Old 01-01-2019, 11:24 PM   #71
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by PolishFrs13 View Post
something ill have to take a look at when im off work..
does he have a build thread on here ?
It is PrimeMotoring’s car. I don’t think there is a build thread here. The RB engine had a build thread.
Old 01-02-2019, 12:02 AM   #72
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
Yeah I just spent a few minutes searching for it but no luck until im off work. Than ill be able to actually look at it all. the Prime-motoring looks like af
PolishFrs13 is offline   Reply With Quote
Old 01-17-2019, 12:32 PM   #73
Ashikabi
Ashikabi's Avatar
Anybody consider using the Nemesis ECU for this?
Old 01-17-2019, 02:46 PM   #74
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
has anyone successfully used this ecu to control all factory functions? I've only seen it in a racecar. finding someone to tune it is another issue. One of the reasons we went with an M1 ecu, among many other things
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 01-17-2019, 02:53 PM   #75
Ashikabi
Ashikabi's Avatar
According to the manufacturer, yes. EXCEPT cruise control. But only because it's always been used with drive-by-cable throttle bodies. He is developing a drive -by-wire throttle body for the LS engines now. I expect when/if that is completed, then cruise control will again operate
Old 01-17-2019, 04:14 PM   #76
vijay.dy06
Drives: Red BRZ
@Ashikabi I sent you a message.
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
Old 01-18-2019, 08:23 AM   #77
Pho20
Drives: 2013 Subaru BRZ
Very interested in retaining cruise control
Pho20 is offline   Reply With Quote
Old 01-18-2019, 08:26 AM   #78
Ashikabi
Ashikabi's Avatar
Me and Vijay were just discussing this. It's likely you could use an aftermarket unit to control Cruise by itself
Old 01-23-2019, 09:48 AM   #79
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I've been looking at this setup:
http://k-tuned.3dcartstores.com/New-...ocks_b_58.html
I think for guys that don't care about AC it is an easy button for the belt drive system.
Thoughts?
Pure Automotive is offline   Reply With Quote
Old 01-23-2019, 01:58 PM   #80
frsty_86
frsty_86's Avatar
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
Thoughts?
K-Tuned makes great products. This bracket says it will take B or D series alternators which means cheap replacements if one ever goes bad. Who needs AC anyways?
frsty_86 is offline   Reply With Quote
The Following User Says Thank You to frsty_86 For This Useful Post:
Pure Automotive (01-23-2019)
Old 01-24-2019, 10:20 AM   #81
Icecreamtruk
Drives: Track preped NA FRS
I know I dont need an AC, or cruise control, or traction control, or SC control, or the OEM dash (any dash will do, like an AIM unit). ABS would be nice, but I can live without as well. I really just hope my stock engine will last enough for this kit to be finished. Yeah, I just need it for a race car, and I just need tiny wee bit more power (like 220whp or so), reliability and cheap replacements and lighter than OEM, which is why this swap has my name all over it.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Joesurf79 (05-21-2019)
Old 01-24-2019, 10:36 AM   #82
Ashikabi
Ashikabi's Avatar
Sounds like you don't need anything more than what is already available. If you don't need any of the features the car currently has (like ABS, TC, ETC) then you can bolt in just about any motor, get a custom drive shaft, stand alone ecu, and a gauge cluster that works with that computer. Easy peasy. It's getting all the"optional" amenities working that is the hard part
Hell, throw a carbed V8 in there. Then you don't even need an ecu
Old 01-24-2019, 10:43 AM   #83
Irace86.2.0
??? I’m utterly confused why you would spend over ten thousand on this swap for something that is achievable on the stock motor with bolt ons, e85 and a tune. If you aren’t going to buy the motec then you will save some money but still be in the hole for a lot more money.
Old 01-24-2019, 10:47 AM   #84
Tokay444
Clearly you have no idea what a K series can do with E85 and a tune...
Get one built, and I've seen them make over 500, N/A.
[ame]https://www.youtube.com/watch?v=1TggNaqQIU0[/ame]
The Following 2 Users Say Thank You to Tokay444 For This Useful Post:
Draco_PR23 (01-25-2019), Pure Automotive (01-24-2019)
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! Pure Automotive Engine Swaps 29 01-10-2018 01:20 AM
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap Pure Automotive Engine Swap 0 12-01-2017 11:57 AM
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:49 AM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:23 AM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 06:33 PM
