Old 01-24-2019, 03:15 PM   #813
lol... Doh!
I wonder if that clutch dust doesn't exacerbate the wear between the quill and bushing. Mixes with the grease and makes a gritty mess. I hate the design but both Toyota and Subaru seem to be ok with it.
My guess is yes. Yes it does.
Ultramaroon (01-24-2019)
Old 01-24-2019, 03:33 PM   #814
maslin
Benz Tech
Drives: 2017 BRZ Premium
Nasty. Good argument for a hydraulic throw out bearing.
maslin is offline   Reply With Quote
Old 01-24-2019, 03:42 PM   #815
lol... Doh!
Nooooooooooooo!
Bubba tells me that the powder off of the clutch disk acts as a lubricant just like graphite would.
There ya have it!
humfrz for Bubba
S. Snake (01-24-2019)
Old 01-24-2019, 03:44 PM   #816
I say we should go back to brass bushings -
swfrs (01-25-2019), Ultramaroon (01-24-2019)
Old 01-25-2019, 01:19 PM   #817
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Brass bushings and pig lard. The way forward.
And bacon in the mean time.
The Following 2 Users Say Thank You to bcj For This Useful Post:
humfrz (01-25-2019), Ultramaroon (01-25-2019)
Old 01-25-2019, 02:57 PM   #818
Fer sure, fer sure.
For the young-ens:
Early axle grease was Tallow, made from animal fat rendered from Beef or Mutton. At room temperature, Tallow remains as a solid substance that could be stored for long periods of time. Due to not having refrigeration to prevent decomposing, tallow was stored in various air tight containers to prevent oxidation.
The wheel-grease containers were among the tools most wagons needed for simple maintenance. Before axle grease came in a tin can, it was often kept in ox-horn containers or a carved out log with a lid as shown left. Looped together with a chain or rope the grease container could then be carried over the rear axle during transit. Carved logs and wooden buckets would be made with an lid having a small hole which allowed to carry a mop like brush used to apply the grease. Later containers would be iron or steel, eventually being supplied in sealed tins.
For early pioneers, grease lubrication was kept at a minimum because of its short supply, but history also records that in emergencies, fatback - today's bacon - was sliced and wrapped around wheel spindles as a lubricant. A true grease consist of an oil along with a thickening agent that during the 1800's was typically soap. Grease was first used during ancient Egypt mixing lime with olive oils. Europe later would use black slugs to make axle grease on wagons and carts. Pine Tar sometimes added for it's preservative properties, although until refining petroleum in the 20th century, Tallow remain the prime lubricate for axles.
Yep, it's another slow day in Puyallup -
gravitylover (01-25-2019)
Old 01-25-2019, 08:18 PM   #819
.. fatback - today's bacon ...
Hey now, let's not lead the youngun's astray. All bacon is fatback but not all fatback is bacon.
Bacon is processed fatback. Fatback is still available and is used for many a fine food.
humfrz (01-25-2019)
Old 01-25-2019, 08:51 PM   #820
@humfrz, you really need to crosscheck your sources. SMH
http://cowboyandchuckwagoncooking.bl...huckwagon.html
humfrz (01-25-2019)
Old 01-25-2019, 09:07 PM   #821
Yep, that's what I used for a reference (I guess I should have put it in quotes) - my bad.
I also found this on the same web page -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Dadhawk (01-25-2019), gravitylover (01-26-2019), Ultramaroon (01-25-2019)
Old 01-25-2019, 09:12 PM   #822
Noted.
Hell, I ain't gonna debate pig meat with an old timer from Georgia -
Dadhawk (01-26-2019)
Old 01-28-2019, 08:05 PM   #823
Youngmanhenry
Drives: Subaru BRZ
do they replace the throw out bearing for f r e e ?
Sent from my SM-G930T using Tapatalk
Youngmanhenry is offline   Reply With Quote
Old 01-29-2019, 09:51 AM   #824
ermax
ermax's Avatar
I doubt it would be free considering the clutch doesn’t come off for this job. I suspect you could get a large discount considering they have the engine out for this job though.
Edit: as WNDSRFR points out, I'm an idiot. The TOB sits on the input shaft of the trany and is free when the engine is out. To replace it you would still need to clean up the old grease and reapply but it's a really quick job. I suspect they would still charge about 30mins labor for it but would probably only take 15mins to do the job.
The Following 2 Users Say Thank You to ermax For This Useful Post:
Tcoat (01-29-2019), Youngmanhenry (01-29-2019)
Old 01-29-2019, 11:09 AM   #825
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Just got my car back from my Toyota dealership yesterday after having the recall addressed. So far, so good. Oil changed, coolant changed, service manager said throwout bearing looked fine, they finally cleaned up most of the grime/mess made by the leaking timing cover they addressed months ago. Could be my imagination, but I seem to be getting a bit more heat in the cockpit than I was previously, which is a very good thing. Any explanation? Can't imagine why they'd touch the thermostat, and I know they didn't do a coolant flush... just drain and refill.. I asked.
Anyway, no issues so far, about 40 miles after the recall fix.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 01-29-2019, 12:48 PM   #826
WNDSRFR
Drives: FR-S,GTI
If I remember right, the clutch doesn't have to be removed to change the TOB. If the engine is removed from the transmission it takes about 30 seconds to change the TOB.
And yes my TOB is being replaced for free.
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 03:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 09:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 10:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-04-2015 11:12 PM
