Old 12-30-2014, 09:50 AM   #1
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Cool Pure Auto's 2JZ Swap Thread - The DRAGFRS
Hey guys, I'm sure some of you have already seen our build thread but since there's finally a swap forum I decided to move it over here as well. Our car was previously LS2 swapped before we decided to go 2JZ. The V8 swap was insanely fun and the only reason we decided to 2JZ was because we were offered good money for the LS2 setup. So being a lover of Supras, I decided its time to do what I wanted to do from the start- Put Toyota power into my Toyota!
The car will be purpose built for drag racing. I'm sure a lot of people won't like that but that's what I really enjoy and the 2JZ platform is no stranger to the 1320. Now for some pictures!
Test Fitting With Stock Manifolds
Test Fitting Our Beautiful PowerHouse Racing Turbo Manifold
The Precious, Borg Warner S400SX 67MM FMW
Test Fitting Our Custom Intake Manifold With Wilson Throttle Body
Starting To Clean Up The Rest Of the Engine Bay- ABS Delete, Booster Delete, Partial Wire Tuck
Engine Is Nearly Complete! Just have to degree the cams and she's all set!
Meanwhile, the car is getting a massive face lift. Partially shaved bay and fixing all the small knicks and bumps.
Before
After
Thanks to @spitfire481 the car is looking "Purer" than ever haha! It's so greeeeeen!
Wraps and great, plastidip is cheap, but there is no replacement for the hard work and art of a full paint job!
Starting to piece the bay back together for insertion, transmission is on it's way!
I'm not online every day, but I will try to keep the thread updated as we go!
Pure Automotive is offline   Reply With Quote
The Following 15 Users Say Thank You to Pure Automotive For This Useful Post:
adprokid (12-30-2014), akahenry (12-30-2014), Bonburner (04-28-2015), civicdrivr (01-17-2015), Creole (08-26-2015), Guff (05-09-2015), kanundrum (01-05-2015), Lonewolf (12-30-2014), Manji (12-31-2014), Marcoscrdo (05-01-2015), SirBrass (04-01-2015), SkAsphalt (12-30-2014), spdfreak (05-25-2015), Sportsguy83 (01-21-2015), Valentino (03-25-2015)
Old 12-30-2014, 01:07 PM   #2
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Looking forward to next Spring
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
Pure Automotive (12-30-2014)
Old 12-30-2014, 06:24 PM   #3
White64Goat
No more power brakes? Installing a chute out back?
The Following User Says Thank You to White64Goat For This Useful Post:
Old 12-30-2014, 07:35 PM   #4
Pure Automotive
If it goes fast enough I will. Manual brakes aren't as bad as you would think. I recently found out that when I had the v8 in there and the ABS light was on, I was really only braking with the front brakes and now that ABS is gone I will have fully functioning and adjustable front and rear. I'm hoping for an overall improved braking experience with just a bit more pedal pressure.
Old 12-30-2014, 07:44 PM   #5
limitedblkwrx
Ultimate Member
limitedblkwrx's Avatar
Drives: 2014 Satin White BRZ
Looks Awesome, I would like to do a 2JZ swap to mine one day. At Least I know where I can go to get it done.
limitedblkwrx is offline   Reply With Quote
The Following 2 Users Say Thank You to limitedblkwrx For This Useful Post:
phobos512 (12-31-2014), Pure Automotive (12-30-2014)
Old 01-04-2015, 05:32 AM   #6
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Those are some ugly ass wheels. But at the same time, if i saw a car with those on, i would try my best not to pass them...
ig:Vinshiin
Vincenttam is offline   Reply With Quote
Old 01-05-2015, 09:58 PM   #7
Pure Automotive
Thanks? Lol
Old 01-05-2015, 10:45 PM   #8
slicktop
Originally Posted by Pure Automotive View Post
Thanks? Lol
You forgot to hellaflushillestswag it, therefore it's ugly.
Pure Automotive (01-07-2015)
Old 01-06-2015, 12:41 AM   #9
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
woRd!
