Old 01-19-2019, 01:14 PM   #3963
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by JOSE_FBR7777 View Post
Will 235/40/18 nitto neogen work with my aodhan ds01 18x9.5 +35 all stock suspension
Yes. Others have even got 18x9.5 +38 with a 235/40 to work on oem suspension. They are going to poke.
Post#213 &214
http://www.ft86club.com/forums/showt...=28017&page=16
I LIKE TIRES!
Old 01-19-2019, 01:40 PM   #3964
JOSE_FBR7777
Drives: Scion FR-S
Ok thank you what’s the next size from 235/40/18
JOSE_FBR7777 is offline   Reply With Quote
Old 01-19-2019, 01:47 PM   #3965
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Um, the next size larger would be 245/35/18. And IIRC, that size is not available in the nitto neo gen.
I LIKE TIRES!
Old 01-19-2019, 01:48 PM   #3966
JOSE_FBR7777
Drives: Scion FR-S
Would I be able to run 235/45/18?
Old 01-19-2019, 01:53 PM   #3967
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Why do you think you want to?
I LIKE TIRES!
Old 01-19-2019, 01:54 PM   #3968
JOSE_FBR7777
Drives: Scion FR-S
I don’t want the tire to stretch
Old 01-19-2019, 02:01 PM   #3969
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Lol.
No one uses 235/45/18 on their twin. Additionally, to have less of a stretch, you want wider tires for your wide wheels. Not taller tires.
So, you will need coilovers to fit 18x9.5 wheels and non-stretched tires. 255/35/18 fit nicely on a 18x9.5.
I have 18x9 wheels and a 245/35 is slightly stretched on them. I personally like a bit of stretch.
I LIKE TIRES!
Old 01-19-2019, 02:04 PM   #3970
JOSE_FBR7777
Drives: Scion FR-S
Ok i appreciate the help thanks, 245 it is
The Following User Says Thank You to JOSE_FBR7777 For This Useful Post:
Leonardo (01-19-2019)
Old 01-19-2019, 02:14 PM   #3971
Leonardo
Country Boy 4 Life
Leonardo's Avatar
So, your tire is going to be close to the spring perch. Hopefully it clears. It probably will. Depends on the tires actual width. Anyway, you will have some poke. And to get rid of the poke you will need camber. To add camber, you will need room between the tire and spring. To get room, you will have to add coilovers.
If you rub, a 3mm slip spacer can be added without changing anything else. You will only have clearance issues in the front, if you do. Meaning you would only need two 3mm spacers, in the off chance you rub.
Good luck.
I LIKE TIRES!
Old 01-19-2019, 02:17 PM   #3972
JOSE_FBR7777
Drives: Scion FR-S
Ok thanks I have 18x8.5 in the front and 18x9.5 in the back I can tint the 235/35 or 235/40
Old 01-19-2019, 02:20 PM   #3973
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have had several staggered setups. The closer tire widths are front and rear, the better the car drives.
What offset are your front 18x8.5 wheels?
I LIKE TIRES!
Old 01-19-2019, 02:38 PM   #3974
JOSE_FBR7777
Drives: Scion FR-S
+35
Old 01-19-2019, 02:46 PM   #3975
Leonardo
Country Boy 4 Life
Leonardo's Avatar
+35
Ok. Now we are getting somewhere...
If you want a staggered setup. I would suggest 225/40 front and 245/35 rear. Get camber bolts for the front, you will have room to add camber.
Or get 245/35 front and rear.
I think you'll want to lower your car in the future. I'd suggest TRD springs for a 1" drop. (They work well with OEM shocks)
I LIKE TIRES!
Old 01-19-2019, 02:57 PM   #3976
JOSE_FBR7777
Drives: Scion FR-S
Ok so I was thinking of going staggered but I didn’t know what size to run, whit the sizes you gave me would I still be able to put coil overs?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
