #41
I suggest you check out the NEW battery and the charging system, if you haven't already.
https://www.aa1car.com/library/battery_runs_down.htm
Old 02-07-2019, 07:31 PM   #42
If new battery didn't start the car then the charging system is not suspect (yet).
Check new battery. Is it charged? Brand new ones can be bad more often than most things you buy.
Check cable ends to ensure clean and tight. It doesn't take much.
Nobody thought to ask before but had you changed anything on the car just before it started having issues?
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 06:47 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
