| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Drives: Sedan
Is it normal for the AC to blow warmer air when under acceleration
I have noticed when I an accelerating that my A/C tends to blow warmer air out while pressing the gas. Is this normal for an 86 is should I get this checked out by the dealership?
#2 |
The Dictater
Drives: '13 Red Scion FRS
The AC automatically disengages when accelerating to give you more power for accelerating the car instead of cooling the air. It should reengage automatically when you are no longer accelerating.
| The Following User Says Thank You to Spuds For This Useful Post: | Tcoat (12-09-2018) |
#3 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (12-09-2018) |
#4 |
Drive From Home
Drives: BRZ STI Performance
I don't find that my AC really disengages when I floor it hard cuz the car is still being bogged down until I turn the AC off.
#5 |
Drives: 2017 BRZ
Do you mean when the A/C is actually running, or when the system is turned off and there's just air flowing through the vents while driving?
#6 |
I know this car will blow warm air through the vents during normal driving even if A/C is off. Is this what your describing? If so then yes its normal.
2013 Series 10 FRS #553
#8 |
Yep. Not just normal for this car but for almost every small displacement engine made for the last 20 years. Like so many things it is just more noticeable in these since everything is right there in your face.
#9 |
Every car I've even owned turns off the compressor when accelerating but my FRS seems to be more aggressive with turning it off then any of my others cars. The slightest acceleration will cause it to turn off. I got my car with 80K miles on it and I noticed after accelerating that it didn't seem to cool back off as quickly as I would expect. This got worse with time. It got to where I would be driving along the interstate and it would randomly start heating up for 10 mins at a time before randomly cooling back down. I figured it needed a charge which I did but it have no impact. Turned out the relay was going bad and randomly the compressor would fail to turn back on. I swapped my horn and AC relay and now the compressor cycles consistently and I don't really notice it getting hot when accelerating unless I'm on a back road where I'm not giving it a break. Now I have a horn that randomly doesn't work. One of these days I will get around to replacing it. Hahaha
| The Following 2 Users Say Thank You to ermax For This Useful Post: | Tcoat (12-10-2018), Ultramaroon (12-10-2018) |
#10 |
Feeling like thinking....
Huh..never noticed this. I'll have to check it out when I use my A/C again in four or five months. On the flipside, I HAVE noticed that this car takes forever to warm the cockpit, and then only at speed or revving. While idling at a light or tooling around town, I experience temperatures best described as "slightly less chilled."
Drive like everyone's life around you depends on it...
#11 | |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#12 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
The AC also takes care of de-humidification.
When you hit defrost, the AC comes on. Take a minute to knock all the slush off your boots first, and it's not quite as bad.
"I gotta rock." -- Charley Brown |
#13 | |
![]() Yep, like said above, cars with AC have been doing that for years. However, with some cars, back in the day, in the heat of a long road race, on a hot day, we used to manually turn off the AC (less power drain), roll up the windows (for less drag) and turn on the heater (to cool the engine). ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | spike021 (12-10-2018) |
#14 | |
| Coolent temps getting a bit warmer | Subz | AUSTRALIA | 1 | 04-24-2018 12:58 AM |
| Is this engine noise normal? (Consensus - normal) | StraightOuttaCanadaEh | Issues | Warranty | Recalls / TSB | 31 | 02-05-2018 03:01 PM |
| Which oil weight for warmer climates | Don Ivey | Engine, Exhaust, Transmission | 5 | 03-16-2015 01:12 AM |
| Warmer switch backs to match DRLs | TheBatman | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-26-2013 07:58 PM |
| Winter: Electric car & battery warmer install | JSUB | BRZ First-Gen (2012+) — General Topics | 2 | 12-26-2012 10:55 AM |
