Old 02-04-2019, 10:30 AM   #1
bsco
Drives: 2013 Scion FRS
Car won't turn over
Anybody know what this issue could be? All the lights work, but it's like it's stuck in accessory and won't turn over. The only noises coming from under the hood is a buzzing.
Sent from my SM-G955U using Tapatalk
bsco is offline   Reply With Quote
Old 02-04-2019, 10:43 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Battery may not have enough juice to crank or bad starter.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-04-2019, 10:43 AM   #3
bsco
I'll check that. I have a video of what's going on, but it's too big to upload it here, unfortunately
Old 02-04-2019, 11:15 AM   #4
Battery is low. The buzzing is the starter solenoid trying to engage. The lights work because they don't need near the amperage the starter does.
Old 02-04-2019, 11:20 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Just had someone who this happened to after they tried to flash a tune to their car that was for the incorrect ECU version. They had to buy a new ECU. Had you just done a reflash? This is PROBABLY just the starter, as everyone else has said.
Old 02-04-2019, 11:33 AM   #6
Brz_racer
Drives: Subaru BRZ
Check your alternator, if the battery is dead the alternator could be the cause
Brz_racer is offline   Reply With Quote
Old 02-04-2019, 11:38 AM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Original battery? If so, maybe your 6 year old battery is on it's way out.
Old 02-04-2019, 11:39 AM   #8
bsco
Didn't try flashing
Old 02-04-2019, 11:40 AM   #9
bsco
It's at 11.85. I don't know the cca though.
Old 02-04-2019, 11:43 AM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
That's slightly low.
Check what it drops to when starting the car? Under 9 and it's probably toast
Old 02-04-2019, 11:46 AM   #11
bsco
Well it won't start, so I can check CCA or anything haha
The Following User Says Thank You to bsco For This Useful Post:
Tcoat (02-04-2019)
Old 02-04-2019, 11:48 AM   #12
bsco
It only stays in accessory mode, but 11.5x is where it's at then
Old 02-04-2019, 11:50 AM   #13
finch1750
finch1750's Avatar
I meant when trying to turn it over. Vids and stuff are blocked at work so forgive me if you posted something and I'm way off. But if you have someone who can turn the key while you check the volts you should see what the battery drops to.
A normal battery should be around 12.5v iirc when off. And stay above 9 when trying to start.
Old 02-04-2019, 11:51 AM   #14
bsco
Yeah I tried that. Car won't start, just go into accessory when turning the key all the way
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 06:47 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
