#71 |
Drives: Late 2014 Subaru BRZ
Of course Toyota & Subaru say don't put Flex Fuel in the car. The factory car doesn't have a Flex Fuel sensor to read or understand it. Flex Fuel does need to use 33% more fuel in order to not lean out.
Anyways, I just got my shiny new CP 12.5:1 pistons in and I'm planning a high comp turbo build. I'll be more than happy to post pictures of the valves and injectors in the next few months.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
| The Following 4 Users Say Thank You to GsxrMe For This Useful Post: |
#72 | ||
Drives: '14 Monogram, '95 Miata, '90 300ZX
The scientific community does. Pretty much the whole civilized world does other than the previously mentioned flat earthers and "jesus lizard" believers. I'm starting to see what we are dealing with here. Quote:
There is absolutely nothing scientific in that video, nor is there anything that disproves in all cases that long term ethanol use will not harm a vehicle. They gave a mileage but not a timeline, or how the vehicle was used. Again, you will effects in a vehicle that was allowed to sit to a much higher degree than one where new fuel was regularly cycled into the system. I'll say it again. There's a reason why the manufacturer doesn't authorize the use of the stuff. Until you people produce documentation from them, or vendor literature for each of the individual parts authorizing use of high concentrations of ethanol, you are always going to be running a risk. "Hurrrr, durrr, durrr, my car has worked fine for 3 years and 40k miles so it must be fine" is not a scientific argument. In fact, it is no better than the simps who say "I've run a stanced car with extreme camber and stretched tires for x years now, never had a problem. There's nothing unsafe about stance". |
| The Following User Says Thank You to Yardjass For This Useful Post: | redrocket89 (03-08-2017) |
#73 | |
Drives: 2014 Scion FR-S Monogram
Sure our cars are not flex fuel labeled but what do you think is different about our cars and the average "Flex Fuel Approved" vehicle? I have a feeling that at a maximum they have seals and hoses that are "approved" to be used with ethanol and a ethanol content sensor. A lot of these approvals that everyone looks for are little more than taking the standard item testing it and if it passes label it as "approved" I doubt that the fuel system on flex fuel cars have no rubber or plastic in them. It would not be economical for a company like GM to change all of those parts on some of their vehicles to be approved for a fuel that I have barely ever seen a person use other than it being a sports car tuned for it to make more power. The whole system of "Flex Fuel" doesn't make sense to me. When E85 is fractions cheaper than the standard 87 oct fuel and sometimes the same price, why would anyone opt to put it in their car and take the 30% reduction in fuel economy? I don't think the "Flex Fuel" vehicles are any more than a marketing scheme used to sway buyers toward their vehicles but this is my personal opinion and if someone proves me wrong then I will change it. P.S. why would anyone not take advantage of the cheap HP gains E85 gives us anyways
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
#74 |
Drives: 2014 UltraMarine FRS
@GsxrMe I could do the same too... My 12.5:1 pistons will be coming soon, and fullblown will be doing the build within the month hopefully.
I ran E85 this entire past year, although only about 5k miles. Ill see if I can get fullblown to take pics of the head when they take it apart to put in new springs and what not. Also the stock pistons and injectors. Maybe pointless considering the car only has 10k miles total on it though. |
#75 | |
The difference is the parts on a flex fuel car are made of materials whose specs are certified to stand up to ethanol fuels. People can check these specs for lines, O-rings, etc. and check the manufacturer's info for the pump, injectors, and so on. When doing this, they could potentially come to the conclusion that the fuel is okay for use, even without a blessing from the vehicle's manual. The fact that nobody has been able to do this for our cars, leads me to believe that some part of them isn't. At this point, it is pretty clear from everyone running E85, that despite what anything says, you are fairly safe running the stuff for a few years as long as you are regularly running through the contents of the gas tank. I personally wouldn't hesitate to do it provided I didn't plan to keep the car for a long time. Just have your fun, sell it, and make it someone else's problem by the time issues show up. That still doesn't prove that problems will never show up, or that long term, the vehicle's parts will resist corrosion and other negative effects brought about by the water than ethanol will draw into the fuel. It also doesn't prove that an owner won't get unlucky and have to deal with some sort of problem that comes from their not-as-directed use early on in the vehicle's life. Heck, would everyone still choose to run ethanol knowing that their car could have a failure that wasn't caused by ethanol but can't be proven/disproven, and the manufacturer will still use it as an excuse to stick them with the bill? |
#76 |
Drives: 2014 GT86
Would everyone still choose to live knowing that we all gonna die?
| The Following 4 Users Say Thank You to churchx For This Useful Post: |
#77 |
Drives: Toyota GT86
This is my motor, after 2 full race seasons on E85.
Here in Sweden we have some problems with the pink color detergent that the government ad too the E85, and often cases like a red go on the valves and ports (al most like carbon buildup) but that is cured with a little dash of Redline SI Alcohol cleaner/lubricant in every fill up.
| The Following 4 Users Say Thank You to Fricke For This Useful Post: | Lantana frs (03-09-2017), new2subaru (03-09-2017), Prodigalson (09-15-2018), PulsarBeeerz (01-13-2019) |
#78 | |
Drives: 2015 FRS
| The Following User Says Thank You to Reamer For This Useful Post: | chaoskaze (08-31-2018) |
#79 | |
Drives: 2014 86 GTS
| The Following User Says Thank You to 504 For This Useful Post: | Lantanafrs2 (01-04-2019) |
#80 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I've been running e85 for 4 years. I street race, roll or dig, autox, and race at drag strips. Never used a fuel stabilizer and i have ZERO problems. I'm NA 205WHP and it's my daily.
| The Following User Says Thank You to Dr. BRZ For This Useful Post: | Lantanafrs2 (01-05-2019) |
#81 |
Drives: 2013 frs red
#82 |
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
This thread is the most hilarious thing to read for anyone with a stem degree and for anyone that has been in an older car community which has made use of ethanol for decades now. IE: the evo community in america which has made use of e85 for over a decade now and the dsm community for over 2 decades now.
Thank you to the person that necro bumped this thread to my attention. |
#83 |
Drives: 2015 Scion FR-S
having used E85 in a dedicated race vehicle: there are some issues with it more so than standard gasoline but it's not anything crazy. it can gum up if left in the tank/lines/engine for long periods of time. it's much more corrosive. just put a little on the floor of your shop and see lol.
i wouldn't recommend leaving it in the car over the winter but filling up and using the car as a weekend car wouldn't be anything to worry about IMO. It's like anything else when it comes to making upgrades, don't be lazy about it and keep an eye on things/maintain as necessary. |
| The Following User Says Thank You to e_lunatic For This Useful Post: | Lantanafrs2 (01-05-2019) |
#84 |
| The Following User Says Thank You to Dr. BRZ For This Useful Post: | Lantanafrs2 (01-13-2019) |
| Long Term FR-S | regal | Scion FR-S / Toyota 86 GT86 General Forum | 83 | 04-01-2016 06:40 AM |
| long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 08:56 AM |
| Long term | Bt216 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-06-2013 11:58 PM |
| Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 02:18 PM |
| Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 09:55 PM |
