#43 | |
Drives: 2015 FR-S
| The Following 2 Users Say Thank You to Cubix For This Useful Post: | PulsarBeeerz (12-14-2018), venturaII (12-15-2018) |
#44 |
Drives: 2013 Scion FRS 10 Series
I think the s2000 transmission you can for less than 1k with less than 50k on it. K24 is a couple grand. The 86 transmission is not cheap by any means a lot more than a S2000 transmission. I think it’s a win across the board IMO for this swap.
#45 |
Drives: Q5 + BRZ + M796
I think you might be confused. A used 86 transmission is about the same $500 as a S2000 transmission. Maybe a built 86 transmission to match the s2000’s strength would make it more expensive.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | BertoFT (12-15-2018) |
#46 |
#47 |
Drives: 2015 FR-S
But I already HAVE an 86 transmission in my 86. I wouldn't have to buy another part.
#48 | |
Drives: 13 FRS Firestorm
Sent from my SM-G9600 using Tapatalk |
#49 | |
Drives: 2015 FR-S
| The Following User Says Thank You to Cubix For This Useful Post: | venturaII (12-15-2018) |
#50 | |
Unfortunately, I have no clue if that is a quality part. I do know that there have been K-swapped S2000's, which leads me to believe that there are many existing parts we can take advantage of with that engine/trans combo. Sent from my SM-G9600 using Tapatalk Edit: I hope I'm not discouraging anyone from going this route. I've been saving for an LS swap, but a K24 swap is more affordable! |
#51 | |
Drives: 2015 FR-S
https://kmiata.com/products/engine-adapter-plate |
#52 |
Rust bucket enthusiast
This swap seems like a configuration I wanted from the factory. When I heard about it, I imagined a legendary STI transmission, and a sweet Toyota build like the 3sGTE OR 2ZZ. I still love our car, but I had to admit it felt backwards. I get why they did it though... Can't wait to see this swap get popular
#53 | |
This swap butts the rear of the motor right next to the firewall, yet the motor sits about the same distance forward as the FA20 (no real savings there). The STI/WRX/etc have the transmission inline with the front wheels to have symmetrical AWD. See below: STI ![]() 86
#54 | |
To be honest I'm not concerned with the weight distribution, I like in-line engines better, that's all. |
#55 |
Here's a disgusting amount of details regarding the K-series: https://www.k20a.org/forum/showthread.php?t=53589
**disclaimer- I have never rebuilt an engine, the most of I've done is clutch replacement. I used this site as a reference: https://www.realstreetperformance.co...d-buyers-guide. The numbers below are from googling** It looks like 5-6k for a junker engine/transmission AND internal upgrades, if you do most of the work yourself. This is the route I'm taking. I'm still waiting on Pure's engine management alternative to Motec, otherwise, add $5k+ for Motec: $800 - junker K24a2 (engine/acc/ecu/harness) $800 - AP2 transmission $500 - forged pistons $500 - forged rods $1000 - camshaft $650 - valvetrain kit $160 - ARP studs $50 - Main bearings $50 - Rod bearings $600 - S2000 oil pump (recommended for redline about 8500 rpm) $60 - Lower timing chain guide (keeps timing chain from jumping) $100 - steel head gasket $11 - exhaust/intake valve seals $1000(?) - head inspection/machining $1000 (opt) - Ferrea rockers (might be needed for 9000rpm+ redline?) $230 (opt) - crank timing gear upgrade (https://www.kseriesparts.com/DCI-CTG.html) $360 (opt) - Balance damper Any corrections, opinions or criticisms are welcomed. Keep this thread alive! |
#56 | |
No K20 head? It was my understanding that all the 250Fwhp+ k24 swaps run the k20/k24 combo. |
| Pure Auto's Swap Compilation Thread - 2JZ and LSX ! | Pure Automotive | Engine Swaps | 29 | 01-10-2018 01:20 AM |
| SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:57 AM |
| SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:49 AM |
| SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:23 AM |
| Pure Auto's 2JZ Swap Thread - The DRAGFRS | Pure Automotive | Engine Swaps | 153 | 06-20-2016 06:33 PM |
