Old 12-14-2018, 10:55 PM   #43
Cubix
Cubix's Avatar
Drives: 2015 FR-S
Yes, it is more robust than ours. I have a friend with a shop that specializes in S2ks, and he has built plenty with the stock transmission holding 700 whp range (say around 600 wtq). Our transmission has been proven to grenade at considerably lower numbers, specially 4th gear and the shift fork.
Don't people get reliable 250-300 whp out of our stock trans with FI? Because if so, I would much rather keep the stock transmission since S2K transmissions aren't exactly cheap. I'm not necessarily looking for 700 whp with this swap.
Cubix is offline   Reply With Quote
The Following 2 Users Say Thank You to Cubix For This Useful Post:
PulsarBeeerz (12-14-2018), venturaII (12-15-2018)
Old 12-14-2018, 11:58 PM   #44
flashman17
Drives: 2013 Scion FRS 10 Series
I think the s2000 transmission you can for less than 1k with less than 50k on it. K24 is a couple grand. The 86 transmission is not cheap by any means a lot more than a S2000 transmission. I think it’s a win across the board IMO for this swap.
flashman17 is offline   Reply With Quote
Old 12-15-2018, 12:23 AM   #45
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I think you might be confused. A used 86 transmission is about the same $500 as a S2000 transmission. Maybe a built 86 transmission to match the s2000’s strength would make it more expensive.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
BertoFT (12-15-2018)
Old 12-15-2018, 12:24 AM   #46
Irace86.2.0
http://blog.wiseco.com/the-500-horse...ine-by-4piston
Something like this would be fun.
Old 12-15-2018, 08:00 AM   #47
Cubix
Cubix's Avatar
Drives: 2015 FR-S
But I already HAVE an 86 transmission in my 86. I wouldn't have to buy another part.
Teseo (12-31-2018), venturaII (12-15-2018)
Old 12-15-2018, 09:34 AM   #48
BertoFT
Drives: 13 FRS Firestorm
You would need an adapter plate to mount the 86 transmission to a k24 engine. The adapter plate will cost more than an s2000 transmission. I don't even think Pure would make money from making/selling such an adapter (pure speculation).
Sent from my SM-G9600 using Tapatalk
BertoFT is offline   Reply With Quote
Old 12-15-2018, 09:45 AM   #49
Cubix
Cubix's Avatar
Drives: 2015 FR-S
You would also need an adapter plate for the K24 to S2000 transmission.
The Following User Says Thank You to Cubix For This Useful Post:
Old 12-15-2018, 10:02 AM   #50
BertoFT
K series to S2000 adapter plates already exist: http://www.balladesports.com/product...-adapter-plate
Unfortunately, I have no clue if that is a quality part. I do know that there have been K-swapped S2000's, which leads me to believe that there are many existing parts we can take advantage of with that engine/trans combo.
Edit: I hope I'm not discouraging anyone from going this route. I've been saving for an LS swap, but a K24 swap is more affordable!
Old 12-15-2018, 10:08 AM   #51
Cubix
Cubix's Avatar
Drives: 2015 FR-S
That adaptor is inexpensive, so there should be no reason to assume an adaptor from K to our transmission would be expensive either. In fact, K-Miata has an adaptor for K series to Miata transmission and is also in a similar price range.
https://kmiata.com/products/engine-adapter-plate
Old 12-15-2018, 10:20 AM   #52
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This swap seems like a configuration I wanted from the factory. When I heard about it, I imagined a legendary STI transmission, and a sweet Toyota build like the 3sGTE OR 2ZZ. I still love our car, but I had to admit it felt backwards. I get why they did it though... Can't wait to see this swap get popular
Old 12-15-2018, 03:45 PM   #53
Irace86.2.0
Legendary STI transmission with a straight four??? If everyone is complaining about the FA20 being too far forward then that configuration would really put everyone off. Imagine adding two more cylinders to the front of an STI.
This swap butts the rear of the motor right next to the firewall, yet the motor sits about the same distance forward as the FA20 (no real savings there). The STI/WRX/etc have the transmission inline with the front wheels to have symmetrical AWD. See below:
STI
86
Old 12-15-2018, 06:02 PM   #54
DarkPira7e
DarkPira7e's Avatar
To be honest I'm not concerned with the weight distribution, I like in-line engines better, that's all.
Old 12-27-2018, 12:38 PM   #55
BertoFT
Here's a disgusting amount of details regarding the K-series: https://www.k20a.org/forum/showthread.php?t=53589
**disclaimer- I have never rebuilt an engine, the most of I've done is clutch replacement. I used this site as a reference: https://www.realstreetperformance.co...d-buyers-guide. The numbers below are from googling**
It looks like 5-6k for a junker engine/transmission AND internal upgrades, if you do most of the work yourself. This is the route I'm taking. I'm still waiting on Pure's engine management alternative to Motec, otherwise, add $5k+ for Motec:
$800 - junker K24a2 (engine/acc/ecu/harness)
$800 - AP2 transmission
$500 - forged pistons
$500 - forged rods
$1000 - camshaft
$650 - valvetrain kit
$160 - ARP studs
$50 - Main bearings
$50 - Rod bearings
$600 - S2000 oil pump (recommended for redline about 8500 rpm)
$60 - Lower timing chain guide (keeps timing chain from jumping)
$100 - steel head gasket
$11 - exhaust/intake valve seals
$1000(?) - head inspection/machining
$1000 (opt) - Ferrea rockers (might be needed for 9000rpm+ redline?)
$230 (opt) - crank timing gear upgrade (https://www.kseriesparts.com/DCI-CTG.html)
$360 (opt) - Balance damper
Any corrections, opinions or criticisms are welcomed. Keep this thread alive!
Old 12-27-2018, 01:00 PM   #56
PuslarBrrrz
$500 - forged rods
$1000 - camshaft
$160 - ARP studs
$50 - Main bearings
$50 - Rod bearings
No K20 head? It was my understanding that all the 250Fwhp+ k24 swaps run the k20/k24 combo.
PuslarBrrrz is offline   Reply With Quote
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! Pure Automotive Engine Swaps 29 01-10-2018 01:20 AM
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap Pure Automotive Engine Swap 0 12-01-2017 11:57 AM
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:49 AM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:23 AM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 06:33 PM
