Old 02-02-2019, 09:21 PM   #1
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Brand suggestions on replacing OEM speakers on door & a Mini Amp
I'm old and lazy to look through this entire section.
I did look at the thread on using OEM wiring to Alpine ktp444u amp.
Looking to upgrade just OEM door speakers. I know they're run via stock amp in trunk. I'm willing to buy a mini amp to run new speakers. I won't be installing this on my own. Probably go to a reputable car audio shop. I wanna be prepared before I go there knowing prices and so forth.
Budget for just speakers and amp, $250-$350. Not sure if I should go component 6.5 speakers or just Two or three way 6.5.
Thanks for the suggestions in advance. I appreciate it.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 02-03-2019, 07:27 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
what are you looking to accomplish by replacing the door speakers and amp?
humfrz (02-03-2019)
Old 02-03-2019, 09:40 PM   #3
Thanks for the suggestions in advance. I appreciate it. ;)
Have you considered getting a hearing aid (or a new one/a second one) or at least new batteries or just turn it up?
Sorry, in advance
Old 02-04-2019, 10:24 PM   #4
86geek
86geek's Avatar
Speakers are crackling & sound has degraded that's why I want to replace it. Sheesh. Car sits 24/7 in the hot Hawaii sun. Heat & humidity number one killer of car speakers. Any suggestions will be appreciated.
Old 02-04-2019, 11:00 PM   #5
Grady
Grady's Avatar
Everyone’s ears and tastes are different. You have to go with what manufacturer sounds good to you. Take you favorite song with you to the store and play it on multiple speakers.
Old 02-05-2019, 12:44 AM   #6
soundman98
soundman98's Avatar
that is quite odd, as the build quality of the oem speakers is on-par with most aftermarket speakers
i haven't heard these, but the specs look decent, and they're for rougher environments.
https://www.parts-express.com/tang-b...2-ohm--264-964
then paired with this amp, i like shooting for around 50-100w rms with most of my builds..
https://www.sonicelectronix.com/item...L-GX-A602.html
that would put you around $195 + install costs. you could slim it down by only replacing the speakers instead of the speakers and amp. more than likely, the speakers are the root cause, amplifiers don't commonly go bad, as there's no moving parts to break down on them.
Door speakers not working JRBEL Electronics | Audio | NAV | Infotainment 11 11-11-2017 03:40 AM
Get Big! (door speakers) Shankenstein Electronics | Audio | NAV | Infotainment 3 06-10-2014 03:55 PM
Replacing stock speakers without juice fmsida Electronics | Audio | NAV | Infotainment 17 03-01-2014 05:16 AM
BRZ door Speakers bbs15 CANADA 3 05-23-2013 06:29 PM
door speakers elfumador Electronics | Audio | NAV | Infotainment 3 04-25-2013 02:00 PM
