#687 | |
Drives: FR-S,GTI
#688 |
Drives: '13 SSM BRZ Limited 6MT
#689 |
Drives: Spyder, MR2, FRS, Tundra
All OE parts are warrantied for a year even if you install them yourself.
#690 |
Drives: 2013 Ultramarine FR-S
Hey guys, I took my 2013 FR-S manual with 26k miles into my local dealer for the valve spring recall. With the engine out, they have also suggested the following:
-Replace the clutch: $300 parts, $295 labor (2-3 hours?) as they claim it has unusual wear. Here's the picture they sent with it already out? I don't know what "unusual wear" should look like. The disk is $91 on the Toyota site, though they may be replacing other things too (plus markup of course)? -Replace spark plugs $100 parts, $130 labor (1 hour?) - seems like typical dealer markup on the plugs, and an hour of labor is probably excessive, but also not that much a concern. I know these aren't supposed to be replaced until 60k miles, but it's also six years old at this point. -Clean mass air flow meter of deposits - $91 - this seems like BS -Induction service to clean fuel delivery system - $218 - this really seems like BS -Four wheel alignment as he says they had to remove suspension parts which seems like they should have to pay for it themself as part of the recall - $130 Does this make sense? |
#691 | |
1: Suspension doesn't come apart on this job 2: If the suspension was coming off the letter you got in the mail would tell you that and also mention that you will be getting a free alignment. This is how it was on my Sequoia when it had a recall. I was excited because it was in desperate need of an alignment at the time. 3: Clutch isn't removed on this job so how did they get that picture? Are they really wasting a bunch of time pulling your PP off just to get a look at your clutch? No, they are sending you a pic from someone else's car. 4: They want $130 in labor to screw in new plugs rather than screw in old plugs? I would pass on everything they recommended and find a new dealer. |
#692 |
Drives: Toyota Supra 2JZGTE VVTi
Charging you labor to do spark plugs is a rip off since they are removing them to do the warranty. The only extra labor should be removing the new part from the box. It might be an extra hour of labor to do the clutch at most. I'd say they're trying to screw you 100%.
#693 |
Thanks. It seemed really sketchy.
#694 | |
Drives: '13 BRZ Limited
I'd have them put in a new throw out bearing - it's cheap and they tend to fail. I had to replace mine - and did the clutch disk and pressure plate while I was in there. My disk looked similar to that one - there were a few rivet holes that had some clutch material that had packed in - I think that's normal. Yours (or that pic) looks like it is not very worn. Probably good for at least 2x the mileage you have now. Are the springs loose at a all in the disk? Mine were a bit so I replaced it. My pressure plate fingers were worn a fair amount - so replaced it as well. Friction surface looked OK. |
#695 |
Drives: Scion FRS 2013
I had the recall fix done last week on my 2013 manual FRS. They replaced my spark plugs with no charge for labor - only charged for parts.
#696 |
On the repair, at the dealership where I had it done, yes. Your warranty may vary as this dealership does that on all repairs. I did verify it was applicable though..
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#697 |
The shop that did mine only charged me for the spark plugs, no labor.
#698 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Got my letter in the mail today. I expected it to come, though. Have to stop by the dealership in the next few weeks to see how they're going to deal with my Edelbrock supercharger. Being in CA puts us in a bind as I heard that you can't renew your registration unless this recall is addressed. I might have bought myself a bit of time by renewing this year's registration online a couple of weeks ago. Hopefully I'll get my tag for 2020 and have time to wait for others to get the recall done before I bring mine in. I don't want to be the guinea pig, especially with FA.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#699 |
According to the procedure breakdown, they do some suspension disconnections for automatics, which makes this extra concerning because presumably the OP has a manual.
#700 | |
Live Free, Drive Hard
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
![]() 1. Fix it/don't fix it. 2. Keep it/sell it.
| Broken Valve Spring | sybrite | Engine, Exhaust, Transmission | 45 | 11-02-2018 04:20 AM |
| Valve spring swap | rcmf5525 | Engine, Exhaust, Transmission | 6 | 05-19-2018 03:12 PM |
| Jrsc replacement diverter valve issue | Brzxton | Forced Induction | 6 | 12-08-2017 09:39 AM |
| GSC FA20 Valve Spring Kits | MAPerformance | Engine, Exhaust, Transmission | 41 | 07-20-2015 10:22 AM |
| Skunk2 Dual Valve Spring and Titanium Retainers | limitedblkwrx | Engine, Exhaust, Transmission | 0 | 01-04-2015 11:12 PM |
