Old 12-03-2018, 11:21 AM   #491
frsty_86
frsty_86's Avatar
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
@Crydo is only partially correct though as has been pointed out (although I suppose it could be different if he is outside the US). It will have to be done by Toyota for an FRS or 86, and Subaru for a BRZ.
However, dealers get paid for warranty work. It's usually a predetermined amount based on the parts and expected labor costs (basically book labor) and is at a predetermined rate, not the dealer's standard rate.
As confirmation, when I had my "cricket fix" under warranty I saw the dealer invoice that was going to Toyota including both parts and labor.
Dealers are independently owned, not owned by the manufacturer. I couldn't imagine a scenario where they would agree to do this work for free.
Well, he may have meant that they are not being paid by the customer. Not sure what difference it makes since they are being compensated regardless. I'm sure the techs are paid their normal rate, but the government may compensate the dealership less than they would otherwise receive if they were doing the work under a regular service ticket.
frsty_86 is offline   Reply With Quote
Old 12-03-2018, 11:26 AM   #492
If they screwed it up the first time?
OK, I'll give you that!
Old 12-03-2018, 11:30 AM   #493
I assume you meant the manufacturer and not the government as the government doesn't cover manufacturer recalls.
As far as compensation, many techs work as "independent contractors" with the dealership and are paid rates based on either the "book rate" for a repair or other agreement. If the manufacturer sets an hourly rate for the work, that is likely what the tech will be paid based on, which could be less than a retail customer rate.
I'm basing this off some limited experience as I have family members who are in the "dealership" business but it could obviously vary.
Old 12-03-2018, 01:17 PM   #494
frsty_86
frsty_86's Avatar
Yep, that sounds much more accurate than what I said.
The Following User Says Thank You to frsty_86 For This Useful Post:
Dadhawk (12-03-2018)
Old 12-03-2018, 08:50 PM   #495
notout86
Drives: GTS 86 auto
Originally Posted by alan.chalkley View Post
Routine subaru service every 15000kms or 9 months!
A couple of years ago I had the hose off the throttle body off and noticed a slight build-up & cleaned it out (from memory I think I used a cotton bud moistened with acetone). I do not have it listed as a routine maintenance in my Toyota service coupon book. I will write it in. "Cleanliness is next to godliness"
GTS86 Auto (Australia)
Old 12-05-2018, 12:34 PM   #496
Crydo
Crydo's Avatar
Drives: 2012 GT86 Dark Grey
Thats what I ment, I should have clarified that better.
its free for the customer, the dealer is compensated for around 12 to 13,5 hours.
I have the recall maintenance manual so I can check if you guys would like.
I dread this recall as my car is also affected.
Currently on 197K Kilometers (122K miles) and it drives like a dream, no issues at all, no oil leaks, nothing..
I'm afraid that once the work is done something will be wrong
Crydo is offline   Reply With Quote
The Following User Says Thank You to Crydo For This Useful Post:
humfrz (12-05-2018)
Old 12-05-2018, 01:03 PM   #497
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This isn't mandatory, you can choose to not have the work performed. I share this fear as well, and may opt to disregard the notice. On the other hand, dealer work should be dealer insured, right?
Old 12-05-2018, 01:23 PM   #498
Crydo
Crydo's Avatar
depends if you have everything documented. if it worked before and suddenly it does not... its your word against theirs right?
When I will get this done I want to have it on record that the dealer agrees that everything is currently fine, get them to sign a document of agreeing that its not leaking, take them for a test drive, etc etc.
If the car does start to have issues I will at least have something to fall back on..... if they agree to my terms that is
Old 12-05-2018, 01:47 PM   #499
Oh, if I had 122,000 miles on mine and it ran perfectly, I would be tempted to pass on the valve spring recall. Hell, I may pass on it with 25,000 miles on my car -
Old 12-05-2018, 06:02 PM   #500
srt4evah
Initial G
Drives: 13 FR-S, 15 BMW 228i
I've got 78k miles on mine and I'm about to install the Edelbrock SC. I'm more worried that the dealer techs won't do a good job and the engine will grenade after the SC goes on, and it will be my problem then.
The car runs great right now, no odd noises or issues. If it DOES blow up and I didn't do the recall, well at least I can build the block and turn up the boost... lol.
2013 FR-S
2015 BMW 228i
srt4evah is offline   Reply With Quote
Old 12-12-2018, 01:33 PM   #501
CB390248
Drives: Asphalt FR-S
How does this affect blown engines...?
Any thoughts on how Toyota will treat me? My stock engine grenaded at around 80k and now I have a refurbished engine installed by a dealership for approx 10k out of my own pocket because Toyota refused to provided assistance (they never said why) but presumably because I was past warranty. As mentioned here this problem is not simply worse case scenario the engine stalls...
CB390248 is offline   Reply With Quote
Old 12-12-2018, 03:27 PM   #502
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Would depend on if the replacement engine falls within the recall - by VIN number.
If not a VIN recall, you should be in the clear. For that problem, anyway.
Old 12-17-2018, 02:26 PM   #503
incriminati
The first go around my VIN was not part of the recall.
Then the recall check sites went down and didn't work.
The recall sites are back up and now IT IS part of the recall.
So yeah, just a heads up for everyone to check again, even if it said you're not affected the first time.
https://www.subaru.com/vehicle-recalls.html
https://vinrcl.safercar.gov/vin/vinLookup
incriminati is offline   Reply With Quote
The Following 4 Users Say Thank You to incriminati For This Useful Post:
davesrave (12-19-2018), humfrz (12-17-2018), nikitopo (12-17-2018), redfred (12-18-2018)
Old 12-18-2018, 05:31 PM   #504
gravitylover
Yep I'm on the official list now too.
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
