Old 01-09-2019, 09:31 AM   #421
muffinz
Drives: 2013 DGM BRZ Ltd
Originally Posted by Legend@wheels View Post
As it looks like it has no cons at all - im going for it!!
2 q's-
1 -The big diff is by changing the cylinder alone,right?
Changing the hydraulic line and/or removing spring is just an extra?
2 after doing that where is the most safe position(to make sure no damage will occur in the long run) for the pedal? 1:1 with the brake pedal height is ok?
1. Yes, the cylinder will change the feel. The line will change the performance under extreme conditions.
2. Yes 1:1 with brake should be fine. Just make sure you bleed it fully and that when you're stopped in gear the clutch doesn't grab until you let the pedal out a little bit. You don't want the clutch rubbing when the pedal is to the floor.
muffinz is offline   Reply With Quote
Old 01-09-2019, 09:44 AM   #422
Legend@wheels
nenber
Hi
1 Didnt understand what u said after 'Should be fine.'
2 how so?(the new line performance)what ill feel?
Sent from my SM-G960F using Tapatalk
Legend@wheels is offline   Reply With Quote
Old 02-28-2019, 03:36 PM   #423
N234
N234's Avatar
Drives:
Hi
1. When the clutch pedal is pressed all the way down, there should be no touching of the plates. While pressed all the way down, shifting gear should be easy, and on a flat surface the car should not roll when going from R to 1 to R).
Sent from my SM-G930W8 using Tapatalk
N234 is offline   Reply With Quote
Old 02-28-2019, 11:20 PM   #424
You won't feel any difference at all. Don't bother.
Old 04-02-2019, 03:28 AM   #425
biggie
Drives: gt86
re
Hi,
I want to do the exact opposite, I need the clutch pedal to be softer (easier to press). I know this sounds like blasphemy, but don't pick up the stones just yet
I have spine surgery that bothers me when using the clutch in the GT86. I also have a Mazda3 that is much softer and I have no issues with that.
Don't get me wrong, I like the feel of the clutch pedal in GT86 as it is, because is gives much more feedback compared to the Mazda, I just need to make it softer because of the reason mentioned above!
Can anyone help me find the right slave cylinder for this?
P.S. I tried to find a stiffer spring to replace the OEM but with no success (I have LHD)
biggie is offline   Reply With Quote
The Following User Says Thank You to biggie For This Useful Post:
bhmax (08-17-2019)
Old 04-02-2019, 10:03 AM   #426
tobin
tobin's Avatar
Drives: '13 BRZ
Originally Posted by biggie View Post
Hi,
Just curious, did you buy your car new? If not, did you check to make sure a previous owner hasn't already removed the spring?
tobin is offline   Reply With Quote
Old 04-02-2019, 10:17 AM   #427
biggie
Drives: gt86
The spring is there
Old 04-22-2019, 11:48 PM   #428
Sgtfluffy16
Drives: White BRZ Limited
this might be a dumb question. Is there any benefits to upgrading to DOT4 fluid? I know it has a higher boiling point. But can i use that in the clutch fluid resivior? I have to bleed the brakes on my R1 and that requires DOT 4 so i figure. 2 birds, 1 stone right?
Sgtfluffy16 is offline   Reply With Quote
Old 04-23-2019, 12:54 AM   #429
It would need to have a larger bore than stock 13/16 inch, 21 mm or greater. Depending on your motivation/resourcefulness, the fork could also be extended and the stock slave mounted on spacers.
I don't know about other parts that might fit. This mod was an accidental miracle for me.
Totally fine to use DOT 4. No worries.
jcw99 (04-23-2019), Sgtfluffy16 (04-23-2019)
Old 07-21-2019, 09:08 PM   #430
Why I like the assist spring
I regret losing the perch for my assist spring but not enough to scrounge up a replacement. I like the assist spring mostly because it seats the pedal firmly against the top of its travel. Other clutch pedals have a small torsion spring for pedal return. Manufacturers would love to ditch that spring but it's too expensive to make a linkage that doesn't rattle. From a design standpoint, the assist spring is an ingenious little way to make a feature out of an otherwise necessary evil.
Clevis joints are inherently sloppy but they're cheap. So much so that the addition of a return spring to manage tolerance is still cheaper than any other solution. I imagine the moment when a smart guy said "If we have to have a return spring, let's also make it push down on the pedal while we're using it."
On the production line, it's relatively easy (cheap) to adequately adjust a linkage that has a little slop. One of the unintended consequences of removing the return spring is that it requires adopting a whole new approach to adjustment of the pedal linkage. We have to actively manage that slop. On one side we have a rattling pedal. On the other we have a rattling master cylinder. I'll get into the latter later.
The first requirement of clutch pedal adjustment is that the master cylinder must be allowed to eject the plunger all the way to the stop shim. This is best for the life of the system because chassis noise/vibration is not vibrating the piston. It also guarantees full opening of the equalizing port for self adjustment.
Secondly, because we no longer have the return spring to pull the pedal home, we must carefully use the rubber foot as the adjustable hard stop for the pedal itself. The factory adjustment procedure allows for some clearance between foot and switch base.
I've found the sweet spot to be when the pedal is at rest, the cruise cancel switch is adjusted so there is almost zero clearance between the switch and foot. Set it to minimize the distance between lifting the pedal away from the clevis pin to where the foot comes into contact with the switch body.
I've driven one with an mtec spring. It's nice because it functions well for pedal return, and is less obtrusive. I'd use it If I really hated the assist spring. If I wasn't missing other parts, I'd have long ago reinstalled the stock one.
jcw99 (07-21-2019)
Old 07-21-2019, 09:34 PM   #431
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
When are you coming to the bay area again? I gotta install this but i need your help, dood.
Old 07-21-2019, 11:28 PM   #432
I promise that I'll let you know before the next time I go down to visit my brother. Let's set up a drive afterward and make a fun day of it.
EAGLE5 (07-22-2019)
Old 07-22-2019, 02:55 PM   #433
A "fun" day with J? You are optimistic.
Old 07-22-2019, 10:51 PM   #434
stockysnail
Just the tip
stockysnail's Avatar
I went back to the OEM slave as I broke my left foot (3 middle metatarsals) and got a stronger ACT clutch. Glad I went back as the new clutch with OEM slave is just as hard to push as the OEM clutch with smaller slave!
The Following User Says Thank You to stockysnail For This Useful Post:
jcw99 (07-23-2019)
clutch line, slave cylinder
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 06:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 08:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 10:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 01:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 05:32 PM
