Drives: 2014 BRZ
Alignment after coilover rebuild?
I ran a couple of searches, but came up empty.
I've sent my coilovers in to be rebuilt and I'm wondering if I need to have an alignment done when I put them back on. They'll be setup the same as when they came off (height and pre-load) so I'm thinking I'll be ok, but I don't have enough experience to know better. I also couldn't really find any info on when exactly you should get an alignment done (other than if you change the height), so if anybody could enlighten me I would appreciate it. |
#2 |
Drives: 2014 Scion FRS (Asphalt)
I think it's always best to at least check the alignment after working on a piece of suspension or something that could change the alignment such as arms.
It's hard to get the exact same settings as when you took them out.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
| The Following User Says Thank You to tyler_win_photo For This Useful Post: | NickB34 (12-10-2018) |
#3 |
Drives: '13 FRS - STX
If there's anything adjustable that's been removed and could be reinstalled different from before like camber bolts, camber plates, any cam bolts on the rear suspension then I would say yes.
If everything you unbolted is non-adjustable it's unlikely that there will be much of a difference from before. But also realize that alignments don't last forever, stuff slips and changes over time of pounding across pavement, some people get alignments every few months, every year is suggested for people who drive their car hard, some people check alignment between track sessions, there's a wide spectrum. |
| The Following User Says Thank You to strat61caster For This Useful Post: | NickB34 (12-10-2018) |
#4 |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
If you're getting a suspension rebuild, then you probably want the handling to be optimized, yes?
So IMO, if ripping the dampers out, always get an alignment afterwards. |
| The Following User Says Thank You to BlueWhelan For This Useful Post: | NickB34 (12-10-2018) |
#5 |
Drives: 2014 BRZ
I realize that the typical response is that any time you touch the suspension you should get an alignment.
I'd get a before and after alignment to have some data to work with, but that just seems like it's probably a waste of money. Thanks for the feedback so far! Last edited by NickB34; 12-11-2018 at 01:43 PM. |
#6 |
Drives: Legacy GT
The rear should be fine, but the front camber at least would definitely need to be checked. Even if you don't have a camber bolt or put it back at the same angle, there is some room for things to move around when it's unbolted.
Also the corner balance will be different. |
| The Following User Says Thank You to jamal For This Useful Post: | NickB34 (12-11-2018) |
#7 | |
Drives: 2014 BRZ
My coilovers have a camber plate on top. I'm assuming that setting them to the previous position will be ok to run around on until I can get the alignment, right?
#8 |
Drives: 2014 GT86
NickB34: there is always some slack in bolt connections. Untightening/rebolting them, even for supposedly unadjustable connections often can make alignment for slight extent out of whack. I guess, that camplate setting may get you in rough ballpark for driving until alignment (at least non-performance driving on track), but i'd wish to have that alignment done sooner. For example if that slack in bolts rebolted changed at previous alignment carefully evened and dialed specific toe settings .. yes, i'd probably would be ok with slight driving for few days to-from work, but would more then prefer to have it set back right prior few days long or of very long mileage trips/trackday/anything that would benefit from better handling/more performance/not increased tire wear.
| The Following User Says Thank You to churchx For This Useful Post: | NickB34 (12-11-2018) |
| Tags |
| alignment, coilover, suspension |
| Coilover alignment | mpross | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 04-03-2016 11:58 AM |
| Coilover alignment specs on stock parts | Rifle | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 11-06-2015 04:07 PM |
| Low Price Guarantee: Stance and ISC coilover packages with SPL Alignment parts | AutoRnD | Brakes, Suspension, Chassis | 20 | 08-01-2014 12:54 AM |
| Alignment/coilover questions | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 08-04-2012 04:48 PM |