Drift&Drag is offline   Reply With Quote
The Following User Says Thank You to Drift&Drag For This Useful Post:
Old 01-06-2015, 02:43 AM   #10
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
What's your end goal? Going to end up with a front shell of a car like Ekanoo?
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Old 01-07-2015, 02:56 AM   #11
rh9
Drives: red brz
what ecu and wiring are you guys gonna use ?
and what rear end setup are you putting on her ?
rh9 is offline   Reply With Quote
Old 01-07-2015, 01:35 PM   #12
Pure Automotive
No way, I'm not rich like that lol. The car will be in all original body and will have full interior from the seats forward. It will be getting a roll cage and possible a chute if the mph is there. But I fully intend to continue putting street miles on it. I'm not a fan of trailer queening. I put about 2000 miles on the V8 swap on the street before we pulled it.
Old 01-07-2015, 02:16 PM   #13
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Open ended question here but...
How much would it cost for a basic turn-key 2jz swap?
hmong337 is offline   Reply With Quote
Old 01-07-2015, 02:49 PM   #14
Pure Automotive
I couldn't begin to tell you that without a 30 question interview about goals, turbo, manifold, piping, exhaust, etc. There's so many variables. The only thing I can say is, don't listen to anyone who tells you it can be done on the cheap. If you want to do it right and reliable, it will cost you a sizeable about of money. At least $20k as a starting point for a professional to do the job. I will give you an example breakdown of bare minimum parts that you need that make up a large part of the total:
Engine/Trans, if you go V160, you're talking $8k
Custom Wiring Harness, starting at $800
Custom Driveshaft, at least $500 if you get it deal
Custom intercooler piping, WG, BOV $1000 +
Turbo Manifold $1500 and up for quality setups
Custom downpipe and dump tube $500+
Turbo $1000-25000 depending on what kind/size
Clutch, Flywheel, Custom Shifter- If you plan to make real power $1400+
Stand Alone Engine Management $2000
RacePack Dash $800
Custom hoses for radiator, heat, A/C, etc. $500+
Axles to support 600+hp
Rear end to support 600+
^ This puts you around $13k and we haven't even opened this used motor to build or do maintenance on anything. You're going to want cams, cam gears, valve springs, retainers, new water pump, new timing belt, new gaskets, at a MINIMUM before you put it in the car, there's another $1500 not including labor.
Now you're talking $15k in parts alone, now someone has to spend xx amount of days properly installing everything, clearencing everything, tuning, etc.
I don't mean to sound ignorant, arrogant, presumptuous, etc. But this is my 3rd engine/trans setup in this car and I can tell you from experience, its ALOT of work and ALOT of unexpected expenses that you come across as you do a swap. I wish I could tell you we do 2JZ swaps for $10k installed but I would be lying and giving you false hope.
*** Disclaimer: This is NOT an advertisement. None of the prices I have put above are in any way an actual price quote for any services/parts. I am simply using numbers for an explanation that people need to see to understand. Please don't delete this as an attempt to advertise, it is NOT.
The Following 11 Users Say Thank You to Pure Automotive For This Useful Post:
adprokid (01-08-2015), AZ BRZ (01-06-2016), dem00n (01-19-2015), Drift&Drag (01-07-2015), Manji (04-03-2015), Ryaquinn (01-12-2015), SirBrass (04-01-2015), slicktop (03-01-2015), Sportsguy83 (01-21-2015), TofuJoe (07-20-2015), Valentino (03-25-2015)
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! Pure Automotive Member's Car Journals 53 03-05-2015 07:11 PM
The New Consolidated Install Thread @Pure Automotive Performance, FT86 Specialists! Pure Automotive Mid-Atlantic 14 09-26-2013 11:28 PM
**The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive Pure Automotive Brakes, Suspension, Chassis 1 02-06-2013 03:32 PM
*Pure Automotive Performance: Project Whiteout FRS Build Thread* Pure Automotive Member's Car Journals 6 01-18-2013 12:34 PM
