Old 01-30-2019, 01:46 PM   #113
ka-t_240
Originally Posted by venturaII View Post
For those of us who plan to stay NA, I think having the option to purchase an adapter to keep the 86 transmission would be well worth it, compared to the headache of modifying the S2000 shifter, on top of the purchase price for that transmission, plus the need to use a different adapter anyways to connect the K motor and S2K trans... I get that the S2000 trans is stronger, but not everyone necessarily needs that in the first place.
The other thing to consider is, how is the BRZ gearing going to work with a K series powerband/rpm.
ka-t_240 is offline   Reply With Quote
Old 01-30-2019, 01:55 PM   #114
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I think it'd work splendidly, frankly. You're talking two 4 cylinder motors of similar displacement and states of tune, not going from the FA20 to an LS with 3x the displacement and torque. K24x motors all have factory redlines that are slightly lower than the FA20. Factor in a tune that allows slightly higher rpms, and you're back on par with the FA20 in terms of usable rpm span.
And even if you used a K20A or Z head on a K24 bottom end, the K20 has an 8000rpm redline which is only 600rpm higher than ours. Remember that the K20 head on the K24 block will drop the K20 head's effective power range a few hundred rpm, and you're back in the same ballpark as the FA20.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 01-30-2019, 02:04 PM   #115
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
This guy makes a good point. What all is involved in an adapter anyways? I'm not familiar with adapting transmissions. Probably some kind of bracket for the bolts and then something for the driveshaft?
Unless I am mistaken, it is a custom bracket or a custom bell housing. Then it would be necessary to do a custom driveshaft and potentially a custom shifter. Even keeping the stock transmission may require all these components because the engine has been shifted closer to the firewall.
Old 01-30-2019, 02:09 PM   #116
venturaII
venturaII's Avatar
http://www.ft86club.com/forums/showp...&postcount=112
Old 01-30-2019, 02:13 PM   #117
venturaII
venturaII's Avatar
Honestly, the value in keeping the factory driveshaft is a little pointless, especially considering one of the big appealing features of this swap is weight reduction. An aftermarket aluminum driveshaft is a relatively cheap way to lose static weight (not even bringing up the rotational argument). So since an aftermarket driveshaft is already going to be on the list of mods that would support this project, it's a pretty simple thing to have it made to length to suit this application.
There IS value in keeping the factory shifter location though, so that would need further investigation.
Old 01-30-2019, 02:23 PM   #118
Ashikabi
Ashikabi's Avatar
If the motor is closer to the firewall then surely the input shaft will now be too long right? Might have to move the motor forward if you want to keep the transmission. Otherwise if you move the transmission, the shifter will be wrong. Then you have a bunch more issues like needing the new shifter and transmission mount
The Following User Says Thank You to Ashikabi For This Useful Post:
Irace86.2.0 (01-30-2019)
Old 01-30-2019, 02:35 PM   #119
venturaII
venturaII's Avatar
IF all that is necessary to make the K motor fit, then there's less value to using the 86 transmission. However, you've still got to contend with the basic cost of the S2K transmission in the first place, which seem to be somewhat higher than what our transmissions are valued at, if you're trying to recoup some of your costs..
Old 01-30-2019, 02:39 PM   #120
ka-t_240
My friends K24 civic revs to 8500rpm. Makes way more torque and HP than my car on the same dyno. Its a stock K24 bottom, stockish head, cams, e85, bolt ons. IIRC it made 245/200 with a great powerband im comparison to the brz. Makes me want a K so much.
The Following 3 Users Say Thank You to ka-t_240 For This Useful Post:
Icecreamtruk (01-31-2019), Teseo (02-01-2019), wparsons (02-08-2019)
Old 01-30-2019, 02:40 PM   #121
Ashikabi
Ashikabi's Avatar
I agree that it would be considered. It certainly sounds both convenient and tempting for presumed cost savings. I'm not sold on it but I couldn't rule it out either
Old 01-30-2019, 02:41 PM   #122
venturaII
venturaII's Avatar
Also, some really quick Googling shows the K24 motor is about 20" long, whereas the FA20 is 18". Not a lot of difference, which additionally lends itself to easier placement. Just food for thought.
Old 01-30-2019, 02:44 PM   #123
Ashikabi
Ashikabi's Avatar
Nevermind. Dumb idea
Old 01-30-2019, 03:29 PM   #124
Irace86.2.0
Just food for thought. Wouldn’t work with their current mounts as the input shaft is too long like Ashikabi said.
Old 01-30-2019, 03:49 PM   #125
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
for what a custom adapter, flywheel/clutch assembly, etc would cost to mate the fa20 transmission to the k block, you could buy one of the multiple k to s2000 trans adapter kits already out there and a used s2000 trans. the time it would take to develop that whole setup, test, revise, test again, etc would not be worth it for the number of sales you could count on one hand.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 8 Users Say Thank You to spitfire481 For This Useful Post:
BertoFT (01-30-2019), Draco_PR23 (02-19-2019), Icecreamtruk (01-31-2019), Irace86.2.0 (01-30-2019), PuslarBrrrz (01-31-2019), Sportsguy83 (01-31-2019), venturaII (01-30-2019), wparsons (02-08-2019)
Old 02-02-2019, 12:34 AM   #126
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
I looked through your other K swap thread on here, i noticed the DBW TB.. is it the grams honda one ?
PolishFrs13 is offline   Reply With Quote
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! Pure Automotive Engine Swaps 29 01-10-2018 01:20 AM
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap Pure Automotive Engine Swap 0 12-01-2017 11:57 AM
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:49 AM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:23 AM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 06:33 PM
