nenber
a quick one-colors
hi
is the mt90 redline 75w90 trans oil is the same color as the OE one?(still under warranty so..) if not,whats the oe's oil color? |
#2 |
Drives: BRZ 2017 Pure Red, MT
http://www.ft86club.com/forums/showthread.php?p=3167619
According to this video, at 8min, it looks red/pink. OEM oil is probably going to be black/blackish if you have some miles on it. |
| The Following User Says Thank You to nico_rsx For This Useful Post: | Legend@wheels (12-31-2018) |
#3 | |
nenber
still havent picked the one to go with(tried 300 and its shitty) so i might be more interested to know what color is the OE one. Last edited by Legend@wheels; 12-31-2018 at 03:25 AM. |
#4 |
nenber
is anyone know the OE gearbox oil color?
#6 |
Drives: 2017 BRZ
The bit about warranty suggests OP wants oil that can pass for OEM in a visual inspection in case of any warranty work that might arise in the future.
| The Following 2 Users Say Thank You to Brink For This Useful Post: | humfrz (01-01-2019), Legend@wheels (01-01-2019) |
#7 |
Hmmm...….OK, you are probably right.
Question for the OP @Legend@wheels as long as the oil that was put in the transmission meets the specifications in the manual, would it make a difference, when it comes to warranty work in Israel? I'm just wondering if you're worrying over something that doesn't need to be worried about? humfrz |
#8 | |
nenber
Sent from my SM-G960F using Tapatalk |
| The Following User Says Thank You to Legend@wheels For This Useful Post: | humfrz (01-02-2019) |
#9 | |
nenber
If its 100% fits so it might be more easier . But i dont think that the oils we put does that. (Mt90,mt85,pentosin,motul300 and so on) P.s If i was thinking what we put is bad i wasnt doing that in the first place/or the oil ive put caused that then i wouldnt go dealer at all since its my fault. But in this case those boxes came out from the dealer as a rubbish boxes. Sent from my SM-G960F using Tapatalk |
#10 |
If the fluid is compatible, it doesn't matter if it's OEM or not...
| The Following User Says Thank You to wparsons For This Useful Post: | venturaII (01-02-2019) |
#11 | |
nenber
Anyway i just want to know its color thats it. If anyone got his previous oil out and it was new car so its the still the same color so its a good indication Sent from my SM-G960F using Tapatalk |
#12 | |
Drives: 2017 toyota 86
If it’s the same “spec” it should not matter assuming the proper filling protocol was met and that replacing it wasn’t the specific issues “filling too much, too little, forgetting to put drain and or fill plug back on etc...” |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | wparsons (01-03-2019) |
#13 | |
Only users lose drugs.
Drives: All the time
And to answer your question, OEM is amber in color. I've been using Toyota LV 75W transmission lube for changes at Toyota's suggestion (also amber). It ain't cheap though... I recently changed to Amsoil 75W-90 GL-4 because it's half the price of the Toyota stuff, and I have to say I'm not impressed. I might switch to Redline MTL 75W80 GL-4.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following 2 Users Say Thank You to venturaII For This Useful Post: | Legend@wheels (01-02-2019), wparsons (01-03-2019) |
#14 |
nenber
Tnx
Then its yellowish like the 300. Always thought its red. Sent from my SM-G960F using Tapatalk |
| FS: NRG Quick Release 3.0, Quick Lock, Steering Wheel | akiranakayama | Interior Parts (Incl. Lighting) | 13 | 08-16-2016 10:40 AM |
| FS: New NRG Quick Tilt & As-Is NRG Quick Release | bear89103 | Interior Parts (Incl. Lighting) | 2 | 10-16-2014 01:11 AM |
| FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel | Pekingduck | Interior Parts (Incl. Lighting) | 7 | 02-12-2014 05:59 PM |
| Quick Release or Quick Lock Steering Wheel and Theft defense too? | 1086 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-24-2014 04:50 PM |
| FRS colors = Prius colors? | lemonspeakers | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 04-11-2013 12:14 AM |
